View Poll Results: Whatís the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
Iíd rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and Iíll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Feb 21, 2014, 03:43 AM
doubletop's Avatar
New Zealand
Joined Nov 2013
Something you will need to deal with then
regards
Pete
doubletop is offline Find More Posts by doubletop
Old Feb 21, 2014, 02:19 PM
Joined Oct 2006
"M" version is wrong.Wrong calculated speed (RPM) is 2x more.(Gompy technology the ENTERPRISE?) http://static.rcgroups.com/forums/im...es/biggrin.gif
My RPM 0-15000 (400-15000 FW version "K")
800-30000 FW version "M"
Error What I showed in the video was between 920-930RPM version of "K"
Now 1840-1860RPM
The good news-I added OPTOCOUPLER to pin5 and freezing is completely stopped. Testing of HV plate (version "K", "M")
blazino is offline Find More Posts by blazino
Old Feb 21, 2014, 03:00 PM
doubletop's Avatar
New Zealand
Joined Nov 2013
Blazino
You passed the test! You need to configure the following
#define VERSION "CDI-2012_12F1840_PJT v2.M Cam \0"
/***********************Configure your system setup here ********************/
#define Sensor_Location Cam //= Crank or Cam
#define Init_Hall_Angle 63 //Enter in true degrees angle MUST be 10deg more than max advance required
#define Do_Kill_Switch True // enable kill switch on pin 4
#define Init_fixed_adv 4 //initial fixed advance value in DD's
#define Start_Throttle 6 //Include your servo setting for starting ('u' command)
#define Rev_Limit 7500 // in RPM
#define Baud_Rate 207 // Set your Baud Rate Control 207=19,200, 103=38400, 68=57600, 51=76800,16=115.2k, 15=128000
Or if you are using the excel based simulator set the "cam' checkbox
It depends where you have your sensor located most will have 'crank' but my engine has the sensor on the cam. I didn't cahnge it in this version, in the other versions I posted I did.
Pete
Old Feb 21, 2014, 03:42 PM
Joined Oct 2006
yup
My mistake.
Pete, thank you, I'll try next week.
Old Feb 24, 2014, 05:04 PM
Joined Feb 2014
Hi guys,
Jake wrote me a letter to join your commmunity.
I more than happy to see your work guys, really appriciate it.
I was also workin on a similar project:
http://csa-electronic.wix.com/index
The hw is based on Gompys project, the sw is written by me.
Cheers,
Attila
CheeseE is offline Find More Posts by CheeseE
Old Feb 24, 2014, 08:37 PM
doubletop's Avatar
New Zealand
Joined Nov 2013
CheeseE
Hi
I've just been talking to Jake. The next thing on our list is a GUI and yours is just what we need to link the V2 code to the outside world. It will allow us to remove the terminal code from the PIC to get some space for more features
Send Jake and me a PM and we can hook up on how we can go about this.
Pete
Old Feb 27, 2014, 10:16 AM
Joined Dec 2012
Pete, just sent you the Zip file.
John
gr8flyer55 is offline Find More Posts by gr8flyer55
Old Feb 27, 2014, 12:30 PM
Gompy's Avatar
The Netherlands, NH, Alkmaar
Joined Dec 2012
Mmmmm....
Gompy is offline Find More Posts by Gompy
Old Mar 07, 2014, 05:49 PM
Joined Dec 2012
CheeseE's software seems to work well with the 16f628A pic chip. If there is a similar bootloader available for the 1840 chip, maybe his gui can be ported over , and used as an alternative system without all the extra features. The older timer board and my hv board work well together after setting timing and delays. I probably will make a test video shortly and post it.
John
Old Mar 08, 2014, 04:50 PM
Joined Dec 2012
Originally Posted by CheeseE View Post
Hi guys,
Cheers,
Attila
I'd like to take a look at it but not keen to sign up to a subscription I don't need.
bluejets is offline Find More Posts by bluejets
Old Mar 09, 2014, 03:13 PM
doubletop's Avatar
New Zealand
Joined Nov 2013
Attila
People aren't keen on signing up to your service provider. Can we post your two files here for the others to use?
Pete
Old Mar 09, 2014, 04:08 PM
Joined Dec 2012
Pete, it didn't make me sign up. I just hit the menu symbol in the upper right corner and it took me right to the download section with the two files. When I got the files, I had to rename the hex file and re save it as hex. The other file is the install file. After installing it, I hit the desktop icon. I think it took a full two minutes to actually come up on the screen but it worked. You'll have to reset your comport back to 9600 baud for it to communicate with both serial port and programming adapter. I programmed the bootloader hex file into the chip and inserted it into one of the older timer boards that ran with either an external crystal or a resonator. I edited the numbers in the rpm & advance table on the screen, making my curve and sensor placement, and after that I hooked the timer board up and hit connect. Then hit program button and it sent the data to the chip. Rpm and advance screens reflected my changes. Haven't run the engine with it yet but it's getting close.
John
Old Mar 09, 2014, 04:17 PM
Joined Dec 2012
I think if we had CheeseE's timer schematic for inputs, outputs and chip pinouts we could test it correctly.
John
Old Mar 09, 2014, 04:57 PM
Joined Dec 2012
John
Something has changed then as the link takes me to a CSA Electronics page, could not see any menu in the top right corner,hit download and the two files are there but when one clicks those, it take one to File Dropper and from there to a Paypal page.
Tried the web page listed but it comes back as some web hosting site.
Old Mar 09, 2014, 05:48 PM
doubletop's Avatar
New Zealand
Joined Nov 2013
A similar experience, once I got redirected a couple of times I gave up
Pete
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 11:03 AM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 08:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 01:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 05:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 12:22 PM
