Old May 02, 2005, 07:16 PM
highace1 is offline
Find More Posts by highace1
highace1's Avatar
Newcastle NSW
Joined May 2004
My ESC got wet. Will it work?
Hello,
Found my new ESC in the bin after a clean up, the heavens had opened up and semi filled the plastic bag that my ESC was sitting in!
I have taken off the heat shrink and have hung it out to dry. I cant see anything that may cause probs but im not sure. It was brand new, nothing was connected.
Will i have to go get another one or should it work if i let it dryout?
Crssong my fingers
Ace
highace1 is offline Find More Posts by highace1
Old May 02, 2005, 07:19 PM
WarPoet is offline
Find More Posts by WarPoet
Small Flying Arts
WarPoet's Avatar
Omro, WI
Joined May 2003
if you let it dry THOROUGHLY it should be okay
WarPoet is offline Find More Posts by WarPoet
Old May 02, 2005, 08:07 PM
Scott_NJ is offline
Find More Posts by Scott_NJ
RC Geek
Scott_NJ's Avatar
United States, NJ, Stanhope
Joined Dec 2004
If it was just fresh water and no power hooked up, it should be okay. As WarPoet said, be sure to let it dry real well. One trick we use with photo gear that gets wet is to put it into a ziplock bag with a few silica gel packs, should help pull the moisture out of the air.
_Scott
Scott_NJ is offline Find More Posts by Scott_NJ
Old May 02, 2005, 08:35 PM
thor4944 is offline
Find More Posts by thor4944
thor4944's Avatar
Ohio Wapak
Joined Feb 2002
Dumped mine in Lake erie. Swam out in 40 degree water to get my plane and when I got to it it was seizing like crazy. Unpluged the battery right away. Cut a little bit of the plastic off to let it dry real good, then used a blow dryer and put it on cool heat and blew dry it dry.....waited till I knew for sure it was totally dry...works like a champ!!!!!
thor4944 is offline Find More Posts by thor4944
Old May 03, 2005, 12:18 AM
highace1 is offline
highace1's Avatar
Newcastle NSW
Joined May 2004
Its looking good for the ESC then, i would like to get another bit of heat shrink tubing to cover it. Is there any other way to shrink that stuff other than a heat gun?
Old May 03, 2005, 12:37 AM
nfhill is online now
Find More Posts by nfhill
Just Keeping UP
United States, ID, Moyie Springs
Joined May 2004
If the water was clean, then just let it dry. If the water was dirty, clean with alcohol or WD40. As long as it wasn't powered up, no problem. Wet when powered up, may or may not work again. As thor4944's experience shows, sometimes you get lucky.
nfhill is online now Find More Posts by nfhill
Old May 03, 2005, 12:52 AM
p51flyer is offline
Find More Posts by p51flyer
San Diego, CA
Joined May 2004
well hupefully it won't fry any of your electronics... Take extra percaution!!!!!!!!!!!!!!!!!!
p51flyer is offline Find More Posts by p51flyer
Old May 03, 2005, 01:36 AM
rbale1 is offline
Find More Posts by rbale1
Joined Dec 2004
Some dude recently torched his whole plane with a shorted ESC, so be careful when you plug in the battery (after it dries )
rbale1 is offline Find More Posts by rbale1
Old May 03, 2005, 06:09 PM
Art Schmitz is offline
Find More Posts by Art Schmitz
Crossville, TN
Joined Dec 2004
ace,a hair dryer will work...as will a lighter used very carefully.I once heard of a guy using a 100w light bulb but never tried it.I'm on my 4th heat gun..HTH.
Art Schmitz is offline Find More Posts by Art Schmitz
Old Mar 23, 2015, 08:41 AM
pankajbhaban is offline
Find More Posts by pankajbhaban
Joined Feb 2015
Same happened with me put my home made airplane in lake motor worked for 10-15 seconds & then nothing motor was just kind of beeping or vibrating where as servo not working let me dry it & try with another ESC & update you
pankajbhaban is offline Find More Posts by pankajbhaban
Old Apr 06, 2015, 11:34 PM
Conehead is offline
Find More Posts by Conehead
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
The fellows on the Waterplanes Forum use Corrosion X Red Label.
Spray it in the rec, esc, servos. they will work underwater.
There is a video on Flite-Test where they show you how to do it, show you want happens and Peter runs motors, servos underwater with no problems.
That same video also shows other ways to water proof/ nothing is quite water proof/ but Peter shows you what to do.
A small can costs about 10 bucks, will do many escs, rec, servos. I have used it, it works.
You can also order it from the company, just google Corrosion X, they sell it in spray bottles, areosol cans and I use it on electric lights on trailers, trailer plugs, anything electrical that I want a good contact electrical.
Conehead
Orrin Eldred
Conehead is offline Find More Posts by Conehead
Latest blog entry: TRAMPS Air Show, 28-June 2014
Question Shulze 40be ESC with lipo - Will it work?? kov Power Systems 1 Mar 22, 2006 06:14 AM
Help! Will my ESC work??? Airplane boy Parkflyers 0 Jan 18, 2006 12:18 PM
Will My ESC Work? AnimalKracker Micro Helis 0 Jun 21, 2005 05:22 AM
sheesh.... Got wrong ESC, ICH100...will it work? theShark Micro Helis 4 Jan 30, 2005 01:54 PM
Fried my ESC... got a new one... naX Parkflyers 1 Dec 22, 2004 10:39 PM
