Old Mar 04, 2010, 12:15 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Rafale 64 mm from FMS .
I get my second Rafale . The first model also feel good and still fly well , it have some modification to make it faster in the second model .Now i want to do a extremely modification to let it more fast and better . I have open box and see the steam mold hole everywhere in the both surface , especial the bottom side a lot of this cripling. i use a sharp knift cut it out and light sanding , The surface are big different feel you can feel by hand . Second step are add the washout and thin the tailing edge . I will do the ducting tomorrow .
kin is offline Find More Posts by kin
Old Mar 04, 2010, 12:43 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
I complete the repair painting in the midification parts and add a little weathering .
Old Mar 04, 2010, 03:38 PM
splitpilot is offline
Find More Posts by splitpilot
splitpilot's Avatar
trying to catch Mr. FrSky... It flyes
Joined Jan 2005
Nice touch, I have one also. I painted the tail just for fun. You may check it at any time
J.
splitpilot is offline Find More Posts by splitpilot
Old Mar 04, 2010, 10:34 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
tonight make the ducting modification .
Old Mar 05, 2010, 05:08 AM
splitpilot's Avatar
Joined Jan 2005
BTW it is nose heavy!!! I move the main gear to the front and added weight whre the main was.. Also added weight inside the fan mount.
Old Mar 05, 2010, 09:40 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
hey! what kit is this n where can you buy it? I've seen it b4, and I'm thinking of getting inta 64mm size jets!
whiskykid is offline Find More Posts by whiskykid
Old Mar 05, 2010, 12:13 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
This is a FMS kit from china ,It quality are ok ! The 64mm fan are freewind products . my first model are fly very well , now are the second and do a extremely modification .let it fly much faster . the fan fly in 4s /2200mah the motor is 3500kv .Flying time (70% time full throttle ) is 3.5 min .The c/g for my first model is show in the photo . it is close the second panel line .i will fly it no landing gear .i will do the centre wall in the intake ducting .it can improve the speed .and the centre wall also add behind the fan motor .I don't need the rudder .fix it in exopy and take out any useless thing .let it extreme light .Let see how the performance???
Old Mar 15, 2012, 02:24 AM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Metrics
Ha! No posts in 2 years. Well, since I've been measuring performance metrics with all my planes lately, I thought I wouldnt leave this one out.
My beloved Rafale is my first R/C plane. It's done me very well over the months. It is stock, running on a 1300ma 3S 25C pack:
AUW: 666g(1.5lbs)
Thrust: 470g (1lb)
25A/300W
For fun, I stuck on a 4S 3300ma 40C pack:
Thrust: 760g (1.68lbs)
40A/614W
I've thought to use a 4S, but I admit I like the docile, calm flying of the 3S. This is the jet i fly when I want to relax. It's has a perfectly balanced fan unit (courtesy of Don) so it sounds buttery smooth.
TheCure is offline Find More Posts by TheCure
Old Oct 28, 2012, 06:02 PM
Znybar is offline
Find More Posts by Znybar
Joined Sep 2012
Model just arrived.
Question: I plan on replacing the EDF with an alloy version, but I see no way of removing the EDF access panel without doing damage (there seem to be foam 'plugs' covering what I believe might be screw mounts or something). Can you guys help with this? Should I just go for it and try and get the plugs out?
Also, do you guys think a 2200mah 3S will fit (from looking at it space shouldn't be an issue)? I might go 4S later on too.
Znybar is offline Find More Posts by Znybar
Old Oct 28, 2012, 06:23 PM
TheCure is offline
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
2200 may fit, but will most likey put the cg too far forward.
those plugs look daunting, but get very think dull knives on either side, slip them in and jimmy the plugs out. if done carfully, little evidence will show you touched them
Old Oct 28, 2012, 09:13 PM
Znybar is offline
Joined Sep 2012
I'm hoping the alloy EDF will be a bit heavier than stock and will make balancing the CG easier.
Also, I managed to tease the plugs out, but not without severely mangling them. They make a tight fit, and it's rather obvious the plane was painted after they were inserted. Once you pull them out, taking the screws out is a breeze.
The stock EDF was also glued in. Seems silly to me when there's already a groove holding it in place.
Old Oct 29, 2012, 07:09 AM
Znybar is offline
Joined Sep 2012
Just finished putting it together. Getting the CG to the right spot (the same that Kin used) is easy with a 2200mah 3S, just push the lipo as far back as it goes.
Old Oct 31, 2012, 10:33 PM
Znybar is offline
Joined Sep 2012
Maiden was a near crash, CG is actually much further forward than expected. A 2200 3S needs to actually be pushed forward almost as far as it will go (the rudder links get in the way).
Once that's done, very docile flier. Like all deltas it's very floaty at low speeds, but can carry good speed if need be. Not a rocket with the stock setup, but fast enough for some fun flying. Very scale looking model, a pleasure to fly! I'm getting about 4 minutes' flight time with the 2200 3S 45-90C nano-tech, WOT ~70% of the time. I'm planning on fitting a Mercury engine and staying on 3S, should improve speed significantly.
Old Nov 28, 2012, 10:29 PM
Znybar is offline
Joined Sep 2012
I've managed to fit the 64mm Mercury 4S version. I tried on 3S, and while it was a small improvement over the lander (huge improvement sound-wise) I decided to go 4S anyway. So now I'm fitting 2200 4S zippy 40C lipos and the thing moves and sounds fantastic. Getting the lipo to fit initially was a bit of a pain, a fair bit of cutting must be made at the back of the canopy. Now the bird has more than a 1/1 thrust ratio, easy to hand-launch and glides in like a treat.
Old Nov 28, 2012, 11:37 PM
TheCure is offline
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
sounds very enticing.
this december i will finally get around to finishing the installation of a 70mm changesun fan on 4s. i will try the 2800kv motor, and drop down to the 2300 if its straining too much.
i did thrust tests awhile back and saw a 1:1, or slightly higher
Discussion How to cut 1 mm and 2 mm Depron? Sackie Scratchbuilt Indoor and Micro Models 40 Mar 18, 2014 02:28 PM
Wanted 64 mm edf unit eschult Aircraft - Electric - Jets (FS/W) 6 Nov 22, 2009 05:40 PM
For Sale 64 mm fans NIB bruff Aircraft - Electric - Jets (FS/W) 3 Oct 28, 2009 07:51 PM
For Sale FMS Rafale (same as HL Rafale) $140 OBO or $75 with no elecs cray2602 Aircraft - Electric - Jets (FS/W) 3 Dec 22, 2008 12:49 PM
Discussion Looking for RAFALE edf 56 mm plans Adriax-1 Electric Ducted Fan Jet Talk 0 Nov 08, 2006 05:33 AM
