Old Jul 17, 2014, 10:49 AM
Joined Jul 2014
Transmitter work with receiver?
Hey all.
Im looking to build a micro FPV system.This would be my first build and my first FPV build.
I understand that you need to have the same frequency for the transmitter and receiver. I'm a bit confused with the statement that comes with the transmitter.
"ATTENTION : CAN NOT USE WITH FATSHARK, FREQUENCIES ARE DIFFERENT."
Im looking at this transmitter: http://www.fpvhobby.com/215-rtu-58gh...-ua-set-3.html
And this would be my receiver: http://www.hobbyking.com/hobbyking/s...dProduct=35055
Would these two work together?
Tim
flybytim is offline Find More Posts by flybytim
Old Jul 17, 2014, 02:38 PM
Jam-ehz's Avatar
Canada, ON, Toronto
Joined Sep 2004
Yup, should be fine.. that monitor/Rx isn't a fatshark receiver (i.e. ImmersionRC or any FS headset) so you're safe.
The transmitter doesn't list the channels, but I'm sure the 8 channels it has will be covered by the receiver. Might just need some docs or question to the seller to find out exactly which.
Looking at the receivers offered by FPVHobby I'm sure it's using the common set.
Jam-ehz is offline Find More Posts by Jam-ehz
Old Jul 17, 2014, 02:43 PM
Joined Jul 2014
Hey Jam thanks for the reply.
You can see the channels here:
Sold JR 347 transmitter with receiver (TX will work with 2.4 spectrum module) flybabycx Aircraft - General - Radio Equipment (FS/W) 0 Nov 03, 2012 05:13 PM
Question Would this transmitter work with a GWS receiver? Draven Electric Plane Talk 6 Aug 13, 2008 09:20 AM
Help! Parkzone receiver work with Futaba Transmitter ? jrotor Parkflyers 3 Aug 20, 2007 05:18 AM
Do some receivers work best with particular transmitters? pfm Radios 9 Sep 12, 2005 09:08 PM
