Old Aug 09, 2015, 12:40 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
They only came with a template for a DLE30.
But... here is the OS 33GT manual (dimensions are on page 27. The DLE 30 manual is here dimensions on page 23, and the DLE35RA manual is here, and again, the dimensions are on page 23.
Just as a matter of mentioning my young padawan..., all of these manuals were found by just typing in the name of the engine and "manual" in Google...found in mere seconds..
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Aug 11, 2015, 01:20 AM
Phazeman is offline
Find More Posts by Phazeman
Joined Aug 2015
SteveT.
Thanks a lot Master !
i wish i could be "young" turning 40 in 2 weeks LOL
i was thinking that the drilling template is model related in the first place and engine afterwards... that's why i was looking for the Slick specific template... i do have both manuals (OS and DLE) but never go to page 23 nor 27
Thanks a lot !!!
Phazeman is offline Find More Posts by Phazeman
Old Aug 18, 2015, 08:15 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I can't believe these are in stock, and Orange on top of that!
I thought they where done with the AJ line.
I'm so, so tempted to push that button, but I still have two I'm working on so I have to use my better judgement and pass.
Now that I have a great charging station, I want more 7X planes instead of 60's.
jk6672 is online now Find More Posts by jk6672
Old Aug 28, 2015, 08:24 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
I jusr scored a 70" Slick to go with my 71, and need to find out the CG measurements. If any of y'all can post it here I'd be your huckleberry.
Chuck
Chuck is offline Find More Posts by Chuck
Old Aug 28, 2015, 08:39 PM
SteveT.'s Avatar
San Jose, CA
70" Slick Manual....
SteveT
Old Aug 28, 2015, 08:40 PM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Did you get the electric or gas version?
I have the manual for the electric one and it says cg is: For maiden and precision flight - 155-160mm from leading edge of wing at root This is approximately the forward edge of the carbon wing spar tube.
camoy is offline Find More Posts by camoy
Latest blog entry: 3DHS 92" Edge repair
Old Aug 28, 2015, 08:48 PM
SteveT.'s Avatar
San Jose, CA
I don't think there is a difference in the two as far as CG goes...
SteveT.
Old Aug 28, 2015, 10:17 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Stacks On?
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
I have the 71 motor box in my 70 Leccy Slick since its stronger and the same. Go with how you like it on your 71.
DaOldGuy is online now Find More Posts by DaOldGuy
Old Aug 29, 2015, 01:40 PM
Brownie433 is offline
Find More Posts by Brownie433
United States, WI, Milwaukee
Joined Sep 2008
For the combination Gas/Electric slick, what are you guys doing for cooling of the motor and batteries when doing electric? At the beginning of the motor box there is wood now for I'm assuming gas, this blocks air flow behind the esc and to the batteries. Are you cutting holes in it to get air flow? What panels in the bottom are you opening up with the tunnel there and all.
In my 5x" planes the former at the beginning of the motor box is open on the sides and there is no tunnel so the batteries, esc, and motor get tons of airflow with the panels cut open on the bottom. The 71 is different and I'm not sure how to attack cooling.
THanks,
Brownie433 is offline Find More Posts by Brownie433
Old Aug 29, 2015, 04:37 PM
SteveT.'s Avatar
San Jose, CA
I used a 5/8" "Forstner" bit and drilled two holes on each side of the motor box in the front former..
SteveT.
Old Aug 29, 2015, 10:05 PM
Joined Sep 2008
SteveT.
Thanks!
DId you do anything with the tunnel?
Are your vents cut out under the tunnel or back past the tunnel or maybe both?
Old Aug 29, 2015, 10:52 PM
SteveT.'s Avatar
San Jose, CA
I just did the holes, and then opened up a hole on the bottom of the fuselage as per instructions.
SteveT.
Old Aug 29, 2015, 11:16 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Thanks guys, for the info & link.
Chuck
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
