Old Nov 14, 2014, 05:40 PM
Joined Nov 2014
Question
The airfoil of a flying wing?
[SIZE="3"]I was wondering where I could find a pattern of an airfoil I could use for a hot wire cutter to make a flying wing. I was hoping to make it around 45" total wingspan.
daboomafoo is offline Find More Posts by daboomafoo
Old Nov 14, 2014, 06:55 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
That's an awfully broad question. Depending on the type of 'wing there are a bunch of airfoils you can use. The MH 45 AND PW 51 are popular but there are dozens of others that will work. The most important number is the moment coefficient, abbreviated Cm. Here's a source of coordinates and characteristic data. http://airfoiltools.com/
--Norm
nmasters is offline Find More Posts by nmasters
Old Nov 15, 2014, 02:41 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Try something with a bit of reflex like the one in the pic gotten from airfoiltools.com here:
http://tinyurl.com/o3vn3u8
djacob7 is online now Find More Posts by djacob7
Old Nov 15, 2014, 07:15 AM
Joined Nov 2014
Thanks for the info Ill start with the airfoil djacob7 has and see how it goes.
Old Nov 15, 2014, 01:14 PM
Fremont, CA
Joined Jan 2009
A few suggestions:
1. I would use this technique for cutting the wings
Hotwire demonstration (3 min 30 sec)
2. Make the template about 0.5-1.0mm larger all around because the wire will cut more than its own diameter depending on its temperature.
3. If you're going to use the cut foam for the elevons, don't make the trailing edge too thin. No thinner than about 3mm. Elevons out of balsa can have TE of 2mm or so.
4. You might know this already, but the pic shows two methods of hinging the elevons.
Discussion which airfoils are used for flying wing UAVs raj777 Flying Wings 2 Jul 02, 2014 10:04 PM
Discussion Need help selecting an airfoil for a flying wing gauravag Flying Wings 7 May 09, 2014 01:20 PM
Discussion Detachable/portable flying wing with true airfoil: your parkflyer in a "backpack" fheanor Foamies (Scratchbuilt) 2 Feb 03, 2014 11:25 AM
Discussion KF Airfoils and a possible Project DLG Gull Wing Flying WIng GreenAce92 Sailplane Talk 1 Feb 22, 2009 02:23 AM
flying wing airfoils continued: Sipkill airfoil? Ronbo Power Systems 2 Dec 23, 2001 09:19 PM
