Old Feb 04, 2015, 09:28 PM
jpt62 is offline
Find More Posts by jpt62
Joined Feb 2012
Build Log
Look what I found..
Was out lurking around the LHS and saw this real beat up box. Asked the owner about it and he said he has had it over 5 years.. Never got around to building it.. So I asked what he wanted for it.. so 3 bills later I got a Great Planes PT 17..
jt
jpt62 is offline Find More Posts by jpt62
Old Feb 04, 2015, 09:31 PM
jpt62 is offline
Joined Feb 2012
the goodies
jt
Old Feb 04, 2015, 09:36 PM
jpt62 is offline
Joined Feb 2012
Now all I gotta do is figger out the power system... Thinking 5 or 6s and 4 or 5000mah packs.. lookin at the other builds here it looks like this baby will come out at 13lbs. any of yall got ideas as to an appropriate motor?? moto-calc 8 isnt being cooperative.. grrr
jt
Old Feb 05, 2015, 10:52 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
One of my favorites for reliable power iss the Scorpion 4025-12 (440KV). There is a new SII series now but basically identical specs. A 16/10 2 blade should show around 1400watts at 58a or so on 6S, I used 80A Turnigy Plush Esc and Turngy Megabec8 Bec(2s only) with complete success. Iran the Zippy 5000/40C/6S for the esc and usually an 1800/2S/20c for the bec. A HK alternative motor would be the SK3 5055-430 with a 16" or the Scorpion 4025-16 with 18/10 or 12 pitch prop. fwi Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Feb 07, 2015, 08:18 PM
jpt62 is offline
Joined Feb 2012
can i use the turnigy sk3's with the same numbers? ie 40 25 at what ever the kv is??
Those Scorpions are nice but a tad pricey... Remember this is a Trainer aircraft.. not looking to do 3d or wild aerobatics.. just something that will replace the 91- 120 slimers...
jt
Old Feb 07, 2015, 10:09 PM
jpt62 is offline
Joined Feb 2012
Wing joiners are under pressure... now to find the covering iron.. gotta remove some storage wrinkles..
jt
Old Feb 08, 2015, 01:21 AM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
JP
old shop , super cludderd , nice people and tons of stuff (treasures ) in hiding ?
Did you see the stuff in the small room in the rafters ?
Great kits that belong to the owners
Ldm is online now Find More Posts by Ldm
Old Feb 08, 2015, 06:41 PM
jpt62 is offline
Joined Feb 2012
Yea them is the kind of shop I like to prowl around in.. Been in a couple that you had to watch where you were putting your feet..
Jt
Old Feb 08, 2015, 09:41 PM
jpt62 is offline
Joined Feb 2012
wings are joined.. Nice thing about joiner pockets is you just pour the Epox in and shove the joiner in and scrape the excess onto the roots..
jt
Old Feb 09, 2015, 11:32 PM
jpt62 is offline
Joined Feb 2012
Dont you just hate it when the string breaks when you are trying to fish the servo leads through 68 miles of wing?? this gets it rethreaded...
jt
Old Feb 10, 2015, 07:56 PM
jpt62 is offline
Joined Feb 2012
got some more work done.. gotta hit it while I feel "normal". wings are almost done just have to install the strut anchors. started work on the fuse today.. gotta see what this "lil" buger is gonna look like...
jt
Old Feb 10, 2015, 08:21 PM
Joined Oct 2008
The Sk3's I've purchased have all proven to reliable performers. No reason to think the 5055-430 won't deliver 1400w or so to fly this plane.
I prefer the SK3 over any of the other motors offered by HK now.
I mention Scorpions because they are 100% reliable, the extra costs warranted on major builds. I;ve owned 14 Scorpions to date, never had an issue with any. Doug B
Old Feb 11, 2015, 05:40 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Coming along very well jt. Much faster than the 24.
J
J Morgan is offline Find More Posts by J Morgan
Old Feb 11, 2015, 10:44 AM
Joined Oct 2008
jpt62 You match up motors with the motor weight and KV. Its sometimes confusing, ie: Scorpions give its model # by the armature measurement, SK3 series are measurments of the outside casing and length of the casing. As long as the weight is similar and the KV is similar they should perform about the same levels at the same amps at the same voltage. The Biggest difference between a SK3 and a Scorpion is the amps they can safely handle continuously. Most SK# in these sizes are rated around 65A max, Scorpion's superior magnets and build allow 90A. The Scorpions will also be at least 10% more efficient, SK3 running around 75%, Scorp's around 85%. fwiw Doug B
Old Feb 11, 2015, 08:07 PM
jpt62 is offline
Joined Feb 2012
yea John dont have as much work on this on.. Plus a lot les motors to get mouinted and plumbed..
jt
Found Found what I was looking for--Looking for a four stroke. fastflyer300 Aircraft - Fuel - Engines and Accessories (FS/W) 7 May 06, 2012 12:11 PM
Look what I found for $50 rrowley Thermal 4 Sep 15, 2002 05:32 PM
Been looking for scale lettering...found just what I needed. mefly2 Scale Kit/Scratch Built 0 Aug 26, 2002 03:52 AM
Look at what I found on RCO Eco8gator Electric Heli Talk 2 Feb 23, 2002 11:31 AM
look what i found Antyoo Electric Heli Talk 7 Jul 11, 2001 06:45 PM
