Old Jan 10, 2015, 04:45 AM
Australia, NSW, Nowra
Joined Dec 2014
FY41AP Servo Gain problem
Just setting up the FY41AP in my ASW-28....
When setting up the AP with the "FY-DOS-Setting-V1.1" software, I can change all the settings and save them.
When I go back in to confirm the setting changes, (after disconnecting and re-connecting) everything has been changed as I had wanted, EXCEPT for the Servo Gains...
I changed the fence distance, speed, etc. etc and they all save and come up the next time I connect the software.
Every time I connect the software, the Servo Gains are zero....
What am I doing wrong???
Plums is offline Find More Posts by Plums
Old Jan 11, 2015, 03:38 PM
Joined Dec 2014
I have discovered that using the OSD to program the 41AP works, and the gains stay where I set them.
It's only when using the GCS or FY-DOS software to read the AP that the gains always read zero....
Anyone else have this problem???
Old Mar 22, 2015, 11:41 AM
Joined Mar 2015
I have exactly the same problem.
I am suspecting that there is something wrong with my unit. Even if you set values in the "FY-DOS-Setting" software, and it says Gain value successfully set, when you check that value in the OSD display, the OSD displays a different value. Further, I dont think that the values you set in the OSD display has an actual effect on the device.
Have you had any progress on your side resolving this problem?
andreas82 is offline Find More Posts by andreas82
Help! Problems with motor and Gain lacombe Power Systems 5 Dec 30, 2014 08:51 PM
Discussion Turnigy Open9x and gyro hk401B gain problem. Almaz Electric Heli Talk 0 Aug 05, 2014 10:31 PM
Discussion Turnigy Open9x and gyro hk401B gain problem. Almaz Mini Helis 0 Aug 05, 2014 10:17 PM
Discussion F550 throttle gain problem with Naza v2 andycorleone Multirotor Electronics 1 Jun 16, 2014 09:00 PM
Discussion Camera OSD / FY41AP problem jasonyyd FPV Equipment 2 Jul 21, 2013 01:33 AM
