Old Nov 26, 2014, 05:03 PM
CUBANO8 is offline
Find More Posts by CUBANO8
Joined Oct 2003
Build Log
Scale Build-off 4: FW-190 60" plans by Tony Nijhuis
Greetings, I would like to start a build log on the FW-190 60"wingspan offered by Tony Nijhuis. I first saw this plane in an Autumn 2011 issue of R/C model Aeroplane special edition. The free plans of the FW-190 were included in the magazine. I bought it, and decided to build it. Since I didn't want to use the plans in the magazine I ordered another set, including the canopy, cowling, and turtle deck (gun hood).
Tony Nijhuis web page:
http://www.tonynijhuisdesigns.co.uk/
Its been a while since I had these items on hand, and now I have decided to start it. I also was debating on purchasing the CNC pack & wood pack, but I thought that I needed a good challenge, and elected to cut them myself.
Sam
CUBANO8 is offline Find More Posts by CUBANO8
Old Nov 26, 2014, 05:12 PM
CUBANO8 is offline
Joined Oct 2003
Plans, Canopy, Turtle deck, and Cowling
Here is the picture of the R/C Aeroplane Autumn 2011 edition, and also pictures of the Plans, Canopy, Turtle deck(Gun Hood), and Cowling.
Old Nov 26, 2014, 05:16 PM
CUBANO8 is offline
Joined Oct 2003
Wing Ribs
The wing ribs are made from 3/32 balsa sheet. I first made a template of each rib from clear plastic, then used the template to trace out the ribs onto the 3/32 balsa sheet.
Old Nov 26, 2014, 05:27 PM
CUBANO8 is offline
Joined Oct 2003
Right wing build
After completing all the ribs, I decided to begin the construction of the right wing. I assembled the ribs unto their position, using two 1/4" by 1/4" balsa stick spars. I also needed to make a dihedral brace shown in the plans to get the correct angle of W1.
Old Nov 26, 2014, 05:30 PM
CUBANO8 is offline
Joined Oct 2003
B1 & B2 Joiner, and webbing
B1 & B2 Wing joiner, and the webbing were glued in place.
Old Nov 26, 2014, 05:41 PM
CUBANO8 is offline
Joined Oct 2003
Top wing sheeting
The sheeting I will be using will be 3/32 balsa. I have a difficult time with the 1/16 sheeting recommended in the plans, only because I have a bad habit of making holes easily. I don't have a tender grip.
I edged glued four 3/32 balsa sheets to make up for the right top wing. I aligned it, and made the rib marking on them, this made it easy to pin the top sheet in place.
This is where I am with the build. After the top sheeting is glued in I will remove it from the build table so I can start on the left wing. Long weekend, so I'm hoping to get some more work on the FW-190 in between turkey, football, and family.
Happy Thanksgiving,
Sam
Old Nov 26, 2014, 05:44 PM
baldguy is offline
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
I was thinking of this one too. But I was going to substitute the 3/32 ribs for 1/16, as well as the sheeting. If it works good for Brian Taylor's bigger Hurricane, it would work for this one too. And it would be lighter to boot. Still might do it someday, but I got too many WW Once models ahead of it.
baldguy is offline Find More Posts by baldguy
Old Nov 26, 2014, 05:49 PM
CUBANO8 is offline
Joined Oct 2003
I know what your saying, trust me I wasn't thinking of this one yet myself, but the garage area is cold, even with the portable heaters, cold creeps in, but inside the home its warm. I like warm, and the wife doesn't mind
Old Nov 27, 2014, 02:59 AM
_AL_ is offline
Find More Posts by _AL_
Australia, NSW, Hornsby
Joined Jul 2005
Very nice.
Subscribed
Al
_AL_ is offline Find More Posts by _AL_
Old Nov 27, 2014, 06:53 AM View Post
quohiloes
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Nov 27, 2014, 05:07 PM
CUBANO8 is offline
Joined Oct 2003
Left Wing
Now that the right wing top sheeting has dried and the ribs are locked in place, I removed it from the building table, and started on the left wing. This was the same procedure as the right wing as the pictures show. I ran out of wood, and CA glue, so a trip to the hobby store is in the plans for tomorrow.
I'm thinking of a retract option now. I have a set of Robart electric retracts, but the length of the strut is just a tad short, and it is 85 degree. I was also looking at the 74 degree retracts offered by LADO, although a bit pricey, they do have the strut option which does have the length needed, and they look nice. The other option is going with Spring Air 709's which are 74 degrees, and oleo strut ready.
Will have to decide, and order soon before completing the wing.
'till next time,
Sam
Old Nov 27, 2014, 07:50 PM
baldguy is offline
I eat glue
Joined Jul 2006
I do believe Tony used the Eflite 120 retract set.
Old Nov 27, 2014, 09:51 PM
CUBANO8 is offline
Joined Oct 2003
I believe he did to. I have the equivalent 120 Robart type electric retract with shorter struts. I could buy or make a longer strut, but I want to try to use something in 74 degree first. I know Eflite has a 74 degree retracts, but for a lighter plane(foam). I might start out with Spring Air 709's.
Old Nov 29, 2014, 09:37 PM
RAFster is offline
Find More Posts by RAFster
United States, TN, Blountville
Joined Oct 2002
How can increasing the thickness of the sheeting and ribs to 1/32 thicker end up with a lighter plane? They might be stronger but they generally are not lighter.
RAFster is offline Find More Posts by RAFster
Old Nov 29, 2014, 09:49 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Because he is decreasing the thickness by 1/32". Going down from 3/32" to 1/16".
Chad Veich is offline Find More Posts by Chad Veich
Build Log Scale Build-Off 4 Kit built 60" AC-130 by Pat Tritle campbelltf Scale Kit/Scratch Built 86 May 03, 2015 08:32 PM
Build Log Scale Build-Off 4 Plans built RV-3 cbalgra Scale Kit/Scratch Built 35 Apr 19, 2015 02:38 PM
Video De Havilland 100 FB9 Vampire Plan by Tony Nijhuis coverted to schubeler EDF 1-rc-flyer Large EDF Jets 10 Apr 13, 2015 04:59 AM
Build Log Scale Build-Off 4 Plans built 64" Cessna UC-78, T-50 Bobcat campbelltf Scale Kit/Scratch Built 42 Jan 20, 2015 10:47 PM
Contest Scale Build Off 3: 30" Stick and Tissue FW-190 bosley Scale Kit/Scratch Built 40 Jun 07, 2014 03:17 PM
