Old Sep 28, 2015, 09:58 AM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
ROTOX X Atom/Raiju PID's ONLY!!!
Just wanted to start a thread dedicsated to only users PID's for these two quads.
It is just too difficult to search through the huge threads dedicated to these micros and parse out the PID's for tuning/testing.
Please add your PID's here in this thread along with version of Cleanflight, and what controller you are using.
Use screen captures, hand typed, or CLI dumps, whatever is your preference!!!
bluemeane is offline Find More Posts by bluemeane
Old Sep 29, 2015, 09:16 AM
bluemeane's Avatar
Joined Apr 2007
From Marty:
Here are the PID's i'm currently using, along with the hex file for betaflight for flashing to the FC, and a CLI dump of all my settings (warning high rates). This is a kit sn20a rx122 setup with naze32. If you get any oscillations I would recommend dropping P values by .1 or .2 as required.
# DUMP
# version
# BetaFlight v2/NAZE 1.10.0 Sep 19 2015 / 21:53:07 (7113e66)
# dump master
# mixer
mixer QUADX
mmix reset
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature FAILSAFE
feature ONESHOT125
# map
map AETR1234
# serial
serial 0 1 115200 57600 0 115200
serial 1 1 115200 57600 0 115200
# led
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 0,0:::0
led 15 0,0:::0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set emf_avoidance = 0
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = 0
set input_filtering_mode = 0
set min_throttle = 1150
set max_throttle = 1850
set min_command = 1000
set servo_center_pulse = 1500
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set retarded_arm = 0
set disarm_kill_switch = 1
set auto_disarm_delay = 6
set small_angle = 25
set fixedwing_althold_dir = 1
set reboot_character = 82
set gps_provider = 0
set gps_sbas_mode = 0
set gps_auto_config = 1
set gps_auto_baud = 0
set serialrx_provider = 1
set spektrum_sat_bind = 0
set telemetry_switch = 0
set telemetry_inversion = 0
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_coordinates_format = 0
set frsky_unit = 0
set frsky_vfas_precision = 0
set hott_alarm_sound_interval = 5
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 33
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = 0
set current_meter_type = 1
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 90
set max_angle_inclination = 500
set moron_threshold = 32
set gyro_cmpf_factor = 600
set gyro_cmpfm_factor = 250
set yaw_control_direction = 1
set pid_at_min_throttle = 1
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set tri_unarmed_servo = 1
set servo_lowpass_freq = 400
set servo_lowpass_enable = 0
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_kill_switch = 0
set failsafe_throttle_low_delay = 100
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = 1
set baro_hardware = 0
set mag_hardware = 1
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
# dump profile
# profile
profile 0
# aux
aux 0 0 1 1700 2100
aux 1 0 0 900 900
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 90 90 100 -1
servo 1 1000 2000 1500 90 90 100 -1
servo 2 1000 2000 1500 90 90 100 -1
servo 3 1000 2000 1500 90 90 100 -1
servo 4 1000 2000 1500 90 90 100 -1
servo 5 1000 2000 1500 90 90 100 -1
servo 6 1000 2000 1500 90 90 100 -1
servo 7 1000 2000 1500 90 90 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = 1
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = 1
set deadband = 0
set yaw_deadband = 0
set throttle_correction_value = 0
set throttle_correction_angle = 800
set default_rate_profile = 0
set gimbal_mode = 0
set acc_lpf_factor = 4
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff = 5.000
set acc_unarmedcal = 1
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set pid_controller = 2
set p_pitch = 40
set i_pitch = 30
set d_pitch = 23
set p_roll = 40
set i_roll = 30
set d_roll = 23
set p_yaw = 85
set i_yaw = 45
set d_yaw = 0
set p_pitchf = 1.500
set i_pitchf = 0.190
set d_pitchf = 0.006
set p_rollf = 1.500
set i_rollf = 0.190
set d_rollf = 0.006
set p_yawf = 6.200
set i_yawf = 0.340
set d_yawf = 0.000
set level_horizon = 3.000
set level_angle = 5.000
set sensitivity_horizon = 75
set p_alt = 68
set i_alt = 0
set d_alt = 0
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set dterm_cut_hz = 40
# dump rates
# rateprofile
rateprofile 0
set rc_rate = 100
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 75
set pitch_rate = 75
set yaw_rate = 45
set tpa_rate = 36
set tpa_breakpoint = 1500
Old Oct 05, 2015, 10:44 AM
bluemeane's Avatar
Joined Apr 2007
Onather set of PID's
Blackjohnson thanks for the screenshot!!
Cleanflight version: 1.10
Controller: 2 Luxfloat
Old Oct 05, 2015, 10:45 AM
bluemeane's Avatar
Joined Apr 2007
Ausmarty:
Ok so it's hard to keep up with everything going on with betaflight but this is apparently the last flight control related update for a while.
I've attached the very latest betaflight Hex file for Naze, my CLI dump and a snapshot of the PID's so you can confirm your settings after the dump save (sometimes PID's don't show up for me correctly).
This is confirmed to work well for Atom users with Naze32 and SN20A ESC's with SimonK, which will be most of you I suspect.
If you don't know how it works, feel free to ask for help. Mr Buddha and moose might come up with some different PIDs for ZTW ESC's but these are mine, let us know if you have any problems.
I had to lower my Yaw P from Mr Buddhas someway down below 7 before I could remove the micro oscillations. Cycle time reading around 1000, feels very nice to me. Make sure you change the rates to your settings, check naze orientation, arm switch etc.
Thanks to BorisB and everyone working on the project! fun to play along at home.
Old Oct 08, 2015, 03:34 PM
bluemeane's Avatar
Joined Apr 2007
From Moosestang:
These are my latest pids for controller 1 using ztw 18a escs. They will probably work fine for any escs. I raised the I a little for pitch and roll and raised the D for yaw trying to eliminate the ocassional yaw out people have experienced, but i haven't had much time to really test it. This is on cleanflight 1.9, not betaflight and a 1500 looptime with accelerometer turned off. I set my rc rate 1.02, rc expo .65 and yaw expo .30. yaw expo is probably unnecessary, i'm not even sure i could tell a difference.
Old Oct 14, 2015, 08:45 AM
bluemeane's Avatar
Joined Apr 2007
From Moosestang:
That's atom red. cleanflight 1.9 with accelerometer turned off and looptime set to 1500. I set yaw I back to 45, lowered yaw p to 9, had it at 10.5 and raised yaw D to 20. I'm not sure yaw has anything to do with the rear dropping on hard turns.
Atom blue is going to get redone with littlebees, 808d lens on the cc1563 and the new motors. I might test 1 esc with blheli and it it doesn't work figure out how to flash simonk.
# version
# Cleanflight/NAZE 1.9.0 May 31 2015 / 13:17:47 (98f7549)
# dump master
# mixer
mixer QUADX
# feature
feature -RX_PPM
feature -VBAT
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -3D
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature RX_SERIAL
feature MOTOR_STOP
feature FAILSAFE
feature ONESHOT125
# map
map TAER1234
# serial
serial 1 64 115200 57600 0 115200
# led
led 0 15,15:ES:IA:0
led 1 15,8:E:WF:0
led 2 15,7:E:WF:0
led 3 15,0:NE:IA:0
led 4 8,0:N:F:0
led 5 7,0:N:F:0
led 6 0,0:NW:IA:0
led 7 0,7:W:WF:0
led 8 0,8:W:WF:0
led 9 0,15:SW:IA:0
led 10 7,15:S:WF:0
led 11 8,15:S:WF:0
led 12 7,7:U:WF:0
led 13 8,7:U:WF:0
led 14 0,0:::0
led 15 0,0:::0
led 16 8,9::R:3
led 17 9,10::R:3
led 18 10,11::R:3
led 19 10,12::R:3
led 20 9,13::R:3
led 21 8,14::R:3
led 22 7,14::R:3
led 23 6,13::R:3
led 24 5,12::R:3
led 25 5,11::R:3
led 26 6,10::R:3
led 27 7,9::R:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
set looptime = 1500
set mid_rc = 1500
set rssi_scale = 30
set min_throttle = 1100
set max_throttle = 1900
set auto_disarm_delay = 16
set flaps_speed = 0
set frsky_unit = 0
set vbat_warning_cell_voltage = 35
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set align_board_yaw = -90
set gyro_lpf = 42
set yaw_direction = 1
set failsafe_delay = 0
set rx_min_usec = 985
set mag_hardware = 0
# dump profile
# profile
profile 0
# aux
aux 0 0 0 1050 1275
aux 1 0 0 900 900
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# servo
servo 0 1020 2000 1500 30 -1
servo 1 1020 2000 1500 30 -1
servo 2 1020 2000 1500 100 -1
servo 3 1020 2000 1500 100 -1
servo 4 1020 2000 1500 100 -1
servo 5 1020 2000 1500 100 -1
servo 6 1020 2000 1500 100 -1
servo 7 1020 2000 1500 100 -1
servo 8 1020 2000 1500 100 -1
servo 9 1020 2000 1500 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set deadband = 5
set yaw_deadband = 5
set gimbal_flags = 1
set pid_controller = 1
set p_pitch = 36
set i_pitch = 53
set d_pitch = 32
set p_roll = 36
set i_roll = 53
set d_roll = 32
set p_yaw = 90
set i_yaw = 45
set d_yaw = 20
set p_pitchf = 2.500
set i_pitchf = 0.600
set d_pitchf = 0.060
set p_rollf = 2.500
set i_rollf = 0.600
set d_rollf = 0.060
set p_yawf = 8.000
set i_yawf = 0.500
set d_yawf = 0.050
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
# dump rates
# rateprofile
rateprofile 0
set rc_rate = 102
set rc_expo = 65
set rc_yaw_expo = 30
set thr_mid = 50
set thr_expo = 0
set roll_rate = 75
set pitch_rate = 75
set yaw_rate = 100
set tpa_rate = 35
set tpa_breakpoint = 1600
Old Oct 14, 2015, 09:35 AM
foremi is offline
Find More Posts by foremi
Joined Sep 2015
Where I am with a CC3D atom and DYS 1306 3100kv motors, using oneshot.
foremi is offline Find More Posts by foremi
Old Oct 14, 2015, 12:29 PM
ronin4740 is offline
Find More Posts by ronin4740
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
Subscribed to the thread! Thanks!
ronin4740 is offline Find More Posts by ronin4740
Old Nov 04, 2015, 08:30 AM
jaxflats is offline
Find More Posts by jaxflats
United States, FL, Jacksonville Beach
Joined Jul 2008
Does anyone have any Raiju PIDs they'd mind sharing? Building with a Naze32 Rev6 using 3s but I'd like to see what's out there. Thanks
jaxflats is offline Find More Posts by jaxflats
Sold Rotor X Raiju never flown *** may trade for a Naza V2 with gps Yojay Aircraft - Electric - Multirotor (FS/W) 3 Sep 04, 2015 04:13 PM
Wanted RAIJU HEX or ATOM QUAD SCUBASTEVE95 Aircraft - Electric - Multirotor (FS/W) 3 Jul 26, 2015 08:50 PM
Discussion Need help PID's CC3D on MYRCMART RCX-250 quad. bluemeane Mini Multirotors 3 May 08, 2015 12:27 AM
