Old Dec 10, 2015, 02:47 PM
bh1989 is offline
Find More Posts by bh1989
United States, IL, Oswego
Joined Oct 2011
90mm EDF Setup questions
Alright guys I have purchased a 90mm Bae Hawk from a fellow member on this site and I should receive it tomorrow. I have built and flown quite a few EDF jets in the past. My most recent on being a Habu 32 on 6s and then I upgraded to 8s. Anyway, the sale included retracts and a few servos which I am framiliar with. But it came with a DR.madthrust alloy fan. here is a Link for the fan..
http://www.hobbyking.com/hobbyking/s...Rotating_.html
my plan is to run it on 6s, possibly 7s but 8s will be too much RPM. It came with a HobbyKing ESC but I'm going to set that aside and use a castle creations ESC I have for it.
my questions are
has anyone ever used one of these before?
if so, how was it?
is it worth keeping or should i sell it and go with something more well known?
I am tempted to try the fan in the plane, but once again I have never used one of these before.
thanks for your help!
Bobby
bh1989 is offline Find More Posts by bh1989
Old Dec 11, 2015, 02:21 PM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
I have one in my taft cobra, works fine. There are options out there that will get better performance, but price is a factor. You can get more performance with another unit, but you will also spend more too.
Also these units are notoriously heavy. You just need to keep that in mind when determining what works best for you. The Mercury Alloy 90mm 6s unit is more than 250g lighter than the Dr. Madthrust EDF unit.
bandetlol is offline Find More Posts by bandetlol
Old Dec 11, 2015, 03:03 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Do a search on here (RCG) regarding your fan They are known for having loose or stripped stator mounting holes, so check yours out.
The Jetfan 90 is a quality EDF. The carbon fiber housing is very light.
For 8s, the most common setup is the JF90 with the HET 700-68-1500 motor, with a good 100Amp ESC (Castle, hobbywing Plat Pro,)
The set up is 3.8kg thrust at 90A (on the bench). About 100A installed in the jet.
This set up is flying most of the popular 90mm jets out there. It's middle of the road, price wise.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Dec 11, 2015, 04:32 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
The JF90 with the HET 700-68-1500 motor on 8s, is what I'm putting in my
FLY FLY F-86 Sabre.
A great combo!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 11, 2015, 07:00 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
my questions are
if so, how was it?
Bobby
I would only run this on 6s as it will already draw over 100amps with a full battery.
Run a couple packs through it first on the ground and if it hangs together that long it should be fine. Dr Lander fans can be great or they can be ??? Depending on how they were assembled.
4stripes is offline Find More Posts by 4stripes
For Sale V1 Vector-Thrust EuroFIghter 90mm EDF; 12 blade changesun 6S setup NickFox Aircraft - Electric - Jets (FS/W) 3 Apr 20, 2015 10:27 PM
Discussion Mixing / Setup question for 90mm F18A/C exceed model NickFox Large EDF Jets 1 Mar 24, 2014 02:34 PM
Sold Dyn-E-Max EDF Setup & RC Lander 90mm EDF w/ Motor FL62 Aircraft - Electric - Jets (FS/W) 0 Dec 16, 2010 10:38 PM
Discussion 90mm EDF 8s setup?? BpwrJet Medusa Research 10 Jul 10, 2009 05:09 AM
Discussion 90mm edf A123 setup suggestions please! Erik v. Schaik Electric Ducted Fan Jet Talk 1 Apr 11, 2007 02:56 PM
