Old Jan 19, 2015, 10:38 AM
United States, WV, Culloden
Joined Aug 2013
Y6 vs hex
I have been planning to build a hex with some leftover parts. Now I am wondering if a Y6 might be a better choice. With three less arms, the frame could be lighter. Of course an arm for two motors would need to be stronger than an arm carrying only one motor, but maybe not twice the weight.
For aerial photography, the hex frame requires that the gimbal and camera be mounted far forward or very low to keep the props out of the view. The frame often has to be extended to mount the battery farther back to balance the camera and gimbal. Hex frames typically need a taller landing gear or one with wider stance which adds more weight. Prop sizes are limited on the hex frame.
The Y6 frame has arms at a wide enough angle that the gimbal and camera can be mounted closer to the center and consequently, the battery as well. The wider angle allows larger props. A Y6 frame can also be designed to fold easily.
So what is the down side? There is some loss of efficiency from having coaxial motors and props but how much is that?
Is the Y6 a good stable platform for Aerial photography? Can it safely land after losing a prop or motor?
syotr is online now Find More Posts by syotr
Discussion Redundancy in multirotors, hex/y6/octo/x8? thatpajeroguy Multirotor Talk 8 Oct 21, 2014 11:02 AM
Sold *Price Drop* Quad For Sale or Trade (Hex,Y6, P2) dronebuilds Aircraft - Electric - Multirotor (FS/W) 0 Oct 04, 2014 08:19 PM
For Sale Sell or Trade - Quad For Hex, Y6, Etc (Power Quad) dronebuilds Aircraft - Electric - Multirotor (FS/W) 7 Oct 02, 2014 11:11 AM
Discussion Flat H6 hex, hex or a y6 for aerial photography ahtiram Aerial Photography 2 Aug 22, 2013 09:53 AM
Discussion HEX vs Y6 Av8Chuck Multirotor Talk 27 May 19, 2011 02:56 AM
