Old Aug 11, 2015, 05:38 PM
TomC is online now
Find More Posts by TomC
Gold Coast Coolangata, Australia
Joined Nov 2003
Originally Posted by Rickochet View Post
I was thinking about converting an old original ES to a water plane. Seems like I remember someone putting one on floats. I was thinking more like adding some sponsons and maybe some more foam to the belly.
Any thoughts on this other than "get a float plane?" I did a search and came up with nothing.
Maybe use the float kit off the new multiplex shark;
RR version;
http://www.worldhobbies.com/product/MPX264286_item.html
Optional Floats;
http://www.worldhobbies.com/product/MPX224328_item.html
TomC is online now Find More Posts by TomC
Old Aug 12, 2015, 02:52 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
What's the span of this shark? I could not see it mentioned on that link.
Found it. 1070mm. Not very big.
Flypoppa is offline Find More Posts by Flypoppa
Old Aug 12, 2015, 03:19 AM
TomC is online now
Joined Nov 2003
~ the same weight with recommended 3s1300 so should work ok. No big deal since you are probably not going to do this anyway, lol!
Old Aug 12, 2015, 04:58 AM
KristofferR is offline
Find More Posts by KristofferR
Sweden, Västra Götaland County, Gothenburg
Joined May 2015
Flaperons?
I got myself a used DX6i which is an upgrade from the Smart SX in the RTF kit. Already have the ailerons on my EZ*2.
Contribution:
Naturally, I tried to use flaperons for fun. It did not work very well. I started big, about 8 mm deflection. Then added a LOT of down elevator mix, 2-3 mm.
Switching the toggle the plane would halt/pop in the air and then start diving. I landed and changed the elevator setting and after a while realized it seemed not to need that much. The aileron response was of course non existent so all turns had to be done with rudder.
The plane would not fly "nice" - hard to explain - it was kind of sinking flat which sounds good in theory but the feeling was more "broken" than "flying".
Eventually the end result was that I decreased and decreased the flap throws until what remained was a smidge of "Flap" more akin to the "thermal" setting on DLG/Thermal/etc planes that uses many flight modes and that was pretty nice.
Toggling the switch there is a visible "brake" and "acceleration" effect but thats it and it flies more or less like normal (did not try any advanced stuff).
Has anyone else experimented or been more successful? (I searched a bit but did not find much)
If I go the Flap route again I would probably try something like FunCub hinges and cut separate flaps but then again I probably would not be bothered. It would help perhaps when landing in really tight places though and I like to fly slow.
KristofferR is offline Find More Posts by KristofferR
Old Aug 12, 2015, 08:30 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
RR version;
Optional Floats;
Great idea. That actually might work along with some sponsons under the wings. I have seen the Shark parts on Amazon as well.
Rickochet is offline Find More Posts by Rickochet
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
