Old Dec 02, 2011, 11:04 AM
EJETS-II is online now
Find More Posts by EJETS-II
TeamSiam
Graz
Joined May 2007
New Product
The wait is over, JETFAN-80 is released and on stock!
Hi caps,
Again we are proud to introduce our brand new JETFAN-80.
The units are on stock, the first 100 pieces will be priced with €88,- incl. the VAT,
for US the VAT will be removed always.
Same for Canada or similar countries, named "Over seas"
After the first batch of 100 JETFAN-80, we have to increase the pricing maybe!
See the pics and the table of released motors.
Incredible values included!
Could some one imagine, how big the "BINNNNGGG" was, as the big 200 Amps ESC said NO, at more than 50.000 rpm's?
The ESC lost one phase, and the motor was breaked in within Milli-seconds.
This happened at a measured thrust of 5,2 Kilos and 12s 5500 with 124 Amps.
Nothing happened to the fan, only the nut of the shaft adapter gets loose. But the screw of the spinner was holding anything in place,
After this, we continued the rest of the testing with this unit, and i will use it in my HABU-32 up to 10s!
So this is at the moment the maximum thrust 2b reached, only for us of course (have no better ESC at the moment)
BUT we definately do not release the usage of this fan for more than 4 Kilos of thrust at the moment, we have to make more tests 2b sure. It's to dangerous for us as a manufacturer, so we have to be on the save side!
Enjoy the pic's.
YOU CAN USE MOTORS UP TO 41mm outside diameter, the outer dimensions of the new JETFAN-80 are exactly like the Delta-V 32, so you don't have to change anything but the unit. Also the origin thrust tube can be used again!
If somebody is flying a HABU-32, of course
EJETS-II is online now Find More Posts by EJETS-II
Old Dec 02, 2011, 03:07 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Excellent news Rainer!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Dec 02, 2011, 03:36 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Hm.....how much thrust and kw does the Stumax 80mm actually provide on 11blades??????
NS.
neversommer is offline Find More Posts by neversommer
Old Dec 02, 2011, 03:42 PM
Mike Warren is offline
Find More Posts by Mike Warren
Not Funny......
Mike Warren's Avatar
United States, CO, Redstone
Joined Dec 2010
NS.
Hm...guess you would have to ask Stumax
Mike Warren is offline Find More Posts by Mike Warren
Old Dec 02, 2011, 04:02 PM
Luzern/Switzerland
Joined Aug 2008
Stick your tongue in somewhere else
I guess I would have 2, don't it?
Let's see
NS.
Old Dec 02, 2011, 05:54 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
This is not a Stumax NS!
We know that! It's something else.
I personally will probably get one to play with.
But my Stu will fly my plane!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Dec 02, 2011, 07:20 PM
mce73 is offline
Find More Posts by mce73
Sweden, Stockholm County, Stockholm
Joined Jun 2005
Is the rotor for this fan specially made for this? 9blades ?
The original E-flite rotor has 5blades.
Tamjet has a remaked Wemo rotor with 6blades.
I dont fully understand what rotor has the best performance.
/Micke
mce73 is offline Find More Posts by mce73
Old Dec 02, 2011, 07:36 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
/Micke
Are you after the best performance or noise reduction???....As a rule---This fan will produce less noise but not be as efficient as other fans that produce more noise...Noise vs performance seems to be a compromise between the two...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 02, 2011, 08:11 PM
mce73 is offline
Joined Jun 2005
Kevin Greene:
Ok..
I am after a fan / motor combo for the Habu32 that is faster than stock without breaking the bank.
i have also looked at Megamotor combos with the original E-flite fan.
A big advantage with this fan is that it can take bigger diameter motors.
Old Dec 03, 2011, 04:53 AM
TeamSiam
Graz
Joined May 2007
Again the same video!
Hi caps,
No idea who already has seen this.
It's the very first prototyp of the JETFAN-80, made in a few minutes by cutting down a JETFAN-90 rotor and implantig in an old 80mm prototype shroud.
here we didn't balance the rotor or motor, because we simple had no time for it.
The motor is an old MEDUSA 36-75- 2300KV. Really old with bad bearings!
But i suppose it has only 2100 KV's under load, because in the meantime the HEt-700-60-2085 or the Medusa36-75-1 with 2080 does have the same thust and Amps.
Our released JETFAN-80 out from serial parts is running a bit smoother, but the noise is always pending by the inlets and thrust tubes.
I personally do not know how much the influence of the gap between the inlets at the HABU-32 is, but we will make tryouts with "closed gap" too.
Enjoy the video, here the Medusa takes 89Amps build in!
Rainer
Habu-32 with JETFAN-80.mp4 (1 min 50 sec)
Old Dec 03, 2011, 09:42 AM
Chuchuf is offline
Find More Posts by Chuchuf
Joined Aug 2009
Very nice Ranier.
Nice 6S setup.
Tell Peter that the Habu will land a lot slower than he did in the video with full flaps....lol
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Dec 03, 2011, 09:55 AM
TeamSiam
Graz
Joined May 2007
Landing on the video
Hi,
Yes, Peter got it in the meantime! Saw personally many fine landings in the meantime.
Now i will be ready to fly my own HABU within a few days, so then i can make the same experiences!
Best greetings, Rainer
Old Dec 03, 2011, 01:24 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
RC Speedo says 134 MPH on the first high speed pass (at my local temperature in Atlanta)
rfodor is offline Find More Posts by rfodor
Old Dec 03, 2011, 02:22 PM
mce73 is offline
Joined Jun 2005
rfodor:
What is the setup ?
Old Dec 03, 2011, 02:33 PM
rfodor is offline
Joined Feb 2009
rfodor:
What is the setup ?
You have to ask Rainer, it is his setup. I only dopplered his video.
For Sale FY 30A Inertial attitude balancer-released on 25/August keyer Aircraft - General - Miscellaneous (FS/W) 9 Aug 14, 2012 01:05 AM
Discussion What is the wait time on return/exchange requests? crypto666 Nitro Planes 3 Oct 21, 2011 08:38 PM
Discussion Moore on Okare-yes, you will wait longer MtnGoat Life, The Universe, and Politics 13 Sep 25, 2011 09:32 PM
Discussion Tulare officer arrested, released on DUI charges MILLERTIME Life, The Universe, and Politics 10 Mar 04, 2011 10:04 AM
