Old Jul 01, 2015, 03:40 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
That setup will work great on either 3s or 4s
Sammy70 is offline Find More Posts by Sammy70
Old Jul 19, 2015, 01:28 PM
scottc39 is online now
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
here is what is used to upgrade my nose , I had to drill out the mounting bracket and the control arm, I used a 3.1 mm drill bit, the wire on this nose gear is 2.9mm thick, I have not flow with the new nose gear on yet but it is a lot stronger then the stock one.
http://www.horizonhobby.com/nose-gea...-rtf-efl310006
scottc39 is online now Find More Posts by scottc39
Old Jul 20, 2015, 06:24 AM
oldsamer is offline
Find More Posts by oldsamer
ARF Basher
oldsamer's Avatar
United States, TX, El Paso
Joined Jan 2011
more prop clearence ?
Nice concept, If anything , my 480's are habitual prop eaters. Existing nose gear leaves a black mark on fuse belly after a hard landing! When the nose wheel is rubbing the belly, there isn't much prop clearance.
Please reply with picture.
oldsamer is offline Find More Posts by oldsamer
Old Jul 20, 2015, 07:41 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
here is a picture before the cowl is back on.
Old Jul 24, 2015, 09:13 AM
Vulgar Vulture is online now
Find More Posts by Vulgar Vulture
AMA 34191
Vulgar Vulture's Avatar
Fayetteville, PA
Joined Dec 2002
Flew mine for the first time a few weeks ago and I'm just getting it dialed in, balance and dual rates and so forth. It flies "light" and slows down real nice for landings. This is the perfect plane for me and my current flying skills.
I WAS using a 2814/6 on 3 cells with a 8x6 but it was a tad anemic so I switched to a 2814/8, 3 cells spinning an 11x8.5 for about 360 watts but it was still a bit anemic. A 14x7 would give me 475 watts on that setup but of course, there's not enough ground clearance! I have some .40 gasser nose gear parts so I'll try the mod you guys did. I put bigger wheels on mine too.
I have some nice 40C 4 cells that paired with a 9x6 would produce 465 watts through the 2814/8. I'm looking for that high powered, tuned pipe, old school pattern feel with this one.
I would LOVE to get another one of these but my gosh I already have 41 other planes, only 10 of which I've flown yet!
Vulgar Vulture is online now Find More Posts by Vulgar Vulture
Sold 3DHS 41" Blue Edge NIB + Eflite 480 Cabledawg1 Aircraft - Electric - Airplanes (FS/W) 5 Sep 03, 2010 12:58 AM
Question Thoughts on the Ultrafly P51D w/ Retracts lafuerza Electric Warbirds 3 Sep 01, 2010 02:16 PM
Discussion Should I try high Timing on a Eflite 480? Cabledawg1 Power Systems 4 Jul 19, 2010 01:16 PM
Discussion Can't replace shaft on Eflite 480? Lowezz Electric Motor Design and Construction 6 Apr 07, 2009 10:42 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
