Old Yesterday, 06:38 PM
Australia, VIC, Melbourne
Joined Nov 2006
I fly at anywhere from the front join of the spar cover, to the rear join, and can't tell any difference across that range. Bar the trim change needed for level flight, which alters per airspeed anyway - but in flying stability terms it is so stable overall that any change across the range is insignificant.
PeterVRC is offline Find More Posts by PeterVRC
Old Today, 04:44 AM
Joined Dec 2014
I just bought a second hand, but never flown bixler 2 which came with the following ESC/UBEC:
Unfortunately the plane came without any user manual so I can't setup the ESC properly. I tried the manual of this HK 20A ESC/UBEC, but the melodies seem to be very different.
Does anyone by any chance have the proper manual for my ESC/UBEC?
floriske.nl is online now Find More Posts by floriske.nl
Old Today, 05:47 AM
"long stretch of water..."
coongoola's Avatar
Australia, NSW, Stuarts Point
Joined Jun 2014
Yes try this one it worked for me. Let it run through the sequence to familiarise first and then start it again. After you select and set an item with the HK ESC you need to unplug the ESC from the battery and start again for the next item.
Pat
coongoola is online now Find More Posts by coongoola
Old Today, 06:03 AM
Joined Dec 2014
Thanks a lot. Will try it and let you know if it worked out.
Old Today, 06:57 AM
Joined Dec 2014
Works like a charm!
Do you happen to know what acceleration setting to use for the Bixler 2? Soft, normal or hard?
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 09:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 12:33 PM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 01:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 01:06 PM
