Old Oct 10, 2014, 09:12 AM
1Para's Avatar
Norway, Vestfold, Horten
Joined Aug 2014
Tarot and Align dfc shafts
I put my heli together yesterday after a crash, but to spare some money I ordered the Tarot DFC shaft instead of the Align DFC one. I have noticed that the Tarot shaft is shorter than the Align and because of that my pitch curve is jacked up. Before my servo horns were 90 degrees at mid stick with 0 degress pitch on the head, but now I had to adjust the servo linkages and the pitch at mid stick is still a bit off. Also the swash is pretty low on the shaft when at low stick. I heard on an YT vid that servo linkages should have 90 degrees at mid stick. Does it have to be exactly 90?
1Para is online now Find More Posts by 1Para
Old Oct 10, 2014, 11:35 AM
Joined Aug 2003
the one is a normal starting point ,would then adjust p curve for pitchthat you want at midstick
so if you want 5pitch at midstick thing arent going to be 90. same whith the low end if to low
might want to set p no to give servo to 90 first to check swash level then set curve to what you
want for picth range
mdugas is offline Find More Posts by mdugas
Sold Align t-rex 600e pro dfc metal main shaft bearing block h60217 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Nov 09, 2013 02:56 PM
For Sale Align t-rex 700 pro dfc main shaft and feathering shaft helifreak592 Aircraft - Electric - Helis (FS/W) 0 Nov 02, 2013 07:14 AM
Sold Used Excellent Cond Align DFC Head w/New Tarot DFC Swash Plus Extras $53.00 shipped kelleysislande Aircraft - Electric - Helis (FS/W) 2 Sep 15, 2013 07:52 PM
Found CopterX 450 DFC - ZYX-S - Tarot split lock DFC head - Heli tools Viper82 Aircraft - Electric - Helis (FS/W) 1 May 28, 2013 07:11 PM
Off Site Align t-rex 250 dfc pro complete rotor head swashplate main shaft grips helifreak592 Aircraft - Electric - Helis (FS/W) 0 Jul 01, 2012 02:18 AM
