Old Jan 30, 2014, 02:53 AM
I wanna fly!....
UK
Joined May 2004
***New Product*** Walkera G-2D Brushless, thoughts?
Hi Guys,
I've been looking for my first gimbal and have come across this...
http://goo.gl/3GVejo
It's available online from $99.99, I'm considering taking a risk on it to use with my Hero 2 (I presume I can add spacers to accommodate the larger depth vs the GoPro 3.
Any input appreciated!
markswift is offline Find More Posts by markswift
Old Feb 04, 2014, 05:33 AM
Joined Jun 2012
I saw that too and that fact that it's quite light was appealing. if the controller turned out to be rubbish you could easily put a cheap AlexMos board on there as the motors would be fairly standard.
One thing that's confusing is you can't tell if the rubber dampers are in compression or in suspension. In some pictures they are clearly in suspension - the arm mounts to the bottom plate and the dampers are stiffer with lines around them, but in a few others, the arm is mounted to the top plate (better) and the dampers are the smooth, softer ones you get on a Tarot gimbal. I'd prefer that if it could be confirmed.
Also, being very light, could easily be converted to 3-axis without adding too much extra weight - about 80g for a motor and some extra plates and an additional controller. Or swap the 2-axis controller for one of the new mini 3-axis ones and it would be even lighter and simpler.
Brandigan is offline Find More Posts by Brandigan
Old Mar 06, 2014, 08:54 PM
Joined Mar 2014
Just got my new G-2D gimbal. It worked for about 5 minutes. Then it jerked all over the place and now the LED does nothing but flash green. It will not initialize at all. Seems pretty dead. Any ideas?
tsunami60 is offline Find More Posts by tsunami60
Old Mar 07, 2014, 07:40 AM
Joined Mar 2014
And, now it works. Went to dinner and when I got back, plugged in the gimbal again. It started working. Seems it just needed to sit for a bit to loose all memory and reboot. No clue. Just glad it's working properly now.
Old Mar 07, 2014, 08:32 AM
eirlink's Avatar
Ireland
Joined Mar 2013
when it works, how stable is it?
can you post up a short video, showing yaw movement. tks
eirlink is online now Find More Posts by eirlink
Old Mar 08, 2014, 06:16 AM
United States, OR, Grants Pass
Joined Dec 2011
Could someone scan and post the instruction sheet for this gimbal?
thx...
bonzer2u is offline Find More Posts by bonzer2u
Old Mar 08, 2014, 06:43 PM
Joined Mar 2014
Instructions
Here you go. G-2D
Old Mar 10, 2014, 02:19 PM
Joined Mar 2014
Not much of a movie maker, but here is a video as requested. The gimble seems to work well. Will know more after I test it in flight and see the video.
H 550 (1 min 11 sec)
Old Mar 15, 2014, 09:49 PM
I feel the need for speed
BaracW's Avatar
St. Petersburg, FL
Joined Feb 2007
I just received my G-2D today. Does anyone know of a source for or perhaps, has a 3d printer to make and sell me, an extended bracket to mount the deeper GoPro2 vs the stock bracket for the GoPro3? I'm thinking about using rubber bands to keep it in the back tray, but would feel more comfortable with a screwed in bracket.
BaracW is online now Find More Posts by BaracW
Old Mar 15, 2014, 10:07 PM
Joined Mar 2014
How about some small spacers and longer screws?
Old Mar 24, 2014, 11:37 PM
San Diego
Joined Feb 2003
Walkera G-2D gimbal
I got
Don 2416n is offline Find More Posts by Don 2416n
Old Mar 25, 2014, 02:02 AM
San Diego
Joined Feb 2003
Old Mar 25, 2014, 06:57 PM
Joined Mar 2014
I bought one and have been testing it for about a week. Im not 100% happy, but cant complain too much since it was $100. Im having trouble calibrating it....which is pretty loose in the manual. Maybe its just me being a little slow, but the manual describes to let lights flash and turn knobs to adjust gain and such, but the gimbal doesn't respond to any adjustments really. It acts like it wants to be factory tuned and not user tuned. Very touchy
Does anyone know how to just reset and start over? I feel like my adjustments made it worse.
animatezero is offline Find More Posts by animatezero
Old Mar 25, 2014, 10:25 PM
BaracW's Avatar
St. Petersburg, FL
Joined Feb 2007
You do have a camera installed when powering up, right? I found mine did OK straight away, but had to do minor adjustment with a GoPro2 attached to setup straight and level.
Old Apr 04, 2014, 12:53 AM
Joined Jan 2014
I connected my G-2D gimbal today with my Walkera X350 Pro and well its kind of jerking around a lot,not responding to the DEVO 10 Pit and Roll controlling knobs at all.... its in "sw 1" position, i havent connected any camera on it yet as i just wanted to see if it works fine or not,and i havent tinkered with the v1/v2 knobs as well..... the green light is stable meaning initialization is complete
baz00ka is offline Find More Posts by baz00ka
For Sale New Product to Mod your Tarot Brushless gimbals wdelarme Aircraft - Electric - Multirotor (FS/W) 5 Nov 20, 2013 05:55 PM
Sold Brand New Tarot T-2d Brushless Gimbal $150 shipped Wangta Aircraft - Electric - Multirotor (FS/W) 6 Nov 11, 2013 08:20 AM
For Sale Brand new f450 + naza v2 with gps + Mastor-G brushless Gimbal redodedo Aircraft - Electric - Multirotor (FS/W) 0 Oct 29, 2013 01:55 PM
For Sale Mastor-G brushless gimbal brand new in box redodedo FPV Equipment (FS/W) 0 Oct 28, 2013 04:13 PM
