Old Jun 29, 2003, 12:35 AM
FlightofSong is offline
Find More Posts by FlightofSong
Why yes, I DO work for GP
Danville Vermilion, Illinois, United States
Joined Oct 2002
HOWTO: Foam cutting templates - 5 minutes each MAX!
I really hate scroll-sawing formica and sanding it, and plywood is even less fun. Here's my method for cutting templates and having them finished and ready to go in 5 minutes apiece, maximum! This may be old news to some of you, but it may help someone get started at doing this.
This method assumes that you've already printed out your templates, whether you drew them yourself, or used somthing like profili to generate them.
What you need:
-Printed template drawings
-Aluminum Flashing - available at Lowes for $5 for an 18" X 10' roll.
-Good NONSERRATED scissors. I picked up some utility shears at Big Lots for 88 cents. The work great!
-Your favorit contact cement - I use Super 77.
-Some fine-grit sandpaper - 400 grit or better.
OK - glue the paper templates down to a piece of the flashing, and cut them out wiht the scissors. Hit the cutouts with a few lengthwise strokes with the sandpaper, and you're done!
Easy, huh? Since the scissors leave a nice smooth cut, if you cut on the line, there is none of the pain of sanding the templates. Just polish it with a few strokes, and you're good to go.
FlightofSong is offline Find More Posts by FlightofSong
Old Jun 29, 2003, 09:22 AM
dang is online now
Find More Posts by dang
USA, WA, Olympia
Joined Jan 2001
The only problem I've had with flashing templates is that they act as a very effective cooling fin for the wire. I guess the thing to do is block the template out from the blank so that cooled wire is not trying to cut. Of course this means different measurements.
Has anyone else dealt with this?
dang
dang is online now Find More Posts by dang
Old Jun 29, 2003, 09:39 AM
Alfred is offline
Find More Posts by Alfred
Alfred's Avatar
Perth
Joined Apr 2002
Dang
If you are making a highly tapered wing, the flashing template/heat sink works great, if it is used only on the smaller rib section. This way you do not burn the side with the short cut.
Alfred
Alfred is offline Find More Posts by Alfred
Old Jun 29, 2003, 02:11 PM
Joined Oct 2002
Using a "sawing" motion, where the bow is slowly moved from side to side as the cut is made, seems to eliminate any tearing problems at the template side.
However, it won't work with something like a Feather/Cut. In that case, formica seems to be the best way to go.
Old Jul 06, 2003, 11:07 PM
dang is online now
USA, WA, Olympia
Joined Jan 2001
Useful chatter guys.
dang
Old Jun 28, 2016, 10:11 AM
RotoTillerGuy is offline
Find More Posts by RotoTillerGuy
United States, CA, South El Monte
Joined Nov 2009
I use a CNC router to cut my custom Formica/Masonite Hotwire templates.
Phenolic is an even better material, but harder to find.
If anyone needs a set, $35.00 for two bottoms and two top templates, made of Formica.
RotoTillerGuy is offline Find More Posts by RotoTillerGuy
Old Jun 28, 2016, 10:57 AM
The_Builder is offline
Find More Posts by The_Builder
God Created me to Create
The_Builder's Avatar
Joined Nov 2009
I switched to G-10. It is brutal on blades but the templates are super durable and they come out pretty nice.
Definitely not a 5-10 minute project though
The_Builder is offline Find More Posts by The_Builder
Foam cutting templates NewbieX Foamies (Kits) 11 Jun 30, 2016 04:14 PM
Foam cutting templates - What material? tomlin Electric Plane Talk 14 Jun 28, 2016 09:55 AM
HOWTO:5 minutes to perfect foam cutting templates! FlightofSong Foamies (Kits) 3 Jun 29, 2003 02:15 PM
