Old Yesterday, 05:25 PM
CaptainElios is online now
Find More Posts by CaptainElios
Flying to help
Joined Apr 2013
GPS Tracker
HI,
Because we can go very faraway only with DL, and we might lose the battery power, I want to use a personal GPS GSM tracker.
which one do you recommend based on field test and experience.
I saw this one http://www.goodluckbuy.com/tk102-gsm...s-tracker.html
CaptainElios is online now Find More Posts by CaptainElios
Old Yesterday, 11:56 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by stevemaller View Post
It's a beautiful place. That's a lot of the reason I want to go long range here...there's so much to see!
So this morning's update:
I got out my RF Explorer and tried to do some sleuthing. I saw a few things. These observations were all made in micro power mode. And as a reminder, I am using a V2 receiver with the Nextgen 1280 firmware (not a Micro receiver).
  • I did switch over to using the PPM stream, and that works fine. I'm still powering the DragonLink from the PPM servo lead, though, so I could investigate powering it separately.
  • The GoPro has been exonerated...doesn't seem to make a lick of difference if it's on or off
  • I saw a small difference in the noise floor depending on what vTX frequency I use, so I picked one that was a little less noisy
  • I also tried powering off everything running on 12V (vTX, gimbal, FPV camera) and they didn't make a difference, either
  • I also tried putting on a random antenna on the DL RX and TX and testing, but the signal degraded badly in both cases, so my conclusion there is that my antennae are good
I went ahead and flew the same route as yesterday and did make it farther (3.2km!) but I guess my choice of video frequencies wasn't good, as I had a pretty bad brownout on the way back (2-3km were dark!). I did make it back just fine (thank goodness for a well-configured NAZA-M V2) after the video and DL came back to life about 2km out.
So I'm left with the possibility that maybe the problem is with my Dragonlink transmitter, which is the only thing I don't have the ability to swap out.
Any thoughts? I guess I have to just send it all in to Mike and have him work his magic. Sigh.
EDIT: here's a video showing what happened today!
https://vimeo.com/127083449
My thoughts...both your control and video were twitching in and out together. That makes me think there's something 'external' going on...like strong rf swamping your signal from somewhere. Where? Don't know...perhaps underwater alien spying post or something. Just to see the FS glitch with the camera tilt down and with the video blacking out at the same time...curious...but I'd almost guess not just DL issue.
Vantasstic is offline Find More Posts by Vantasstic
Old Today, 12:13 AM
IamtheWalrus is online now
Find More Posts by IamtheWalrus
Australia, NSW, Moss Vale
Joined Jun 2013
Could it possibly be a supply voltage issue? Perhaps after the battery voltage sags to a particular voltage, any on board regulation may be suffering a brown out? Just my two cents.
IamtheWalrus is online now Find More Posts by IamtheWalrus
Old Today, 02:08 AM
suxi is online now
Find More Posts by suxi
Open Source It!
suxi's Avatar
Joined May 2013
Originally Posted by CaptainElios View Post
HI,
I am using that one and it already helped me once to recover my plane 25 km out. If weight is an issue you can even take the pcb out of the heavy case. Then you just need to make sure that the battery will stay connected after a crash. I wrapped my construction into thick velcro. Also take under consideration that it needs a mobile phone network as well as a GPS fix in order to work. Both can be tricky if the tracker comes to rest upside down under the plane, a tree, etc.
Best...
suxi
suxi is online now Find More Posts by suxi
Old Today, 02:36 AM
tritan is online now
Find More Posts by tritan
Joined Apr 2007
Same but for $20?
http://www.ebay.com/itm/SPY-Vehicle-...item58be4d7738
tritan is online now Find More Posts by tritan
Old Today, 02:51 AM
eyber is online now
Find More Posts by eyber
Joined May 2014
Originally Posted by JettPilot View Post
The calibration procedure has changed... Go into the Micro RX computer program, and follow the instructions there. That's it, nothing more required. It only takes 45 seconds, assure that you see the CALIBRATION SUCCESSFUL message at the end of the process.
I do not understand your PPM question... But what I can tell you, PPM output is channel 7 of the micro RX by default. Connect that to the PPM input of the NAZA V2.
Do not worry about posting questions here, as anything you need. There are a lot of people here that are happy to help new people like you !!! That is what this place is for
Hi again mike. so sorry bad english ... I have a problem.. I loaded drivers on my computer. Then I runned DragonLinkUpdaterV1 exe. I updated tx . Then I updated rx for DragonLinkFirmwareUpdate exe. Because dragonlink updaterv1 not update rx. Anyway, Then change Id on grey led. Then I done binding on yellow led tx with rx but blinking blue not always led blue.. Then I run DragonLink_Config_V1_9 exe and I run advance calibrate but calibration failed. Blinking blue led on rx not always blue. Helpp please.. What problem on my procedure... Calibration failed and blinking blue
eyber is online now Find More Posts by eyber
Old Today, 03:22 AM
hawaiitaco is online now
Find More Posts by hawaiitaco
hawaiitaco's Avatar
Joined Dec 2010
I am getting the USB updaters TODAY
I will be putting them on the website www.FPVPro.com tonight !!!
You can not use the ones available off ebay, as there are many cheap and fake ones that do not work properly. Also, they need the RESET pin, which they do not have. If it were such an easy solution, I would just buy 1000 of them from china and sell them on my website, and not be bothered with making them ourselves....
so I checked this evening and its still out.
hawaiitaco is online now Find More Posts by hawaiitaco
Old Today, 04:03 AM
eyber is online now
Joined May 2014
I selected Tx_V11_1280MHz_optimized_v2 and binding okey and calibration okey. But normal TxDLNGFW27May2014-11 update is binding and calibration problem. Is it okey 1280 optimized..
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 13678 May 05, 2015 07:53 PM
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 5 Nov 11, 2014 04:41 PM
Yippee! Win a FREE Dragon Link UHF Long range RC system - BEST VIDEO contest for AUGUST !!! JettPilot FPV Talk 60 Aug 21, 2014 03:40 PM
New Product ChainLink UHF Long Range System siim227 FPV Talk 2853 Jul 01, 2013 04:23 PM
Yippee! Win a FREE Dragon Link UHF RC System - Video Contest JettPilot FPV Talk 63 Aug 02, 2011 10:52 PM
