Old Nov 11, 2006, 06:23 AM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Show us your scratchbuild foam (Motor) Glider !!!
Guys,
I believe that (motor) glider models are way too underrepresented in the scratchbuild-foamy section!
Do we really want to accept that those balsa/fiberglass builders look down at us and say that our foamies fly just because of a high thrust to weight ratio???!!!
So here you can SHOW THE WORLD YOUR MODEL and prove what a determined foam scratch builder can do with a sheet of blucre/depron and an x-acto knife!!!
I'd be surprised if we can not soar and thermal the out of those 300$ ARF models.
chara is offline Find More Posts by chara
Old Nov 11, 2006, 08:11 AM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
ok, I'll make the start...
Made a full profile wing (85cm span) a while ago to experiment a bit with wing building techniques.
My ultimate goal is to make a little scratch built foam motor glider with the best possible glide performance. So I've cut out a few pieces of foam to form a simple streamlined fuse and some tailfeathers...
So... here is "MOSE-01" (MOtorSEgler - motor glider).
RET control, 165g AUW. A bit heavy I could have done it probably around 150g if i took more care.
Did not maiden it yet cause the weather sucks...
Old Nov 11, 2006, 10:32 AM
FatBeech is offline
Find More Posts by FatBeech
FatBeech's Avatar
Bavaria, about 45km from Neuschwanstein-Castle
Joined Nov 2006
Nice and Well done!
Nach wieviel Weissbier ist das entstanden?
Gruss aus Kempten,
Ernst
FatBeech is offline Find More Posts by FatBeech
Old Nov 11, 2006, 12:20 PM
oldcoot88 is offline
Find More Posts by oldcoot88
Joined Dec 2002
Nice lookin' bird there, Chara. With that huge rudder coupled with the polyhedral, it's probably gonna be pretty touchy and easy to over-control. Might need to minimize rudder throw and/or reduce rudder area.
Bill(oc88)
oldcoot88 is offline Find More Posts by oldcoot88
Old Nov 11, 2006, 12:48 PM
WrongwayII is offline
Find More Posts by WrongwayII
Lancaster, OH
Joined Mar 2004
Very nice looking bird, Chara. What motor and prop are
you using. I think you're right. A motor glider can be a lot
of fun. I'll be watching to read of your adventures with
your plane. Meanwhile, I'll see what I can start here.
WrongwayII is offline Find More Posts by WrongwayII
Old Nov 11, 2006, 12:50 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Ernst, thanks! 3 Weissbier, dazu 3 Weisswurst und Brezn ... Gruß zurück
Bill, thanks for the tips! I'll bring a cutter on the maiden flight so I can adjust the fin sizes. Dihedral was a bit small initially so I readjusted it...hmm, maybe I've overdone it. Hope the weather will be better tomorror!
Old Nov 11, 2006, 01:09 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
WWII thanks!
the motor is a little BL inrunner (12mm diam. type) with 3500kv. Pulls around 4A on 3 cells. The prop is a 3x3 cam slim from Graupner.
Come on guys! whoever has built something that glides and soars nicely and is out of foam, please POST IT HERE!
Old Nov 11, 2006, 02:25 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
This wing didn't take long to build, I think I spent longer researching the aerofoil than I spend building it.
I hot wired a couple of EPS wings, cut and bevelled the polyhedral and used carbon rods top and bottom in the centre section for strength and then covered in packing tape.
I didn't think it was going to measure up against a balsa glider wing, but when I weighed a similar sized wing from a similar sized glider it was exactly the same!
RobinBennett is offline Find More Posts by RobinBennett
Old Nov 11, 2006, 02:31 PM
Water Boy is offline
Find More Posts by Water Boy
Water Boy's Avatar
Greenview,IL
Joined Feb 2006
Chara looks great! This is definatly something I have benn working on my self. I have taken some planes for a Global Easy Answer and started building it from Pro board. Center wing is sorta done and fuse is mostly done. Looking to use an Essky 400xt for the power plant on it. Will post pics later on today.
I am surprised more people are not building gliders. I learned to fly on one amd love how they just float and seem to fly forever, power up to elevation and cut the juice and glide around.
Harry
Water Boy is offline Find More Posts by Water Boy
Old Nov 12, 2006, 08:40 AM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
thats great Robin! how did it fly?
Hot wiring gives you lots of options, what kind of airfoil did you use finally?
I've made some research as well for low Re profiles, but in the end I had to make a compromise between simplicity of build, structural strength and aerodynamic efficiency. It is a kind of Clark Y what came out finally.
Old Nov 12, 2006, 08:55 AM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
WB I'm looking forward to see your pics! You're right! I wonder myself why I haven't hardly found a glider thead in this forum. Hope this is going to change!!!
Gliders have their own appeal: the high requirements/challenges for the designer and also the joy you feel whet they just glide silently and seem to stay up forever without having to change batteries every other minute.
Old Nov 12, 2006, 10:18 AM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
I started this mod on my Alula last night. Adding that much weight way out there on a sub 4 oz plane doesnt seem too bright though. I'm going to shorthen it up alot to get the battery back on the CG.
My F5D plyon racer was meant to be a sloper. The airfoil was not very efficient "semi-symetrical", so it was religated to a parkflyer. My feathercut will fix the efficiency problem on my next try.
Boz
theBOZman is offline Find More Posts by theBOZman
Old Nov 12, 2006, 02:35 PM
Sussex, UK
Joined Jun 2004
For the first flight I used the stock slow stick motor and it was great - 15 minutes of floating around the field while lying on my back in the hot sun. Then I noticed some dihedral that wasn't there before, then there was a LOT of dihedral, then it came down like a lawn dart...
I had originally used only plastic box strapping as a top spar (the plastic strip that comes wrapped around boxes of printer paper) with strapping tape as the bottom spar. I think the sun softened everything until the spar could buckle.
As it was a foamy I just bent it straight and melted a slot for CF rod. After that it was much stronger.
I'm not much of a glider pilot, and it's built for a competition that requires a direct drive speed 400 and 7 AA cells from the 'everything one pound shop', so I don't often catch thermals or stay up long. One time I did it got so high I nearly lost it and ripped the tail off trying to get down.
SD7037 - it seemed popular and I wasn't interested in high speeds, which is something it's not supposed to be good at. After a couple of evenings research I got rather lost and unscientific but it looks OK, and probably more accurate than a balsa wing with sagging film covering.
It did come out much like a Clark-Y - the nice curvy underside ended up mostly flat, partly due to the at the 8" chord and partly due to the tape.
Old Nov 12, 2006, 03:52 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Boz
Boz, that sounds good. Hope the electrification of your Alula works out great - that thing is known to be very sensitive on CG position to fly nice.
PS: actually it was your shrike-alike thread that inspired me to make a motor glider...
Old Nov 12, 2006, 04:11 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Good news on MOSE-01!!!
Today the weater cleared a bit - the rain clouds were blown away by 50mph(!) winds (...well, about ). Absolutely awful conditions for a maiden flight, especially for such a light model. But patience is not my strength...so I gave it a try.
The wind was so strong that it ripped the plane out of my hand before I was ready to launch. But, off it went climbing 15m in a second ...wow! Turned the nose into the wind and needed 100% throttle to keep it on the spot. Looked much like kite flying... It flew extremely stable considering the conditions.
Control response was pretty good and I was able to counter the heavy gusts.
Can't wait to fly it on a normal day!
Here is the footage that we took ...
http://www.rcgroups.com/forums/showt...86#post6376167
Discussion Show Us Your Easy Glider! Capgun_Slim Foamies (Kits) 231 Aug 03, 2014 02:07 AM
Show us your airplanes! sneu Electric Plane Talk 21 Sep 20, 2009 01:03 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your wildest Zagi Dave Seay Foamies (Kits) 9 Jan 23, 2002 01:22 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
