Pepster. . . . .that would be a great name for a new Soda Lol!
Latest blog entry: Joe Nall 2013!
Have a look at this thread, post number 32, http://www.rcgroups.com/forums/showt...3#post21350615.
Yes ,templates are a pain to make. I'll spend 12 to 15 hours to make templates for a DLG wing. The easiest way to make them is to have someone CNC cut them! Mountain Models as well as many others offer this service. Below is a picture of temps made from Formica, Ply and Aluminum Flashing that has Balsa glued to sides . One tip when cutting Flashing or Card stock with scissors, cut in a direction so that when you make the next cut with the scissors that the wire does not hang up on the next step that you just created. Very carefully line up the scissors to make the next step, try to make it one continuous line. Hope This helps.............Blue Skies......................Tim |
| Thread Tools | |
| Wanted Wing Templates for Supra | Belginique | Aircraft - Sailplanes (FS/W) | 2 | Mar 26, 2012 06:13 PM |
| Sold Supra Set Up Templates | EBerris | Aircraft - Sailplanes (FS/W) | 1 | Mar 18, 2012 01:19 PM |
| Question Tight radii on LE of foam cutting templates | bwill6 | Composites Fabrication | 2 | Mar 05, 2012 11:51 PM |
| Help! Aerofoil templates? | Anjan Babu | Electric Plane Talk | 7 | Feb 23, 2012 05:08 PM |
| Discussion Multifunction Tool for shaping Formica templates? | ForeverFlying | The Builders Workshop | 7 | Sep 05, 2011 09:56 PM |
