Old Jul 17, 2015, 09:58 PM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Question
Keel bulb design for specific weight
are there any tables that show keel bulb design/dimensions for specific weight? I am looking for tables where you can enter desired final bulb weight, and the tables will provide (I hope) the length and diameter for a bulb to hit or come darn close to the design bulb weight,. I thought there was one but haven't been able to find it. Any help or links appreciated.
Thanks in advance. Dick
Dick L. is offline Find More Posts by Dick L.
Old Jul 17, 2015, 10:22 PM
KIWINB is offline
Find More Posts by KIWINB
Auckland New Zealand
Joined Sep 2010
http://www.onemetre.net/design/bulbcalc/bulbcalc.htm
All you need. Takes a bit of learning how to drive it though.
found it in http://onemetre.net/index.htm
There is always a tradeoff between length/dia (surface area) and drag. I've seen a chart of surface area vs drag relationships but can't find it.
I seem to remember for lowest drag the diameter is around 8 to 10% of length. Makes delicate ballasts though.
KIWINB is offline Find More Posts by KIWINB
Old Jul 17, 2015, 10:32 PM
Dick L. is offline
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
@KIWINB
Thank you. I believe this was the one I was looking at some time back, and forgot to bookmark the URL. Will give it a go and see what kind of shape & size I wind up with. Appreciate your quick response.
Dick
Old Jul 18, 2015, 05:44 PM
Rusty Nail is offline
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Attached is a non-lifting, parallel bulb calculator and lifting profile drag analysis for completeness.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jul 19, 2015, 11:32 AM
Dick L. is offline
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Thanks for the calculator. I am hoping to take a chunk of cedar and turn it on a lathe in garage. I was thinking that I wanted a diameter and a length that would = desired weight. My initial guess is the first response will provide that - or - a darn close ball park shape to begin.
Want to get away from the # 5 or #6 shape (Image above) and head towards the #1 or #2 shape. I have no issue in finding the best total bulb weight - just visualizing how much lead needed to make a good bulb shape. I prefer to be close on the wooden turned plug, rather than having to try to reduce a lead bulb.
Old Jul 28, 2015, 10:32 PM
sub wrecker is offline
Find More Posts by sub wrecker
Joined Feb 2013
Bulb Moulds
Has anybody tried making moulds of portland cement.Plaster of paris is just to fragile!Maybe even chopped fiberglass in cement.
sub wrecker is offline Find More Posts by sub wrecker
Old Jul 29, 2015, 08:17 AM
DLord is online now
Find More Posts by DLord
DLord's Avatar
United States, FL, Cocoa Beach
Joined Jan 2010
bulb mold
The best material I found for making bulb molds is alumina ceramic. You can use a wood plug and make a small box out of balsa to pour the mixed ceramic into with the wood plug inside. After a few hours it will be ready to go. A bit expensive if you buy the material from McMaster-Carr: $85 for 10 pounds, part #8498K35. You can use a mold made out of this stuff dozens of times with no degradation.
DLord is online now Find More Posts by DLord
Old Jul 29, 2015, 08:23 AM
Dick L. is offline
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
I have been looking at this stuff. Haven't purchased as yet.
Old Jul 29, 2015, 09:15 AM
slotracer577 is offline
Find More Posts by slotracer577
Joined Jan 2006
I actually use silicone rubber for molds. You can mold the bulb inside the rubber, then cut a single slit to get it out. One pc bulbs and since the rubber is soft you can cast in a fin slot.
slotracer577 is offline Find More Posts by slotracer577
Old Jul 29, 2015, 09:28 AM
Si2 is offline
Si2
Find More Posts by Si2
Si2
United Kingdom, England, Portsmouth
Joined May 2014
RTV silicone is cheap and easy. People have been casting lead soldiers in it for years.
Not as cheap as sand mind you, but cheap enough.
I make a box out of lego bricks to pour the silicone in to around the form.
You can either use this box when casting or it you add enough wall thickness the whole thing is self supporting. LIke Slotracer says you can basically encapsulate a nice bulb form with filler and vent, in silicone and then slit it to remove the form once the silicone has set.
Then close if back up with either the orignal box or a rubber band or two and you can cast in it.
here is an article by me for casting tanks - but it's the same process...
http://www.madponies.net/mold.html
Si2 is offline Find More Posts by Si2
Old Jul 29, 2015, 10:52 AM
FoamCrusher is online now
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Dick:
I have made several "cast to weight" bulbs for different boats. I use the Bulb Calc software to get the correct dimensions, factoring in the amount of lead that will be lost for the keel slot that is later milled into the bulb and an additional tiny bit because the lead shrinks as it cools in the mold.
Then I turn a hardwood plug and apply a good waterproof finish and let it dry. The box for the mold is made from fan folded foam (BlueCor) parts stuck together with hot glue.
I have tried several materials for the mold, but the cheapest and simplest is Ultracal 30, a gypsum cement used in the ceramics industry http://www.plaster.com/Ultracal.html for duplicator molds. It is super strong, has virtually no shrinkage, cures quickly and withstands the heat of the pour lead so it can be used multiple times. Petroleum jelly is an easy and cheap mold release.
I get it in 50 lb bags from a local ceramics studio - the type where people buy greenware, apply the glaze and pay to have the shop fire it. You can get small amount from a seller on eBay, but the shipping amounts to more than the product.
About the only cheaper molding process is to use sand molds, but even the best technique still leaves a rough surface. The Ultracal molds require only a light touch up with surface putty before priming and painting.
FoamCrusher is online now Find More Posts by FoamCrusher
Old Jul 29, 2015, 01:34 PM
Joined Feb 2013
Bulb Molds
Thank you all for info.and quick response.Now have to decide what material i'm going to use to make mold for several bulbs.
Wanted Thunder Tiger Victoria older keel bulb dno264 Boats (FS/W) 0 Jun 11, 2014 07:31 PM
Help! How to calculate weight/volume of a keel bulb? disabled Sailboats 28 Sep 05, 2011 04:35 AM
Discussion Keel length vs bulb weight rich1833 Sailboats 9 Dec 17, 2009 10:07 AM
Discussion 1.2 mtr keel bulb weight sirmong Sailboats 4 Jul 15, 2008 10:13 AM
Sailboat Keel Bulbs for pods? Thermalin Hand Launch 3 Apr 09, 2005 12:48 PM
