Old Jun 17, 2015, 06:34 PM
simmler is online now
Find More Posts by simmler
United States, CA, Santa Margarita
Joined Dec 2007
There is an annular opening around the spinner. ~ 1/8" on the bottom tapering to ~ 1/32" on top. The hole for the motor wires allows air movement through the fuselage to a hole in the rear of the fuselage. There is ample room to enlarge the entry, passage, and exit holes if needed. I fly in summer temperatures well above 100 deg. I keep my motor runs below 30 seconds (200 meters in ~ 24 seconds) and so far have not had a problem.
simmler is online now Find More Posts by simmler
Old Jun 17, 2015, 06:42 PM
n0irw is online now
Find More Posts by n0irw
LSF 6632 Level II
n0irw's Avatar
United States, OK, Perry
Joined Jun 2006
Great! Thanks for the post and photos....the finished plane looks great!
n0irw is online now Find More Posts by n0irw
Old Jun 23, 2015, 06:24 PM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
I've got a new Oly III fuse on the way and will be electrifying it. I'll continue this thread with this part of the project. I'm putting a Turnigy G25 outrunner on it with a 14x7 folder...(same prop as on the E-Flite Mystique. Also using the E-Flite 60A ESC.
Old Jun 24, 2015, 01:32 PM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
While I await the fuse, what do you guys think about down thrust and/or right thrust in the motor??
Old Jun 24, 2015, 01:57 PM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
I do know the fuse sides are about 5/16" to narrow at the nose block to keep the motor between the sides. The first former is also a little narrow. In looking at widening the front end to allow the motor between the sides so I can streamline the nose a little. Also may have to turn the servo tray around and shorten it in order to get the battery in. The speed control will fit the forward compartment or I may move the #1 former back to allow the battery tisitdirectly behind the motor. Any comments??
Old Jun 25, 2015, 08:50 AM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
The fuse will be here today, but I've got to work out a few things before I start on more than the tail feathers......like the questions above.....come on guys, give me some feedback!
Old Jun 25, 2015, 02:17 PM
pnubtrnjly is offline
Find More Posts by pnubtrnjly
pnubtrnjly's Avatar
United States, OK, Norman
Joined Sep 2013
Oly III !
n0irw did you buy just a fuse kit to modify so maybe have one conventional one electric?
I havent read all this thread so apologise if my question is redundant.
How about a bottom side photo of the Teal please.
Tom
Missed the Stillwater fly last year. Promise to do better.
pnubtrnjly is offline Find More Posts by pnubtrnjly
Old Jun 25, 2015, 03:27 PM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Yes, I bought the Fuse kit to modify then I can fly it either way. I'll try to get a shot of the teal in the next couple of days Did you make it up to our glider fun fly last year at Stillwater??
Old Jun 26, 2015, 06:15 PM
Joined Dec 2007
Regarding motor thrust angles......................
The Olys I have flown, both Airtronics II and Ray Hayes II & III, all have excellent pitch & yaw/roll control inherent in their design. Areas and moments allow for trimming for a wide range of speeds, including during powered climb. That said, and being basically lazy, I installed the firewall in mine at ~ 3 degrees down and ~1 degree right thrust, and still use a very small amount of down elevator (<3/32") electronically mixed in with full throttle application. The airplanes are sensitive enough while climbing to tell you it needs slightly more down pushed when using a fresh charged battery, or when pushing the Center of Balance back a little at a time. Built straight and balanced properly, obtaining perfect motor thrust angles might not be worth the effort to find them in a very fun-very forgiving- very capable sport airplane.
I'm enjoying your process, and suspect you'll be pleasantly surprised with your version.
Old Jun 26, 2015, 07:15 PM
n0irw is online now
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Thank you for the input....I'm going to mount the motor between the sides, so have to widen it about 5/16" give or take.
Build Log Skybench OLY III build k4to.dave Thermal 818 May 31, 2014 04:26 AM
Wanted Oly II OLY IIS OLY III Dinu Toadere Aircraft - Sailplanes (FS/W) 10 Nov 22, 2013 09:43 PM
Build Log Oly II S Build log? cn0rris Thermal 146 Sep 02, 2013 02:25 PM
Question Oly II, Oly III or Oly IIs nine2fitzpatrick Thermal 27 Oct 15, 2012 11:54 AM
Discussion Oly III build tips ozmo01 Thermal 5 Jan 20, 2008 07:44 PM
