Old Jul 02, 2014, 08:42 PM
United States, CA, San Diego
Joined Oct 2013
Anybody used non-stock 3 blade props on the stock spinner? If anybody has recommendations that have worked would appreciate it.
deadzone is offline Find More Posts by deadzone
Old Jul 02, 2014, 08:58 PM
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
The GWS 7x3.5x3 works OK, but only on 3s. You can use the stock nut and a couple 3mm washers to space it off the motor. Don't need the middle piece of you do it this way.
Kman
kman24 is online now Find More Posts by kman24
Old Jul 03, 2014, 07:23 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by thosmosis View Post
I don't get it. Rather than two batteries. Why not just 3s 1000mah?
Weight distribution
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jul 03, 2014, 11:59 AM
Joined Oct 2013
Originally Posted by Saxguy1000 View Post
Weight distribution
Don't think that is necessary. I get perfect CG with my Admiral 1300mah 3s in the battery compartment, just moved back about 10-20mm. I also have the Orange Gyro receiver.
Old Jul 03, 2014, 02:36 PM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
No issues here with 3s 1300.
Diesel6401 is online now Find More Posts by Diesel6401
Old Jul 03, 2014, 03:11 PM
"Champ'ion Newb"
thosmosis's Avatar
United States, WA, Vashon
Joined Sep 2013
I have had luck with the 3S 1000mah from Admiral. Pushed forward. And a couple (4) quarters glued to the foam nose under the cowl...
thosmosis is online now Find More Posts by thosmosis
Old Jul 06, 2014, 01:20 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
You probably haven't changed out your motor to a heavier 3-4S with a 40-amp esc.
Old Jul 06, 2014, 05:35 PM
Joined Oct 2013
I put in a HURC 30A ESC. Battery is 3s 1300.
Old Jul 07, 2014, 08:53 AM
Virginia Jim's Avatar
United States, DC, Washington
Joined Mar 2011
As I had contributed earlier in the thread (#1490), I decided to put in a new motor and larger 3-blade (8x6). I then was considering what 3S batteries to use. For the heck of it, I put a 500mah Zippy that I have for my Inverza in this and it was fantastic. But, it gave me about 3 minutes flight which is, obviously, not good enough...
SAX:
I was very impressed with your description and photo documentation of your effort to obtain more mAh for your more powerful motor/ESC system. Not only did you illustrate the placement of your parts (very helpful for those wishing to duplicate), but your approach reflects your willingness to THINK OUT OF THE BOX. Yea, I really like that. Keep your ideas and your sharing comin. I'm lovin it.
VJ
Virginia Jim is offline Find More Posts by Virginia Jim
Old Jul 07, 2014, 09:18 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by Virginia Jim View Post
SAX:
VJ
Thanks, VJ. Not totally new thoughts on my part, but the result of spending the winter on forums! The FMS T-28, which I am assuming that is just like the Airfield--if not the same rebranded--has a cg at 45mm rearward from the forward tip of the wing at the fuselage. On my plane, it's dead center of the front (student) pilot. This is what I was shooting at trying to hit that balance point. By experimenting with shifting the 1300mah battery, the 1000mah battery it would not hit the mark. So, I saw the area underneath the canopy and saw that my 500mah fit. That's what got me to trying it and it works great. I'm now contemplating putting in aircraft lights, but can't decide if I want to add another more weight to the already fine flyer. I'm sure I will, but I want flaps, too, so hey. Can pigs fly?
Sold Airfield Extreme Detail 4-Channel Remote F4U Corsair 800mm (31.5") Mikemynameis Aircraft - Electric - Airplanes (FS/W) 2 Jul 06, 2011 11:50 PM
Discussion 800mm T-28 varian Nitro Planes 2 Jun 26, 2011 01:32 PM
