Old Apr 29, 2015, 09:42 PM
gva1956 is online now
Find More Posts by gva1956
United States, WA, Goldendale
Joined Apr 2012
Question
CG for Sterling PT-17, 64" Wing Span, BARN FIND
Just got this old Sterling PT-17 from one of our local flyers who has had it hanging in his barn for the past 30 years. He is hoping we can get it to fly again,
The engine is already running great, I have replaced the old butterscotch 4 wire kraft servos. The tail feathers were warped but the covering shrunk tight and is so far keeping them straight.
What I am looking for now is if someone has the plans and can give me the correct CG location.
If she survives the test hop we will strip her down and recover her in the yellow and blue color scheme.
gva1956 is online now Find More Posts by gva1956
Old Apr 30, 2015, 07:16 AM
scale_only is offline
Find More Posts by scale_only
# Scale is a way of life
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
Nice find,,,
on the plans
http://www.outerzone.co.uk/plan_details.asp?ID=3704
good luck
scale_only is offline Find More Posts by scale_only
Old Apr 30, 2015, 09:40 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
If you get really turned on, Robart made functional oleos for that model. You would have to tear open the belly, and modify a bit, but it does work. I did mine.
LesUyeda is offline Find More Posts by LesUyeda
Old Apr 30, 2015, 10:37 AM
Joined Apr 2012
Again, Scale comes through, Thanks !
Great looking Stearman Les
Old Apr 30, 2015, 11:14 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Somebody will have the plan CG location, but actual location varies. A little nose heavy with tank empty is good advice for the maiden flight. Good tail-dragger technique is needed, be ready for pitch-up after lift off. A little right aileron up-trim and a little right rudder trim may help takeoff. Some up-elevator helps keep tail on ground for steering during start of takeoff, then let tail rise and steer with rudder during takeoff. Keep climb gradual at around 3/4 throttle. Forgive me if you already know all this.
E-Challenged is offline Find More Posts by E-Challenged
Old Apr 30, 2015, 11:51 AM
Joined Apr 2012
Any advice it welcomed.
All the flyers here want the re-maiden to go well.
Old Apr 30, 2015, 03:21 PM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
Gva: Thanks. Still got it hanging in my garage.
Got me to thinking, a lot. The reason I went to Robart for wheels, was that the stock Sterling were soooooo springy, I never knew which way the plane was going to go when I began to taxi for take off, and once it landed, the same was true. Hated it. Robart solved that problem.
Les
Old Apr 30, 2015, 05:40 PM
scale_only's Avatar
Joined Apr 2010
My Royal Stearman was the same way,, had to land it like an at-6,, a little power on wheel landing,, if you tried a flair landing it was 1 in 10 that stuck,, the other 9 were bouncy
happy to help,,
Old May 06, 2015, 05:56 AM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Man oh Man ! That is nice ! It just has that 'look' of an Antique...I can't imagine recovering it, unless it's absolutely necessary......
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: Airshows, and Tradition.
Old May 07, 2015, 08:59 AM
308jockey is offline
Find More Posts by 308jockey
Joined May 2011
I have this same question EXACTLY. I bought a 65" PT-17 at Perry this year. I'm unsure which kit it is but I'm ready to fly it. Got a radio in it, put an OS 91 4 stroke on it and now I need a CG for it. It balances right now 4.5" aft of the top wing leading edge. I'm thinking I need to move it forward to about 2.5", about 25% of the top wing chord. Is that at least a safe starting point? This plane appears to be several years old but was quite well built and has never been flown. I'm going to test run the motor today and fly it tomorrow if all goes well. Looking forward to flying it at our warbird event in a few weeks. Any help on this CG location will be appreciated. Thanks.
Rick H.
308jockey is offline Find More Posts by 308jockey
Old May 07, 2015, 09:05 AM
Joined May 2011
Les if you don't mind, which radial is that you have around that OS? It's one of the last things I need to finish this and that installation is very nice. I'm going to wait until I know it flies before getting one but will need to make a decision soon on it. Thanks.
Rick H.
Old May 07, 2015, 09:06 AM
scale_only's Avatar
Joined Apr 2010
Again, the plan shows it,, it's more like 55% at the top wing,, 25% will be very nose heavy
http://www.outerzone.co.uk/download_...an.asp?ID=3704
good luck
Old May 07, 2015, 09:33 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
I took a bunch of Williams Brothers parts, and fabricated to fit. Cost more that it would have to put a two stroke engine in the plane:-)))))) But this looked a lot better.
Les
Old May 07, 2015, 03:28 PM
epoxyearl's Avatar
Joined Oct 2011
Guys- for most straight wing bipes-measure from the LEADING edge of the top wing, to the TRAILING of the bottom one.- Fuselage level, vertical lines drawn to the surface of the work bench... Treat that total length as your wing "Chord" and then 25% will be a nose heavy 'safe' starting point.
Old May 07, 2015, 03:36 PM
Joined Apr 2012
I also like that antique look on this plane but the covering is so brittle, I have already poked a hole in it. Plans are to test fly it this weekend.
This plane did come with a large piece of lead on the firewall but I still wanted to confirm it was enough.
What I have done was look at the Great Planes PT-17 with a 71" wing span and found their CG to be 5 1/2" back from the leading edge of the top wing.
I decided to look at 5 1/4" for this one and she was spot on with an empty tank.
I did add 4 oz to the firewall for good measure.
Discussion Sterling PT-17 64 inch northernlightsfl Control Line 1 May 12, 2014 05:49 PM
Sold Sterling PT-17 Kadet 64" span NIB $250 sagomon Aircraft - Fuel - Airplanes (FS/W) 4 Feb 23, 2014 04:24 PM
Sold Sterling PT-17 Kadet 64" span NIB $250 sagomon Aircraft - Fuel - Airplanes (FS/W) 2 Feb 17, 2014 04:24 PM
For Sale Sterling PT-17 Kadet 64" span NIB $250 sagomon Aircraft - Fuel - Airplanes (FS/W) 0 Nov 29, 2013 06:31 AM
For Sale Sterling PT-17 Kadet 64" span NIB $250 sagomon Aircraft - Fuel - Airplanes (FS/W) 0 Sep 08, 2013 02:46 PM
