Old Today, 12:19 PM
Roger Wilkes
United Kingdom, Portsmouth
Joined Dec 2012
Help!
Spectrum DX7s - AR6100 dual aileron and flap setup
Can anyone expand on how to set a 6100 up,I have managed to get the ailerons functioning in unison,but the rates and flaps are not correct.
I have used a DX7 for 10 years,after a break of 18 months I have started using the DX7s SO different and manual most unhelpful (Age is also a cause 58).
Would appreciate some direction to FULLY understand the DX7s.
Regards
Roger Wilkes
Roger Wilkes is online now Find More Posts by Roger Wilkes
Old Today, 12:26 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Start by going in the wing type menu and selecting the proper wing type.
Two Aileron One Flap.
Follow the servo monitor for proper servo connections.
This will enable the flap menu and once you assigned a switch the rest should be easy to follow.
freechip is online now Find More Posts by freechip
Question How to program a dual aileron / dual flap with DX9 trasher_can Sailplane Talk 8 Nov 14, 2014 02:14 PM
Discussion DX7 Dual Flap Servos, Dual Aileron Servos, Dual Elevator Servos dickbeep Radios 5 Nov 13, 2014 05:04 PM
Discussion DX8 flap setup Funcub with 1 aileron and 2 flap channels ham Electric Plane Talk 3 Aug 15, 2014 06:44 AM
Question Dx7 Ar6200 Dual Flaps and Ailerons, How to get Aux1 to work properly. Timws Sailplane Talk 6 Jan 31, 2012 03:49 AM
Discussion DX7-Dual Elevator/Dual Aileron Setup Jimws Fuel Plane Talk 2 May 23, 2011 12:09 AM
