Old Oct 12, 2015, 09:12 AM
FlightIdle is offline
Find More Posts by FlightIdle
if it flies....
Australia, VIC, Melbourne
Joined Apr 2011
Gasser fuel tank setup
Hi,
Is the fuel tank level (relative to the carby) important on a 50cc gasser? I got hold of an el cheapo edge 540 kit in a swap deal and the instructions don't mention tank installation at all and if mounted it on the floor of the model would be approx 2" below the carby level. I had previously owned an Extra 260 which from memory had the tank and the carby at the same level which prompts me to ask the question.
Any advice appreciated.
FlightIdle is offline Find More Posts by FlightIdle
Old Oct 12, 2015, 10:24 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Nope, the carb on a gasser is different than glow. Gassers carbs are pumped. Plus you can run a t fitting one end to the carb the other to the tank. When you fuel you won't flood the engine.
Remember you need tygon fuel lines, a tank stopper for gas. And a vent line to the outside of the aircraft
jetmech05 is offline Find More Posts by jetmech05
Old Oct 12, 2015, 10:50 AM
Jacksonville Fla.
Joined Mar 2007
Forgot to mention the vent line exits the tank runs on top of the tank makes a loop then exits the aircraft
Old Oct 14, 2015, 08:00 AM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
Maybe worth mention as well, is the location of the tank, because we have a pretty effective fuel pump, can be on or near the plane's CG. This make a lot of room in front available, as well as no more concern regarding in flight CG changes as the fuel is burned off.
ahicks is offline Find More Posts by ahicks
Old Oct 14, 2015, 09:17 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Here's how I set mine up.
I also filter the fuel coming out of my jug.
grosbeak is offline Find More Posts by grosbeak
Old Oct 14, 2015, 01:33 PM
exf3bguy is offline
Find More Posts by exf3bguy
United States, CA, Sacramento
Joined Oct 2011
Textbook setup pictured above. While the location is not super critical the height does have some small affect. I always mount my tank above the carb. Two reasons for this, first it makes it much easier to draw fuel to the carb on that initial start and all following first starts of the day if you like to drain the tank after a flying session. Secondly most gassers will go slightly rich when inverted. While inverted my tank is now below the carb and helps slightly with keeping the mixture consistant.
exf3bguy is offline Find More Posts by exf3bguy
Reply With Quote  (Disabled)
Old Nov 12, 2015, 11:47 AM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Most gas engines have Walbro pumping carburetors, and it doesn't matter where you place the tank (up-down, near or far from the engine).
Saito FG 4-cycle engines DON'T have this type of pumping carb, nor the OS 15cc engines. Stick with engines that have Walbro pumping carbs, and you will have no fuel feed problems.
wuest3141 is offline Find More Posts by wuest3141
Help! Gasser Tank/Smoke Setup trailmixhawkeye Fuel Plane Talk 2 Oct 02, 2015 10:38 AM
Sold 11 Glow fuel tanks, 5 new and 6 used. Tank stoppers and misc fuel line. $15 shipped jl33fr33 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 29, 2014 04:06 PM
For Sale Fuel Tank Assy/ Air Tube for Fuel Tank (New) - Worldwide FILLIPEAMP2 Aircraft - General - Miscellaneous (FS/W) 0 Apr 08, 2014 07:09 PM
Discussion Best fuel tank system (proof) The search for the best performing tank setups schusterjo Fuel Plane Talk 414 Aug 29, 2012 12:19 PM
Question "Gasser" fuel tank,plumbing how to??? HELIRLC Beginner Training Area (Fuel) 7 Aug 21, 2007 12:54 PM
