Old Apr 21, 2015, 08:07 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by ChinoDiablo View Post
I'm thinking of putting together a NIB 48" Edge EXP that's been sitting under the stairs for the last 6 months.
I have these servos hanging around:
Hitec 5085mg.
Ya'll think these are too big?
I don't mind carving out some wood but the extra weight is a small concern.
All but the elevator will bottom out. You'll be a lot better off using HS65MGs on the ailerons and rudder. Run them on 6 volts and they will be fine.
Doc Austin is offline Find More Posts by Doc Austin
Old Apr 30, 2015, 11:35 AM
ChinoDiablo is offline
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
Love this plane!
EF Edge #2 is so sweet!
Zero coupling for KE, KE loops are a piece of cake with the suggested Torque motor running a 13x6 Xoar prop with 70amp Quantum ESC and Savox SH -2056 Super Torque servos running at 6 volts.
Needs no improvements.
She flies so much differently than my EF 48" Laser EXP, it astonishing.
As Doc sez, flying the Edge is almost like cheating... But I love it!
ChinoDiablo is offline Find More Posts by ChinoDiablo
Old May 02, 2015, 12:09 PM
skypan12 is offline
Find More Posts by skypan12
Northern IL
Joined Sep 2006
Ordered up the edge last night, this will be my first 48" from EF went with all stock power set up and have some HS 85's sitting around to go in it.
This ship sounds like it is going to be loads of fun.
skypan12 is offline Find More Posts by skypan12
Old May 02, 2015, 12:20 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I would recommend using one 85 in the elevator which will take a little opening up of the servo hole and going with micro servos on the rest. 65mg is recommended and savox has a couple of micros that work. If I ever do a 48"er again it will have HV servos.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old May 02, 2015, 12:30 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yeah, the 85 is great on the elevator but it is too tall to fit in the other openings.
I'm still running 65s and 85s in my Edges and they are fine. The HV servos are better, but the 6 volt servos are still working fine. Still, anything new I build will have HV servos.
Old May 03, 2015, 02:18 PM
732002 is offline
Find More Posts by 732002
732002's Avatar
United States, OR, Lake Oswego
Joined Dec 2003
I was skeptical of digital servos but after two of my HS65mg stopped working.
(after hundreds of flights)
I made the upgrade. Big difference in ease of hovering, like having faster reflexes.
Even on only 6V
732002 is offline Find More Posts by 732002
Old Yesterday, 12:08 AM
jk6672 is offline
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I started to build my Edge tonight and it looks like I'm going to need to use some wood stock to build out the rudder servo slot for the rudder in order to use the 5070. Also will have to cut the slot bigger for the elevator since I'll be using the 5087. hope there is enough meat.
jk6672 is offline Find More Posts by jk6672
Old Yesterday, 12:38 AM
Joined Oct 2011
I used the 85 in the elevator without adding anything for nearly 700 flights. Don't know in the rudder as I used the 65mg.
Old Yesterday, 11:50 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You can't use an 85 on the rudder because it will bottom out on the opposite fuselage side. I suppose you could space it out, but it would look incredibly bad. The 48" Edge tends to want the battery way forward anyway if you use one 85 in the tail, and in my experience the 65MG holds up really well in it's application here.
The 85 though, is still pretty close to bulletproof in these planes.
Old Yesterday, 11:52 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I used three washers under the rudder servo and that did it.
Check my blog article on installing the HS85. Remember that the plane in the article is the Extra, and the Edge has it's elevator servo on the opposite side.
Installing the HS85MG on the elevator of the Extra EXP
Old Yesterday, 06:28 PM
jk6672 is offline
John
jk6672's Avatar
Joined Sep 2012
Thanks. I cut some ply and it worked perfect today. There was also enough meat for the 5087 on the elevator.
Old Today, 03:45 AM
Add1ct3dd is online now
Find More Posts by Add1ct3dd
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
Motor box ordered, 6-8 week wait for it to get to Aerobertics
Going to rebuild it properly, and reinforce it. Last time I used hot glue and super glue, of which I realise now are both utterly useless for the repair I did initially. It also seems the superglue I have has gone crap, used in a few other applications, and the bond broke within a couple of weeks!!
Anyway, onwards and upwards. Tempted by a 70"+ over the summer
Add1ct3dd is online now Find More Posts by Add1ct3dd
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 8954 Apr 25, 2015 07:56 PM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
Discussion New Extreme Flight RC 48" Extra EXP mxcop 3D Flying 3 May 20, 2009 12:49 PM
Extreme Flight R/C Edge 540T profile MikeMayberry Sport Planes 21 Jun 17, 2004 11:08 PM
