Old Yesterday, 04:20 PM
JoeCatul is offline
Find More Posts by JoeCatul
United States, CT, Hartford
Joined Feb 2015
Originally Posted by rcflo View Post
+3 same story here. One hot air rework + thin tip (fast heat up) station for electronics traces and wiring, and one 80+ watt monster for the big stuff like esc/pdb leads/lipo connectors.
For soldering, the right equipment will allow you to quickly get better
So I have the Weller 25W, I think that should be good for the light wire stuff? It apparently gets to >700 F.
I will search this thread for past recommendations; anyone have pointers to a decent one I should get if the Weller 25W isn't sufficient?
JoeCatul is offline Find More Posts by JoeCatul
Old Yesterday, 04:45 PM
--Oz-- is offline
Find More Posts by --Oz--
--Oz--'s Avatar
United States, CA, Newport Beach
Joined Mar 2006
Pretty hard to beat this for $17 + shipping, when the tip gets old, buy genuine Hakko tips.
http://www.hobbyking.com/hobbyking/s...lder%20station
--Oz-- is offline Find More Posts by --Oz--
Old Yesterday, 05:27 PM
fieliep is online now
Find More Posts by fieliep
MudMaster
fieliep's Avatar
The Netherlands, NB, Breda
Joined Sep 2014
You'll do fine with this one Joe!
Let's get you back in the air first
fieliep is online now Find More Posts by fieliep
Old Yesterday, 05:36 PM
JoeCatul is offline
Joined Feb 2015
I'll report back, hope I don't fry/burn anything.
I need some props too, fortunately BuddyRC had some and shipped it right away so I should have them Saturday. I can't wait to get this bird back in the air
I gotta say, this thread has the most helpful and encouraging people on RCG!
Old Yesterday, 05:56 PM
MudMaster
fieliep's Avatar
Joined Sep 2014
Hey guys,
this is brilliant:
Apparently people are working on being able to program the ESC's with Cleanflight! I wonder when this feature will be available?
https://github.com/cleanflight/cleanflight/issues/216
Old Yesterday, 06:15 PM
oldcougar50 is offline
Find More Posts by oldcougar50
CDN AIRFORCE ( RET )
oldcougar50's Avatar
Canada, NS, Halifax
Joined Aug 2014
Hey guys,
this is brilliant:
Excellent find Phil....+ 1 , i'm in !!
Gramps
oldcougar50 is offline Find More Posts by oldcougar50
Old Yesterday, 07:21 PM
michel_morin is offline
Find More Posts by michel_morin
michel_morin's Avatar
Canada, ON, Ottawa
Joined Oct 2014
Hey guys,
this is brilliant:
That would be cool and convenient to have all configuration / flashing using the same interface. Definitely, nice find!!
michel_morin is offline Find More Posts by michel_morin
Old Yesterday, 09:21 PM
mewert is online now
Find More Posts by mewert
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Hey guy's, I currently have a Spektrum DX9 and I'm wondering if setup with Cleanflight would be easier with a Tarranis? I have a lot of learning to do and would prefer to do it once.
mewert is online now Find More Posts by mewert
Old Yesterday, 09:30 PM
sur3fir3 is offline
Find More Posts by sur3fir3
United States, FL, Gainesville
Joined Jun 2013
Does anyone have the cleanflight settings chris ships on the CF226?
sur3fir3 is offline Find More Posts by sur3fir3
Old Yesterday, 09:56 PM
tekyguy is offline
Find More Posts by tekyguy
Can't get enough RC!
tekyguy's Avatar
United States, OH, North Ridgeville
Joined Jun 2014
Originally Posted by bobepine View Post
Yes, this is what it means.
Best,
Chris
Chris, any special settings when flashing blheli? Or do you leave all the defaults and simply enable dampen light? Then do an esc calibration with cleanflight? I hadn't got around to flashing the ESCs on my CF258 but now that I know they support one shot it's time to get that done and move that one to cleanflight :-)
Cheers!
tekyguy is offline Find More Posts by tekyguy
Old Yesterday, 10:40 PM
JoeCatul is offline
Joined Feb 2015
It lives! I was able to solder the loose wire back onto the ESC (that was harder than I thought, took a relatively long time for the existing solder on the ESC to melt and accept the wire). I made sure the heat shrink between the ESC/wires and the frame was still intact, and added a little electrical tape to cover what I cut. I'm not sure how good the solder joint is (it's possible I have a cold joint) but it seemed reasonably solid. If that motor starts acting up in the future, I know the first thing to check.
Anyhow, I fired it up without the props and all the motors seemed to be spinning well. Put on the props, tightened it (really well, I think I'm anal about this now, wonder if I could be tightening too much?), and fired it up in the basement. Everything looked to be spinning perfectly, even got it hovering just above the ground for a few seconds. This is looking good, I'll know better when I have a chance to take it outside tomorrow morning (it's getting close to midnight now).
I've seen some pictures of people with M5 lock nuts instead of the regular prop nuts; would those be more secure somehow? I'm still bummed that one came off on my maiden flight, even after I double-checked them all, so wondering if I should switch to these lock nuts?
I really hope this is it, no more issues, and I can start really learning to fly this bird. Thanks so much for the pointers and guidance everyone; I'll report back in about 10 hours.
Old Yesterday, 10:47 PM
Rcnewbiechris is offline
Find More Posts by Rcnewbiechris
Scratch-Built 250 Quads + 450
United States
Joined Sep 2012
M5 locknuts are the best thing to have, they don't unscrew like the prop cones and normal nuts
Rcnewbiechris is offline Find More Posts by Rcnewbiechris
Old Yesterday, 10:49 PM
joelwhite is offline
Find More Posts by joelwhite
Joined Sep 2014
The nyloc nuts give some tension on the nut. Without that as soon as it loosens at all its gone.
For me locknuts are the go to prop hold down. If you run clockwise and counterclockwise threads the bullets are fine.
joelwhite is offline Find More Posts by joelwhite
Old Yesterday, 11:14 PM
JoeCatul is offline
Joined Feb 2015
I did pick up some M5 0.8 nylon lock nuts from the hardware store earlier this evening, but they only screw down a little bit and then stop - tried it on CW and CCW motors. Maybe I need to get these lock nuts (I want black anyway )?
Old Today, 02:33 AM
MudMaster
fieliep's Avatar
Joined Sep 2014
Good Job Joe! And you are right. If it starts dipping in the direction of the arm you just fixed. First check this solder joint.
In this video Chris shows that he tightens the cone with just a few pounds of pressure with a tool. I used to tighten them too much. This wore out the thread on the prop-adapters rather quickly. So I follow Chris's advise here now. Not too tight but tight enough pressure on both normal nut & cone. Have some lock nuts but don't use them and no problems with loose props. So when you tightened them well and even double checked, I really don't understand why it came off.
Have fun flying!
Sold FS: Armattan 355 Package $250 initials Aircraft - Electric - Multirotor (FS/W) 0 Jan 12, 2013 05:21 PM
Sold Armattan M355 RTF Creepy1 Aircraft - Electric - Multirotor (FS/W) 1 Jan 09, 2013 12:54 PM
Sold New flight tested CNC Armattan 355 littlepiston Aircraft - Electric - Multirotor (FS/W) 2 Jan 06, 2013 07:52 PM
Sold Armattan M500 Custom Build Bryan's Flyin Aircraft - Electric - Multirotor (FS/W) 5 Jan 06, 2013 06:55 PM
Sold Armattan V3 CNC 355 RXR (The first one!) bobepine Aircraft - Electric - Multirotor (FS/W) 4 Jan 05, 2013 02:48 PM
