Old May 22, 2016, 02:34 AM
Hummina is offline
Find More Posts by Hummina
Joined Jul 2014
Figure erpm?
For a 12'tooth and 14 magnet motor. How do u do it ?
Hummina is offline Find More Posts by Hummina
Old May 22, 2016, 05:16 PM
Hummina is offline
Joined Jul 2014
Rpm x magnet pairs. So rpm x 7
Old May 22, 2016, 08:22 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What is erpm?
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 22, 2016, 08:34 PM
Hummina is offline
Joined Jul 2014
Electrical revs per minute. How many comutations the esc does per motor rev I think.
Old May 22, 2016, 09:22 PM
Jack
USA, ME, Ellsworth
Joined May 2008
That is what we also call cogging steps I think, you can get those from the Winding Scheme Calculator here:
http://www.bavaria-direct.co.za/scheme/calculator/
For a 12N14P motor it is 84 cogging steps.
Jack
Old May 23, 2016, 12:09 AM
learningrc is offline
Find More Posts by learningrc
Joined Feb 2015
1 mechanical revolution is how far a rotor turns in order to get back into the physically identical position it started in. This is always 360 degrees.
1 electrical revolution is how far a rotor turns in order for it to get back into the magnetically identical position it started in. If there are only 2 poles on the motor, then the rotor will make a 360 degree rotation before the north and south poles are in the same position they started in. If there are 4 poles then the rotor will be magnetically in the same position after only 180 degrees. If there are 6 poles, then it will be 120 degrees and if there are 8 poles, then it will be 90 degrees.
This means the electrical RPM's is always the number of pole pairs times the mechanical RPM's.
Note that this is different than the number of commutations per rev and different than the number of cogging steps. In a "6 step" (trapezoidal) control, there are always 6 commutation steps per electrical revolution. And the number of cogging steps depends not only on the number of magnetic poles but also on the number of stator teeth.
learningrc is offline Find More Posts by learningrc
Old May 23, 2016, 12:25 AM
Hummina is offline
Joined Jul 2014
So for our 12x14 motors one rpm is 7 erpm.
Old May 23, 2016, 08:26 PM
Joined Feb 2015
Yes, that's correct.
Discussion Help me figure out this NeilsonOrlov Car Talk 5 Nov 11, 2015 07:38 PM
Discussion GPS Help, I cant figure this out ee0u30eb Multirotor Talk 5 Sep 22, 2015 03:40 AM
For Sale Akira anime figures - McFarlane Toys - early 2000s craab Non R/C Items (FS/W) 0 Sep 17, 2015 03:43 PM
Gallery Pilot figures-Painting Pilot figures-Toys adapted for pilots -Show us what you got pecanpatch Painting and Finishing Tips 49 Jul 30, 2015 03:48 AM
