Old Apr 14, 2015, 10:31 AM
l1nuxfre4k is offline
Find More Posts by l1nuxfre4k
Joined Mar 2015
My APM voltage regulator busted?
When i messure the voltage at the IC2 pins i get between 1.6 and 2.6, is it busted or could something else be causing it to behave in such a way?
I was reading about someone fixing it without soldering using a Arduino nano/mini to power it with 3.3v, anyone here tried it?
http://flight.farbird.com/2014/02/re...ardupilot.html
l1nuxfre4k is offline Find More Posts by l1nuxfre4k
Old Apr 14, 2015, 02:10 PM
Oldgazer is offline
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
The I2c pins are INPUTS. You need to measure the output of the 3.3v regulator.
Oldgazer is offline Find More Posts by Oldgazer
Old Apr 14, 2015, 04:04 PM
Joined Mar 2015
hm ok, cant find my multimeter atm but ill redo the test over it.
But the reason i was thinking it was the regulator is because im getting stuck after installing firmware and starting up mission planer and hitting connect im getting stuck at "Got param rc1_min" and after some reading i've found that people are saying thats an common error when the voltage regulator is broken.
http://imgur.com/AgaK14v
Old Apr 14, 2015, 04:15 PM
Oldgazer is offline
Oldgazer's Avatar
Joined Dec 2013
So my next question is how are you connecting? USB or telemetry radios?
Old Apr 14, 2015, 04:18 PM
Joined Mar 2015
im connecting to my computer using USB with the GPS/Compass connected to the APM
Old Apr 14, 2015, 05:00 PM
Oldgazer is offline
Oldgazer's Avatar
Joined Dec 2013
If your GPS and compass are working, the 3.3 volt regulator is good...
Old Apr 14, 2015, 10:58 PM
Joined Mar 2015
Hm ok? I don't know if the gps and compass is working since every time I try to connect the apm to any computer I get the error I've told you about.
If not the voltage regulator, then what could we wrong?
Old Apr 15, 2015, 11:37 AM
Joined Mar 2015
tried leaving it on for a longer time but it was still stuck at the same place:/ tried reflashing firmware also tried reflashing bootloaders
Old Apr 15, 2015, 07:03 PM
Oldgazer is offline
Oldgazer's Avatar
Joined Dec 2013
Ok, this is my last shot.
Disconnect the APM from every thing, RX, ESCs, GPS, and power module.
Connect the APM to your computer and try to connect.
If that fails the APM is toast...
Discussion APM 3.3 voltage regulator juano2001 Multirotor Electronics 2 Apr 08, 2015 04:13 PM
Sold Voltage Regulators, Voltage Step-down and other misc. brn2fly Aircraft - General - Radio Equipment (FS/W) 0 Jan 26, 2015 11:06 AM
Question Burnt my Transmitter Voltage Regulator .. Can I bypass it? Harasi Batteries and Chargers 18 Apr 03, 2014 06:49 PM
Discussion Big battery, voltage regulator and my v929 scotty562 Mini Multirotors 0 Feb 19, 2014 10:24 PM
Fixed voltage regulator for wallwart will my batteries see full charge? power Batteries and Chargers 3 Sep 13, 2003 12:36 PM
