Old Dec 15, 2010, 02:46 AM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Build Log
Lockheed L-1011 ANA+L-1011-500 Panam EDF Foamies
With the A300 comming close to completion I thought I'd treat myself to a Christmas gift in the form of 2 EDF jets, one ANA l-1011 in 1970's mohican Livery and one L-1011-500 in Panam livery, even though I'm building for other poeple dosn't mean I have to stop building for myself,no way!
ANA L-1011 breakdown:
Lenght 84"
Wingspan 75"
weight 8-10 LBS
Powerplant 3 90mm HET Typhoon EDF's
3 75AMP ESC's
7-9 Mini Metal gear servos
3 18.5 22oo mah 40c lipo batteries
fixed gears then retacts after the maiden
will have flaps
Panam L-1011-500 breakdown
dimensions pending same tail, same fuselage diameter but longer wingspan & shorter fuselage
Powerplant 2 90mm EDF's
2 18.5 2200 MAh 40C lipos
wieght 7-8 lbs
7-9 metal gear mini servos
will have flaps
fixed gear removed & replaced with retracts after maiden flights
demondriver is online now Find More Posts by demondriver
Old Dec 15, 2010, 12:03 PM
Up-Out-&-Gone
Joined Mar 2007
I've started making the L-1011's plans I will add the L-1011-500's plans onto the standand 1011 as well. Don't worry Rookie2008 I woln't start construction untill I finish your A300!
Latest blog entry: 4-Years in the Making!
Old Dec 15, 2010, 05:13 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
your not going to have a house to live in soon...
foam and tape is offline Find More Posts by foam and tape
Old Dec 15, 2010, 05:29 PM
Up-Out-&-Gone
Joined Mar 2007
F&T you mean I woln't have a hangar to live in right?
Old Dec 15, 2010, 06:10 PM
Up-Out-&-Gone
Joined Mar 2007
As with all my airliner builds I buy a plastic or cast metal model of the plane I'm building this is a 1/200 scale hasegawa L-1011.
Old Dec 15, 2010, 07:16 PM
Broken Bottle is offline
Find More Posts by Broken Bottle
Broken Bottle's Avatar
Joined Sep 2007
I'm annoyed I giggled when I saw the title to this thread. I'm glad you're doing a Japanese airliner(I know you're not going the Japanese paint, but still) this time.
I think I'm going to enjoy watching this one come together more than the others.
Broken Bottle is offline Find More Posts by Broken Bottle
Old Dec 15, 2010, 07:35 PM
Up-Out-&-Gone
Joined Mar 2007
Thankyou my friend!
Old Dec 15, 2010, 07:43 PM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
DD, I don't know the rationale behind fixed gear on maiden vs retracts, can you elaborate?
ruff1 is offline Find More Posts by ruff1
Old Dec 15, 2010, 08:36 PM
Up-Out-&-Gone
Joined Mar 2007
Ohh that's easy it's called $190-200.oo bucks for servoless retracts, thats my rationale Ruff1. If I had the money I'd put retracts on all my jets, I'd rather buy EDf's than retracts.
Old Dec 15, 2010, 09:03 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Yikes, didn't realize they cost that much. I guess with the "heavies" you build you better have something substantial...
Old Dec 15, 2010, 09:08 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
What sort of flight times do you expect? I'm assuming you get scale performance or maybe just a bit more?
Old Dec 15, 2010, 10:14 PM
Up-Out-&-Gone
Joined Mar 2007
I wish it was warmer here in Chaelston SC Ruff, I can't belive I'm saying that! then I would have flown my One eleven again, but I hope to get 4-8 mins of flight time depending on throttle usage, as for performance the L-1011 will weight in at 8-10 lbs with 15lbs of thrust on the L-1011-200 & 12lbs of thrust on the L-1011-500 "shorter fuselage" & it will not have a tail EDF but it will be 3 EDF ready like the 1011-200.
Old Dec 16, 2010, 04:21 AM
plane_spotter is offline
Find More Posts by plane_spotter
plane_spotter's Avatar
United Kingdom, Wrexham
Joined Jun 2004
Another exciting build subject. Have watched all your airliner threads. I take my hat off to you for your skill and determination. On a personal note, my father worked in Saudi Arabia for several years when I was a kid and I frequently flew on Tristars back and to from the UK. Have a look at my Flight Sim screenshot, ah the memories. Saudia livery, climbing out of Jeddah International 1982. This thread certainly takes me back.
Description:
The Tristar was a brilliant wide bodied jet.
Best of luck with your project.
Ash
plane_spotter is offline Find More Posts by plane_spotter
Old Dec 16, 2010, 12:09 PM
Up-Out-&-Gone
Joined Mar 2007
Attachment 3664246
Ash
Thankyou Ash! It's builders like you that give me the encouragement to build the best jet Airliners I can.
Old Dec 16, 2010, 06:41 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Thanks DD... I think your build threads give us a great idea of how to go about this. I have wanted to build an EDF airliner, but that may be a few years off.
Are you or have you considered some kind of "large build" ebook?
For Sale Lanier Laser 200 1/3 scale Giant Zenoah G62 $500 nutzaboutharleys Aircraft - Fuel - Airplanes (FS/W) 1 Dec 08, 2010 12:04 PM
Sold Sapac L-39 RXR Foam EDF richh73 Aircraft - Electric - Jets (FS/W) 3 Nov 18, 2010 06:25 PM
For Sale L-39 Complete Composite Tooling for 70 MM EDF - Serious Buyers Only LJE4357 Aircraft - Electric - Jets (FS/W) 0 Nov 18, 2010 11:36 AM
For Sale Two Airliner Models L-1011, DC-10 ASAMech Non R/C Items (FS/W) 0 Nov 27, 2007 09:30 AM
Pcm L-1011 Eddie P Fuel Jet Talk 2 Oct 24, 2005 09:31 AM
