Old Jun 26, 2015, 01:48 PM
LRFitch is offline
Find More Posts by LRFitch
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Building a CNC router?
I'd like to have a cnc router machine, and would prefer to build one out of wood, if that is possible. I've seen the "buildyourcnc" and the Wetlands build, but not sure either would do what I'm trying to do. I'd like a machine at least 24'X48", and would prefer something 48"X 48" so I can cut several wing ribs for large scale gliders (wing chord 30+") without having to cut a few, and load in another sheet of ply. I've been told that gantry mass (and attendant backlash) can be an issue with getting rib notches (for spars, etc.) cut accurately, so not sure a wooden machine is even possible. Has anyone used such a machine to cut large wing ribs, etc. using a CNC router? I'd like to build because I don't think I can buy one for under $3000.00. I'm open to any recommendations.
Larry Fitch
LRFitch is offline Find More Posts by LRFitch
Old Jun 27, 2015, 02:41 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I would think that one could be made to do a reasonable job. The ones I have seen had serious issues from using substandard guide rails. So hard to judge. Even with the issues they did a reasonable job, as long as the cuts where light.
I looked at the Wetlands build. I think its gantry issue had more to do with the design, than the material.
I haven't seen in person a well implemented wood design. To bad you didn't ask last month. I passed up a couple of decent sized routers in auctions recently. Both because I didn't want to deal with shipping.
Mass in a machine can be good, or bad.
Good: it helps reduce vibration, for a smother cut.
-It is usually more rigid. Often allowing for a more aggressive cut, or the ability to handle harder materials.
Bad: it has more momentum, so takes more power to accelerate, and stop. So may end up being a slower machine.
-Can require more expensive slides, and electronics to deal with the weight.
-Might not be as portable.
Roto Rob is offline Find More Posts by Roto Rob
Old Jun 27, 2015, 03:41 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
i have used sum wood on my cnc mostly ply steel for the frame and liner rails
the money is in the liner rails but there is a new system that offer a good rail at a good price V slot if i rebuild my cnc that is what i would go for i have built a 3D printer with it and am thinking abut building a new foam wing cuter with it
http://ooznest.co.uk/blog-section/C-Beam-Now-Available
pdf of my old cnc router
dpot is offline Find More Posts by dpot
Old Jun 28, 2015, 10:21 AM
LRFitch is offline
Joined Aug 2004
Thanks guys
Rob, can you share what the gantry issue was with the Wetland design/build? Not sure I saw that. Dpot, thanks for the insight. I've seen the V-groove rails and agree they look rather good. I currently think I would go for CRS rails and steel rollers as well, like on the Wetlands build. I agree that mass can/is both "good and bad". Everything is in most mechanical designs.
Larry Fitch
Old Jun 28, 2015, 02:04 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Sure, the router had all the ply running the same direction. The flex he had in the middle of the gantry was forward, and aft. That happens to be the easiest direction for the ply to flex. If he had left the outer ply as is that would resist vertical flex. The interior ply could have been rotated 90 degree's to resist forward, and aft flex.
It might take some testing to figure the right mix, to limit flex in each direction while keeping a light weight assembly. The machines I have worked with usually have a higher load to the side, and less vertical while routing. That side force on the router also tries to twist the gantry. The buildyourcnc machine has spacers between the gantry ply with the ply running fore, and aft. That helps prevent twist. Would take some figuring to calculate the best configuration, for the amount of wood used.
Old Jun 28, 2015, 07:18 PM
LRFitch is offline
Joined Aug 2004
Rob, after reading your statement above, I went back to YouTube, and found his video about the deflection of the gantry. What I saw seems to say he measured the deflection with the dial indicator (appears to be about 2-4 thousands of an inch). I guess my question is if this amount of deflection is an issue in machine accuracy. I agree with your comment about having all the plys running in one direction. I think a better use of the plywood's potential could improve performance. Any information about how other materials (80/20 forms) would perform in this type of measurements. How much better would the aluminum be in similar structures? I wonder how "stiff" these structures have to be to be usable. I'm not sure.
Larry
Old Jun 28, 2015, 09:26 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
The deflection he had is not that much. The force he used was rather vague, but gave the impression he was using a good deal.
Rigidity allows it to work harder, and faster. I have seen machines not nearly as nice do work that is better than many would do by hand.
Old Jun 29, 2015, 08:27 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
When I set up both of my machines, I measured using 50lbs of cutting force at the tool. My old machine was MDF and had a long extrusion for a gantry. I measured almost 15 thousandths of deflection at 50lbs at the center of the gantry. My new machine is about 2 thousandths.
My old machine was very capable. Knowing what and where the flex was helped a lot. Keep the speeds down on harder materials and cut them near the end of the gantry travel if possible to minimize deflection. It's really pretty easy. I eventually (6 years) built a stiffer machine with a much larger and shorter gantry but my old machine served me very well in the past.
Building a machine and knowing how to use a machine are two distinctly different skills. Once you have a CNC router that you can use on a daily basis, you quickly get an understanding of how to work WITH the tool to overcome it's weaknesses.
tom43004 is offline Find More Posts by tom43004
Old Jun 29, 2015, 10:32 AM
LRFitch is offline
Joined Aug 2004
Rob, Tom,
Thanks for the insights. I think I will venture down the wooden road, designing a stiff machine using the attrubutes of the plywwod as best I can, and go from there. Tom, you are very right, most machines have a weakness or two, and you learn to get work done dispite them.
Thanks again,
Larry Fitch
Old Jun 29, 2015, 11:49 AM
gonzalito is offline
Find More Posts by gonzalito
Argentina, Cordoba, Villa Marķa
Joined Feb 2012
Depends
I think it depends on what you want to cut or work with. I“ve made mine with mdf, and i can work Mdf correctly, as well as cutting plywood with no problems.
It also depends on how much precision you want.
I built mine with very little money (for a CNC) and performs well.
If +/- 0.25mm is fine then yeah you can do it cheaply. Precision increases cost.
gonzalito is offline Find More Posts by gonzalito
Sold Parts to build a Hobby CNC Router. The Don Aircraft - General - Miscellaneous (FS/W) 3 Jan 11, 2014 07:15 PM
Discussion Building planes with cnc router/laser Krashlnd The Builders Workshop 5 Dec 22, 2006 04:36 PM
Cool Anyone build a CNC Router from Hobby CNC plans? corey The Builders Workshop 0 Jan 23, 2005 02:52 PM
I want to build a CNC router that... Xnaron The Builders Workshop 17 Dec 02, 2004 05:28 PM
