Old Jan 24, 2015, 10:06 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Rewind iPower GBM4114-120TGimbal Brushless Motor
I have this motor, which was sent me a gift, along with others for Jack. (Thanks a lot)
It comes without wire and according to their tread:
http://www.rcgroups.com/forums/showthread.php?t=1922512
Has 120Turns, Delta to 29.64 Kv.
This motor can be wired with 18 turns delta HP AaAaBbBbCcCc 23.5 AWG wire.
For this I occupy six wires 108 inches.
That according to TC 7.1 (not yet available)
give me a Kv of: 395, Rm 68.3 milliohms.
Once completed, the measured Rm was 61milliohms
Delta Termination
For Delta termination:
Start A (Red) - End B (blue),
Start B (Blue)- End C (green),
Start C (Green)-End A (red)
manuel v is offline Find More Posts by manuel v
Old Jan 25, 2015, 12:32 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
jackerbes's Avatar
USA, ME, Ellsworth
Joined May 2008
Nice work, Manuel!
The original motor weighed 140g with the arms well filled, I think you will have a similar weight there. So you should have a nice motor there.
I think it will good for at least 450W continuous. What prop will you test that with? I have some of the iFlight T-Style props, do you want some of of those for testing?
T-style Carbon Fiber Prop - http://www.iflight-rc.com/iflight-t-...w-ccw-set.html
It is not real clear but the prices there are for one pair of props, one each CW and CCW.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 25, 2015, 01:53 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Thanks jack.
I have 16x5.5, 15x5, 14x4.7, 4,5,6slipo.
Regular APCe prop. 15x4, 15x8,
I believe that this is more than enough.
Thank you very much.
I hope that works well in the range of 450 watts.
Old Jan 25, 2015, 02:25 PM
Jack
jackerbes's Avatar
USA, ME, Ellsworth
Joined May 2008
And do you have a prop adapter for that motor too? I think that motor has the four holes in a 12 x 12mm square pattern, right?
If you need a longer shaft so that you can have a stub shaft to locate the T-Style props on let me know, I can send you one.
Jack
Old Jan 25, 2015, 03:04 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Jack.
remember, you send me other complete motor and one 4108.
I think, i have one adapter.
But I'll check.
Thanks very mush.
Actually not that you can use this motor. possibly build you a big foamy J3 60 in stile.
Manuel V.
Old Jan 27, 2015, 09:22 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Final weight:
net weight = 162.1g
with spinner= 174.3.
First test data.
no load. .53A, 12V, 5000, 416Kv/v
IF CF 14x4.7, 5s= 17.13A, 17.92V, 6240rpm, 306W,
IF CF 14x4.7, 6s= 24.16A, 22V, 7431 rpm, 531W, 80.4%NLS.
APCe 15x8, 5s= 21.19A, 17.66V, 5941 rpm, 374W.
APCe 15x8, 6s= 30.94A, 21.74V, 6939 rpm, 672W, 76%NLS. ( Over 3.5Kg thrust, in Drive calculator)
IF CF, DJI style 15x5, 5s= 20.23A, 18.5V, 6400 rpm, 374 W.
to 50% throttle. = 2.94A, 19.45V, 3400 rpm.
Motor warm all the way. below 100 F.
Old Jan 28, 2015, 04:21 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
More test.
iCF CF 15 x 5 DJI.
5slipo.
2823 rpm, 1.87A, 21.15V, 39W. Aprox 500g, 12.83 g/W
3178 rpm, 2.54A, 21.08V, 49W, Aprox 600g, 12.24 g/W
3456 rpm, 3.02A, 21.02V, 65W, Aprox 700g, 10.76 g/W
3751 rpm, 3.87A, 20.95V, 81W, Aprox 800g, 9.87g/W
3901 rpm, 4.11A, 20.87V, 86W, Aprox 900g, 10.466 g/W.
4118 rpm, 5.02A, 20.77V, 104.26W, Aprox 1000g, 9.59 g/W.
Full throttle.
6571 rpm, 21.01A, 19.4V, 406W, Aprox 2547g, 6.27 g/W.
iCF CF 16 x 5.5 Dragon Fly
5slipo.
3178 rpm, 3.08A, 19.95V, 61W.
3396 rpm, 3.57A, 19.87V, 71W,
3551 rpm, 3.99A, 19.80V, 79W, 1/2 throttle.
Full Throttle.
6327 rpm, 23.13A, 18.96V, 438W, 92.3F.
Old Jan 28, 2015, 09:02 PM
crackup007 is offline
Find More Posts by crackup007
Israel Montoya
crackup007's Avatar
Joined Jan 2007
Originally Posted by manuel v View Post
Final weight:
net weight = 162.1g
First test data.
Beautiful! Manuel Good work!
crackup007 is offline Find More Posts by crackup007
Old Jan 29, 2015, 06:43 AM
Jack
jackerbes's Avatar
USA, ME, Ellsworth
Joined May 2008
That looks like a winner for sure. Are you going to fly it on something? You don't have enough of them for a multi do you? That might make a good motor for those big mapping multi that they are discussion here:
Ultimate mapping quad! - http://www.rcgroups.com/forums/showthread.php?t=1982044
Those are all focused on long duration and low energy flight and the best platforms are the ones that use bigger props at lower RPM to keep the power use down. I think, in general, they are over propping the motors to get the best duration. And you motor looks like it could handle more prop down around half throttle.
This is a two part motor right? And it is wound to this scheme?
AaAabBbBCcCc/aAaABbBbcCcC
If you look at that in the winding scheme calculator the winding factor is very good at 0.94947. You can copy and paste the scheme in in the Advanced mode and enter 22 poles to see that.
Jack
Old Jan 29, 2015, 11:46 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Thanks Crackup007.
Yes Jack this is the scheme.
Im going to try in Airplane.
comparing a stock motor vs rewinding.
Discussion rewind iPower iPM2212-920Kv. manuel v Electric Motor Design and Construction 5 Dec 21, 2014 10:19 PM
For Sale Brushless gimbal carbon fiber motor complete set(roll, pitch, yaw) GBM4114-100T CopterVu Non R/C Items (FS/W) 1 Aug 22, 2014 04:23 AM
For Sale Brushless gimbal motors (ipower gbm4114-120t) BIGTACO Aircraft - Electric - Multirotor (FS/W) 0 Jun 03, 2014 11:05 PM
For Sale Gbm4114-120t brushless gimbal motors BIGTACO Aircraft - Electric - Multirotor (FS/W) 0 Jan 26, 2014 08:09 AM
Mini-Review iPower GBM4114-120TGimbal Brushless Motor jackerbes Multirotor Talk 6 Jul 17, 2013 01:36 PM
