Old Jun 21, 2014, 01:47 PM
Foamaholic
Mayday~Mayday's Avatar
Northern California
Joined Feb 2010
Build Log
New wood FPV Mini H
So a couple months ago I sat down and started scratching out some plans for a mini H quad for FPV. I wanted it to carry all my FPV gear plus a GoPro and look good while doing it. I wanted it to take decent jello free video, so I made the bottom section dirty, separated with anti vibration balls.
After getting this thing up and running I biffed it while getting it tuned and broke my vtx, this put me out of business for a few weeks. Just got the new vtx and got it up and running again.
Even though some of the commercial frames look and perform awesome I am cheap and like to do things myself. Now, this is no seat of the pants flying but fun none the less.
Mini H quad tuned (6 min 7 sec)
Plans:
Specs:
254mm motor to motor diagonal
216mm Long
63.5mm wide
AUW 708 grams (Porker)
Gear I used:
1/8th inch Birch plywood
Epoxy Resin
HK 328p Multiwii
Ready to Fly Quads F-20 Fire Red ESC (Overkill)
Emax MT 1806 2280 Kv
HQ Props 5x4
3s 2200 Lipo
ImmersionRC 5.8 gHz 600 mw vtx
GoPro Live out video cable
Plans scratched out on plywood and coated with epoxy resin.
Parts cut out and mocked together
Parts painted Faux Carbon Fiber
Assembled
All in all I am very pleased with the way this little quad turned out. Every time I fly it, I can't help but have a big grin on my face.
Mayday~Mayday is offline Find More Posts by Mayday~Mayday
Old Jun 21, 2014, 02:07 PM
DIY junkie
InflytRC's Avatar
Joined Jun 2014
I hear ya on the doing things yourself! There's nothing like the feeling of something you cut up and put together taking to the skies. Great design and great vid! Congrats!
InflytRC is offline Find More Posts by InflytRC
Old Jun 21, 2014, 03:08 PM
Foamaholic
Northern California
Joined Feb 2010
Thank you and you are absolutely right!
Old Jun 21, 2014, 04:32 PM
United States, PA, Doylestown
Joined Jan 2014
Look and flys good.
Those Emax MT 1806 2280 Kv motors and HQ 5x4 Props seem to work well.
waltr is online now Find More Posts by waltr
Old Jun 21, 2014, 06:06 PM
Foamaholic
Northern California
Joined Feb 2010
Originally Posted by waltr View Post
Look and flys good.
They really do, I first tried the GF 5030's and they were pretty doggy.
Old Jun 21, 2014, 06:19 PM
United States, NH, Fitzwilliam
Joined Jan 2014
ye ha!
hope to be joining you soon.! i am headed to the band saw tonight. i was contemplating resin coating mine as well(mostly for a slick surface for decals) how did that work out for you strength/weight wise?
mokermeister is offline Find More Posts by mokermeister
Old Jun 21, 2014, 07:34 PM
Foamaholic
Northern California
Joined Feb 2010
Definitely gives it some additional strength, and also makes it look nice for paint Depending on how many coats you do, it does add additional weight.
Old Jun 22, 2014, 08:16 AM
Joined May 2014
How did you attach the motor to the wood? Did you just buy some longer screws to go through the wood? Did you use a nail? how did you do it?
rainless is offline Find More Posts by rainless
Old Jun 22, 2014, 11:10 AM
Foamaholic
Northern California
Joined Feb 2010
I made a paper template of the mounting holes then drilled them out. I used some longer screws I found in my flight box. An X type mount would be a heck of a lot easier.
Old Jun 22, 2014, 12:51 PM
Joined May 2014
did the screws go all the way through the wood?
Old Jun 22, 2014, 11:46 PM
Foamaholic
Northern California
Joined Feb 2010
Yep all the way through.
Old Jun 23, 2014, 11:17 AM
United States, PA, New Kensington
whats the name of the epoxy resin and where did you buy it? I'm looking for a way to cut my plywood without all the splinters. Thanks
cflchurch is offline Find More Posts by cflchurch
Old Jun 23, 2014, 02:50 PM
Foamaholic
Northern California
Joined Feb 2010
And the epoxy definitely helps with that. I used 3m fiberglass resin which I got at lowes. A quart lasts a long time on these little projects. I used a foam paint brush to spread the resin. I did two coats, after it dried I sanded smooth.
Old Jun 23, 2014, 06:37 PM
Awesome, thank you
Old Jun 29, 2014, 12:27 PM
Spain, AL, Armilla
Joined May 2014
I really like the design and I congratulate you for it, please no possibility that I can spend the plans to implement one?.
Thank you very much and best regards.
antblas is offline Find More Posts by antblas
New Product MOGO250 FPV True H Mini FPV Quad compuatic Multirotor Talk 236 Jul 04, 2014 01:30 PM
For Sale MOGO250 FPV True H Mini quad, with mini PDB included! mattjk Aircraft - Electric - Multirotor (FS/W) 0 May 19, 2014 04:28 PM
Sold ** SOLD ** NEW Mini H FPV 6061 Aluminum CNC Frame TPSreports Aircraft - Electric - Multirotor (FS/W) 6 Mar 16, 2014 05:57 PM
New Product BAH Mini H Fpv Quad bayareaheli Multirotor Talk 0 Oct 19, 2013 04:45 AM
