This might make your head hurt, but if you can sort through the "garbage" there is some good info. I'm kind of intrigued by using the pulley system. No slack at all..... if set up right
![]() ![]() Ken http://www.rcuniverse.com/forum/m_10...m.htm#10852484 |
Ken, your link got mashed up. I think you meant this one. I had a similar idea to use pulleys (actually a capstan) I posted here some time back. The RCU link says 'typical setup' on a sailboat, so I guess my idea wasn't so original. But the concept has a lot of advantages and is 100% linear, so I still plan on using it sometime.
The straight servo-to-rudder pull-pull system is fine as long as Ackerman is kept in mind, that is:
Florida
Joined Aug 2004
The second comment "distance between string holes must be the same at rudder and servo" is not true. No harm if different as long as at maximum throw the moveable surface is not moved so far that binding occurs. |
| Thread Tools | |
| Discussion how well do small 4 strokes pull fuel from a lower tank? | jeff262 | Engines | 13 | Jan 28, 2013 06:39 PM |
| Help! How to calculate low voltage alarm for 4S? | Scooter619 | Batteries and Chargers | 2 | Jan 18, 2013 03:14 PM |
| For Sale HD Tiller Bars, Bell Cranks and Differential Bell cranks-Price to sell | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 0 | Jul 09, 2011 07:46 PM |
| Discussion Rudder Pull/Pull - Crossed wires or straight? | wollins | The Builders Workshop | 8 | Jun 20, 2007 05:29 PM |
| Hornet Tail Gearbox Bell Crank Shaft (E025) | Maarksc | Electric Heli Talk | 1 | Jun 01, 2001 03:14 PM |
