Old Jul 05, 2011, 07:49 AM
planex is offline
Find More Posts by planex
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Ailerons to Easystar Phoenix 2.5
I'm wanting to add ailerons to the Easystar on my Phoenix 2.5, I've read about it being done but am having trouble
If someone could provide step by step details on how to add them it would be much appreciated
planex is offline Find More Posts by planex
Old Jul 06, 2011, 02:30 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
I used the instructions from Phoque.
Steps: (Or... If you are lazy, and just want to use my moddified variant, I've attached it below.)
1. Create an EasyStar Variant called "Aileron".
2. Under "Control Surfaces" change "Minimum Aileron Travel" degree to 35* (or what ever you prefer.)
3. Change "Maximum Aileron Travel" to 35*
4. At the bottom, unmark the "Swap Rudder --> Aileron Channel".
5. Follow Planex's instructions.
Originally Posted by Planex
  1. Open file C:\Users\Yourname\Documents\PhoenixRC\Variants\fix edWing\easystar_Aileron.pxv (the file may be named slightly different).
  2. Scroll all the way down
  3. Add the following, right before "end":
The .pxv file can be opened with MS Notepad.
After copying and pasting the code (below) to the easystar_Aileron.pxv right before "end", make sure to save the moddified file without changing the file name.
Code:
newObjectType.controlSurfaces ={
	"elevator", "__helper_e1","__helper_e2","__helper_e3", "elevator",
	"rudder", "__helper_r1","__helper_r2","__helper_r3", "rudder",
	"left_aileron", "__helper_la1","__helper_la2","__helper_la3", "left_aileron",
	"right_aileron", "__helper_ra1","__helper_ra2","__helper_ra3", "right_aileron",
When copying the above code, make sure to include the last character, "}".
6. In the Phoenix Sim, select the variant "Aileron" under EasyStar.... and fly!
7. I also increased the Brushless Thrust to 1.8, increased Rudder and Elevator throw*
8. Remember, every time the aileron variant is edited, the "easystar_Aileron.pxv" file has to be modded with the above code and saved again.
KC
Edit: WOW! The the aileron modded EasyStar is a totally different plane! It is so much better than just rudder/elevator. A really big thanks, Phoque!
KC is offline Find More Posts by KC
Old Jul 06, 2011, 03:58 AM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
Here is a quick demo flight of the (above) EasyStar Aileron Variant. Please excuse the flying (skill) .
KC
Old Jul 06, 2011, 03:59 AM
planex is offline
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Thanks heaps
I tried the exact same thing but it just wouldn't work. I used your file instead and it worked perfect, much appreciated
So much better to fly with ailerons, feels like my bixler now just a lot more agile
Old Jul 06, 2011, 04:04 AM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
NP! I wouldn't have known this could be done if you hadn't started this thread!
KC
Old Jul 06, 2011, 04:05 AM
planex is offline
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Man its so good to fly this thing with ailerons, next time I go to the park I'm really going to give my Bixler a thrashing!!
Old Jul 06, 2011, 04:18 AM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
What's this Bixler you speak of? Now I wish I had a plane that flies as nice as the EasyStar with the ailerons in the sim.
Edit: Ahhh I found a vid.
Flite Test - The Bixler - REVIEW (8 min 38 sec)
Old Jul 06, 2011, 05:46 AM
planex is offline
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Thats the one man, can get it from hobbyking for very cheap
http://www.rcgroups.com/forums/showthread.php?t=1231310
Huge thread about it and its original design, the Sky Surfer
Old Apr 13, 2012, 03:18 PM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
Doesnt work with Phoenix 4 beta. Anyone knows how to fix it?
RoboSerg is offline Find More Posts by RoboSerg
Old May 21, 2012, 02:46 PM
pascalp is offline
Find More Posts by pascalp
Joined Mar 2008
With Phoenix 4.0k
Modifying a stock brushless easystar then applying Phoque's instructions to the "whatevername.pxv" give a working plane.
Remenber that you have to apply instructions each time that you click "end" in the modification panel.
I did it yesterday ! I'm waiting for an Easystar II and the modded model (even not perfect) is better for training.
I hope that someday, the new Easystar II will show-up in Phoenix.
pascalp is offline Find More Posts by pascalp
Old May 26, 2012, 07:33 PM
Roblister is offline
Find More Posts by Roblister
North West UK
Joined Nov 2010
Don't hold your breath
Roblister is offline Find More Posts by Roblister
Old Dec 16, 2012, 10:54 AM
jano101 is offline
Find More Posts by jano101
jano101's Avatar
Slovakia, Trencin
Joined Jun 2012
to:KC
Please the order: I do whatever I do I but wings does not start up
I tried other tutorials
if you give your recording EasyStar_Aileron_Variant.pxr should be displayed so beautifully that they go wings
But not me, I tried to throw the rudder / aileron but still nothing
but I have version 4 .0.m Phoenix RC
jano101 is offline Find More Posts by jano101
Old Sep 12, 2013, 04:50 AM
mvd1968 is offline
Find More Posts by mvd1968
The Netherlands, NH, Nieuw-Vennep
Joined Sep 2013
bixler with flaps
Hi sorry for bumping this old thread
Has anyone yet made the bixler for Phoenix or realflight?
I am looking for a model that can be compared with the bixler and that i can fly in Phoenix and/or Realflight WITH airelons AND flaps.
Thanks guys!
mvd1968 is offline Find More Posts by mvd1968
Old Dec 05, 2013, 02:29 PM
Stickeh is offline
Find More Posts by Stickeh
Canada, BC, Whistler
Joined Jan 2005
Thanks guys!
http://www.rcgroups.com/forums/showt...x#post26228848
Stickeh is offline Find More Posts by Stickeh
Old Mar 07, 2014, 06:11 PM
1eleven is offline
Find More Posts by 1eleven
Still learnin'
United States, GA, Alpharetta
Joined Feb 2013
Bringing up an old thread probably, but I am trying ot get a model that is very similar to the Bixler 2 flying characteristics. Phoenix RC is now up to 5.0.i and the previous variants are no longer valid. I started with a base Easystar model and added Ailerons in the Model edit mode with values that "looked" right on the model representation.
Has anyone else done this and flown a Bixler2 to know that the "feel" is right? I even added some downward thrust angle on the prop to be more realistic.
Edit: Adding my variant in case anyone wants to test it.
1eleven is offline Find More Posts by 1eleven
Question Phoenix 2.5 Kaw1000 Simulators 10 Apr 26, 2011 12:39 PM
For Sale New Omega 2.5 Electric Flaps Ailerons HITEC SERVOSCarbon Kevlar Fuse Unpainted bipe22 Aircraft - Sailplanes (FS/W) 0 Aug 01, 2008 01:47 PM
Question Anyone's 2.5 Thermic improved with reflex on the ailerons? T Z Thermal 0 Sep 26, 2007 09:01 AM
Help! 5 ch RX + Futaba 9c Super + 2 servo ailerons paulobao Hand Launch 10 Mar 12, 2007 04:22 AM
Pics of T-52 w/ 2.5:1 GB, mag mayhem & flat wing w/ ailerons The Other Dave Foamies (Kits) 11 Aug 05, 2002 06:39 PM
