Old May 30, 2014, 12:21 PM
1sq
1sq's Avatar
United States, CA, Imperial Beach
Joined Mar 2013
I went thru the first page and did not find anything about CPPM connection.
Does this board/code have CCPM to enable?
1sq is offline Find More Posts by 1sq
Old May 30, 2014, 12:24 PM
Austria
Joined Jan 2004
Originally Posted by MrGibbage View Post
@e_lm_70, you posted your reply while I was typing mine. Are you saying that it *IS* ok to use the UBEC from one of my ESCs to power the FC?
If you have a quad and no servo gimbals ... there is no issue on power control board and rx with one of the 4 BEC included in the ESC, the other 3 is better to remove the red line for avoid to make them to fight each other ... but it is a minor issue ... if you have 4 identical ESC putting them all the 4 BEC of the 4 ESC in parallel will not cause much of waste or extra heat
Different story is for a tricopter, the digital servo needed for yaw can do a lot of mess in the power line, this I don't suggest to put in parallel to the power line used by the control board
e_lm_70 is online now Find More Posts by e_lm_70
Old May 30, 2014, 12:25 PM
Austria
Joined Jan 2004
Yes ppm is supported ... if I recall right it is A0 the connection
At multiwii side, there is something to uncomment in config.h for enable ppm
Old May 30, 2014, 12:35 PM
1sq
1sq's Avatar
Joined Mar 2013
I'll look in the config.h for it.
Care to point me to the A0 connection? I don't see that writting anywhere on the board. I see A10 which i believe is the throttle?
Old May 30, 2014, 12:42 PM
Austria
Joined Jan 2004
Just double check my x900 that use this board ... it is A8 ... sorry not A0
Old May 30, 2014, 01:30 PM
1sq
1sq's Avatar
Joined Mar 2013
/**************************** PPM Sum Reciver ***********************************/
/* The following lines apply only for specific receiver with only one PPM sum signal, on digital PIN 2
Select the right line depending on your radio brand. Feel free to modify the order in your PPM order is different */
//#define SERIAL_SUM_PPM PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2,AUX3,AUX4,8,9,10 ,11 //For Graupner/Spektrum
//#define SERIAL_SUM_PPM ROLL,PITCH,THROTTLE,YAW,AUX1,AUX2,AUX3,AUX4,8,9,10 ,11 //For Robe/Hitec/Futaba
//#define SERIAL_SUM_PPM ROLL,PITCH,YAW,THROTTLE,AUX1,AUX2,AUX3,AUX4,8,9,10 ,11 //For Multiplex
//#define SERIAL_SUM_PPM PITCH,ROLL,THROTTLE,YAW,AUX1,AUX2,AUX3,AUX4,8,9,10 ,11 //For some Hitec/Sanwa/Others
// Uncommenting following line allow to connect PPM_SUM receiver to standard THROTTLE PIN on MEGA boards (eg. A8 in CRIUS AIO)
#define PPM_ON_THROTTLE
Above is what i commented and connected a PPM set RX to A10 (throttle) and i can''t even arm the board. I tried the A8 also and no luck.
On a diffrent note i connected my $18 UBLOX? GPS from witepsy and Bluetooth/ez gui is not showing satellite number even after 10 minutes powered on. It stays 0 sattelite.
I'm looking at the board now and there is a blue LED (3) dimely blinking. Is that GPS 3d lock?
Oh now GPS is working! On android app+BT, FC is showing 9 sat and android showing only 7 sat lock.
Now i just need to figure out the CPPM.
Old Jun 23, 2014, 12:21 AM
Joined May 2014
Are the pinouts different on MW 2.3 or same as 2.2? I just started quadcopters and a senior member told me not to update to 2.3 because pinouts are different.
Mkkhattak is offline Find More Posts by Mkkhattak
Old Jun 23, 2014, 01:39 AM
Austria
Joined Jan 2004
Only for tricopter and some servo there is a difference as far as I know ... still I'm running 2.2 on this, 2.3 only on different boards
Old Jun 28, 2014, 04:41 AM
Joined Feb 2012
Look at function "void mixTable()" in "output.ino"
Later you should see:
Code:
    #ifdef TRI
      motor[0] = PIDMIX( 0,+4/3, 0); //REAR
      motor[1] = PIDMIX(-1,-2/3, 0); //RIGHT
      motor[2] = PIDMIX(+1,-2/3, 0); //LEFT
      servo[5] = constrain(conf.tri_yaw_middle + YAW_DIRECTION * axisPID[YAW], TRI_YAW_CONSTRAINT_MIN, TRI_YAW_CONSTRAINT_MAX); //REAR
    #endif
Change into
Code:
    #ifdef TRI
      if (f.ARMED)
      else
        servo[5] = conf.tri_yaw_middle;
    #endif
Have been looking around for this, thank you!
philsson is offline Find More Posts by philsson
Old Aug 11, 2014, 03:58 PM
Belgium, Flemish Region, Geel
Joined Jun 2013
Originally Posted by JNJO View Post
Or, you can run your GPS with 3.3V. Just remove the solder at the 5V-pads and solder the 3.3V pads together.
Picture stolen from post#1, info is in the GPS-manual.
Id like to reuse the MTK GPS module for a naze32 based quad. The naze manual states in big bold red font that I need a 3.3V GPS. I actually suspect that refers to the signaling, rather than VCC, since most pictures for wiring the GPS suggest to power the GPS from a 5V pin. So now Im a bit confused.
If I were to desolder the 5V pad and solder the 3.3V on the gps, would that change anything to the signal voltage? Would it then be safe to use with a naze32 board?
Vertigo72 is online now Find More Posts by Vertigo72
Old Aug 12, 2014, 02:51 AM
Austria
Joined Jan 2004
MTK is 3.3v internally.
What matter is the voltage level at TX and RX pin ... these are 3.3v on the MTK
Just power the MTK module with 5v ... TX and RX will be 3.3v and you will have no issue with Naze32
Old Aug 12, 2014, 02:54 AM
Austria
Joined Jan 2004
Here is my latest video from this board:
Lago di Maen - Valtournenche Valle d'Aosta - Aerial Video + Crash from x900 Tricopter (3 min 51 sec)
Once again I had bad luck ... like 1 year ago not far away from this place my old KK2.0 lost the Z gyro chip ... and I got a fly away
This time ... less damage ... but I still don't know why it did flip over.
After 1 year ... actually on my last video I also got more jello/vibrations ... I still have to find the best mount ... but I should have some new real APC prop coming to me .... for try to improve the situation vs the 3 blade cheap plastic prop ... let see
Old Aug 13, 2014, 03:43 PM
Joined Jun 2013
THanks, I just tried, and indeed, it "just works". Aweseome. Also quite pleased to see GPS data is sent over frsky telemetry by the naze, so I can log everything on my taranis, even the track and load it google earth.
Old Sep 11, 2014, 10:16 AM
Joined Sep 2014
I want to get a vtail 500 dialfonzo, does MPNG support vtails? I looked at the diagram and didn't see a vtail setup.
mrclean1972 is online now Find More Posts by mrclean1972
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 01:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 04:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 03:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 10:29 PM
