FC108 5.8GHz 32CH FPV Transmitter Camera with Servo Gimbal
All in One Camera/Tx/Pan/Tilt System
Simplify Your FPV Setup
The FC108 is a compact all in one FPV system. The housing is plastic and fully encloses all the electronics and features servo operated pan and tilt. It also has a camera and a 200mW 32 channel 5.8GHz video transmitter built in making this a tidy unit to put on your aircraft or vehicle. Stay tuned for our full review coming out soon.
Learn More about the FC108 at Banggood.
Old Dec 24, 2014, 03:03 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
It seems that Video Out should be connected to Video In in order to have the image. Otherwise I can't imagine how they implemented external OSD.
Operation Travel stated as 60degree - this is very narrow.
They also didn't specify what camera they used.
Not impressed at all by this, Jason.
schumixmd is offline Find More Posts by schumixmd
Old Dec 24, 2014, 05:19 AM
UAV119 is offline
Find More Posts by UAV119
UAV119's Avatar
Joined Oct 2014
Specifications
These were the specs on their web site :
Specification:
Camera 1 Effective Pixel Array: 976(H) x 496(V)
2 Pixel Size: 5.00um x 7.40um
3 Effective Image Area: 4.88mm x 3.67mm
4 Optical Format: 1/3inch,RGBBayerfilter
5 Dynamic Range: 65.5(dB)
6 SNR: 46.4(dB)
7 Video Output: 1V0.2Vp-p/75Ω
8 TV System: PAL/NTSC
9 Operating Voltage: +6.0V~ +30.0V
RT
Transmitter 1 Transmitting Frequency: ISM 5.6GHz-5.95GHz 32CH
2 Supply Current: 110mA10mA
3 Video Input Level: 1V0.2Vp-p/75Ω
4 Audio Input Level: 0.5~2.0VP-P/10KΩ
5 TV System: PAL/NTSC/SECAM(AUTO)
6 RF Output Power: 200mW(23dBm0.5dBm)
7 Antenna Connector: SMA Connector
8 Operating Temperature: -10℃~+85℃
Servo 1 Control System: Positive PWM control(1500 usec Neutral)
2 Operation Voltage Range: 4.8V~6.0V
3 Operation Temperature Range: -20℃~+60℃
4 Standing Torque: 1.0kg.cm
5 Speed: 0.14 sec/60 deg at no load
6 Idle Current: 70mAat stopped
7 Running Current: 390mA at no load
8 Dead Band Width: 5 usec
9 Circle: 15000 times
10 Direction: Anti-clockwise/pulse travel 1500 to 900 usec
11 Driver Type: FET drive
12 Motor Type: Coreless
13 Potentiometer Type: Indirect
14 Operation Travel: 60 10
15 Gear Material: 150mm
16 Case Material: 26AWG,Futaba universal
17 Connector Wire Length: Negative
18 Connector Wire Gauge: Positive
19 Wire Info(Brown): Signal
20 Amplofier Type: Analog
UAV119 is offline Find More Posts by UAV119
Old Dec 24, 2014, 11:01 AM
MaydayMayday is offline
Find More Posts by MaydayMayday
MaydayMayday's Avatar
United States, CA, Fremont
Joined Jul 2011
I agree 60 degrees seems limited. I wonder if it can be modified, eg they use standard micro servos.
I think it might work ok for a FPV car....
Interesting though, when you look on their website the picture of it in the box is clearly 90 degrees...... hahaha
MaydayMayday is offline Find More Posts by MaydayMayday
Old Dec 24, 2014, 11:09 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
And I know why. Because standard servo is able to turn mechanically 180 degree, but only 120degree when connected to standard radio with 100% end points.
So, now I assume they say 60 degrees in one direction.
Old Dec 25, 2014, 08:02 PM
shelbonic is offline
Find More Posts by shelbonic
Joined Dec 2013
any nexwave connection IE Immersion ??
shelbonic is offline Find More Posts by shelbonic
Old Dec 27, 2014, 08:05 PM
nige838 is offline
Find More Posts by nige838
United States, TX
Joined Oct 2009
Now if they made it a point to make it really small, then this would be more interesting...
nige838 is offline Find More Posts by nige838
Old Dec 28, 2014, 04:42 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
I love the concept, but I also agree 60* rotation is almost impractical on pan. Also I am assuming a cheapie CMOS cam. What breed vTx is it? How easy is it to change channels? What quality is in the servos, coz I'm wondering how much buffeting would be passed through from the servo slop to the camera (which would result in lots of jello effect) when using enclosed CP antenna such as Spironet.
Great concept, but as per usual it would seem another great idea falling well short of what the mainstream requires.
That said though, at under $80 I'd be tempted to try one, but not without at least 180* rotation on pan...
AussieHoppy is online now Find More Posts by AussieHoppy
Old Dec 28, 2014, 04:48 PM
Airworks is offline
Find More Posts by Airworks
Helicopters
Airworks's Avatar
United States, MA, Adams
Joined Oct 2008
every move of the camera moves your antennas orientation.
Airworks is offline Find More Posts by Airworks
Old Dec 28, 2014, 05:10 PM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Good idea, bad execution.
they should have used servos with more travel. And either skipped the video transmitter or mounted it on the stand, not on the camera.
Xermalk is online now Find More Posts by Xermalk
Old Dec 28, 2014, 05:24 PM
Joined May 2010
Your plane will move through orientation changes far more than P & T
Originally Posted by Xermalk View Post
...or mounted it on the stand, not on the camera.
My thoughts exactly
If they refine this product with half decent servos, a half decent camera, and a decent vTx mounted say vertically off the base behind the cam and keep the aerodynamic drag to a minimum.... then the next challenge is keeping the price down lol
Old Dec 28, 2014, 06:19 PM
Sweden, Helsingborg
Joined Jun 2012
Id actually skip the fpv tx completely. Most will already have one they prefer to use anyway.
I do wonder what servos their using, Hobbyking has some small 180 degree metal geared ones. That does slightly below 240 degrees if you extend the limits on your tx. Though the servo horns on those are crap, the plastic "cogs" on them will strip long before the gears will be in any danger. Making the metal gears pointless/a waste of weight.
Old Jan 11, 2015, 10:59 AM
The Valkman is offline
Find More Posts by The Valkman
The Valkman's Avatar
Joined Nov 2011
Metal gears wont strip near as easy on a bad landing.
I see no mention of weight on this.
The Valkman is offline Find More Posts by The Valkman
Old Jan 11, 2015, 02:29 PM
Sweden, Helsingborg
Joined Jun 2012
The Valkman
The servo horn on that servo will strip with less force then what it takes to strip the gears on a 5g plastic servo.
Old Jan 16, 2015, 08:33 AM
Joined Nov 2011
Are you saying a metal gear servo will strip more easy than a plastic?
New Product SKY-N2000 FPV 5.8GHz 2000mW 32Ch A/V Transmitter with display bigheadfpv FPV Equipment 28 Yesterday 12:20 AM
Help! Problems with 8" Lumenier LCD FPV Monitor with 5.8GHz 32CH Diversity Receiver rockdude14 FPV Equipment 3 Jan 10, 2015 09:54 AM
For Sale Skyzone 32CH 5.8GHz FPV Micro 500mW AV Transmitter TX TS58500 uuustore1 FPV Equipment (FS/W) 0 Aug 16, 2014 05:41 AM
For Sale FPV 5.8G 600mW 32CH A/V Transmitter 32CH A/V Receiver (RX) W/ LED Channel fpvhobby_mandy FPV Equipment (FS/W) 6 Oct 11, 2013 03:06 AM
