Old Aug 07, 2015, 05:30 AM
Shifty is offline
Find More Posts by Shifty
UK
Joined Oct 2006
Setting throws on combat wing?
I'm no expert but I'm assuming that at some point when increasing the throws you'll get to a point where any more increase does nothing (other than add drag?), so my question is what should I be looking for when doing this? This being a combat wing I want aggressive, fast movements as opposed to smooth flight so probably want my throws on the longer side of things.
This particular wing is a "Flyingwings Storm SL" which I no longer have the manual for, and my TX is a DX6i.
Not sure if it's throw related but this wing seems to axial roll off centre and quite slowly (even in a full dive), how can I speed up and centre the axial roll?
Shifty is offline Find More Posts by Shifty
Old Aug 07, 2015, 11:05 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
To get best performance from a combat wing:
Nail the CG! If you are nose heavy the wing will feel heavy and roll off center. Do a "Dive Test" and change the balance point (CG) accordingly by adding or removing weight to the nose (or TE) of the glider. Test again and adjust as many times as you need to get a nice neutral (or very slight nose heavy) balance/CG.
Roll: Adjust the elevons mechanically so you have substantial Aileron throw (25-30+ degrees each way) and make sure they have equal travel each way. It is hard to have too much aileron throw.
Pitch: If your elevons are producing enough aileron throw, as per above, you will need to tone down the elevator throw to something much less. Most folk will use 100% aileron throw and only 25-35% elevator throw. I try to set the elevator to be able to just stall the wing at moderate speed… or just a bit less. Often wings will need a bit more down elevator than up to do inverted and outside turns/loops.
Dawson
dawsonh is offline Find More Posts by dawsonh
Old Aug 07, 2015, 11:20 AM
Shifty is offline
UK
Joined Oct 2006
Thanks, I'll give that a go.
Old Aug 08, 2015, 06:25 PM
kbstingwing is offline
Find More Posts by kbstingwing
Slope Nutz, FLY OR DIE
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
you could use this CG calculator to find the best CG for your wing.
just type in the measurement of your wing and the angle of sweep and it will give you the info you need for a good CG.
http://fwcg.3dzone.dk/
kbstingwing is offline Find More Posts by kbstingwing
Old Aug 09, 2015, 01:49 AM
Shifty is offline
UK
Joined Oct 2006
Thanks!
Discussion Parajared's guide on how to launch a flying wing using the "Throw at Your Face" methd parajared FPV Talk 3 Jul 31, 2015 06:46 PM
For Sale Wing warrior combat wing Think4WD Aircraft - Sailplanes (FS/W) 1 May 02, 2015 01:53 AM
Discussion Setting up a Flying Wing DLG on Deviation modded Walkera Devo 7e Tx on DSM2 vtdiy Radios 21 Feb 20, 2015 11:33 AM
Question "T" throwing peg on Steigeisen wing? Bodywerks Hand Launch 3 Sep 14, 2014 09:03 AM
Question set 9x up to cut throws on all switches by half ? jasonak Radios 1 Mar 26, 2014 03:18 PM
