Old May 12, 2013, 04:28 PM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
SplashPipe - a scratchbuilt waterproof PVC quad
Video:
20130519112807 (0 min 0 sec)
I haven't documented a build yet so I thought I'd show my process on this rig. I've accrued most of the necessary pieces, enough to get started at least.
52mm vacuum pipe trimmed to accommodate the 3/4" (22mm od) pvc water pipe:
Motor mounts being formed:
Main body and booms, trued and glued:
Bare frame weighs 310g, time to start designing the multiwii pcb. Updates to follow.
Granted is offline Find More Posts by Granted
Old May 13, 2013, 07:47 AM
Joined Feb 2013
That's awesome. I like how the motor mounts were formed. Just some heat and clamps?
Jirv311 is online now Find More Posts by Jirv311
Old May 13, 2013, 03:02 PM
Registered Loon
Blackrat's Avatar
Jeffreys Bay South Africa
Joined May 2006
cool idea , what FC you gonna use ? would be neat if it fitted in the tube ?
Blackrat is offline Find More Posts by Blackrat
Old May 14, 2013, 02:41 AM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
@Jirv - yep, heat and clamps.
@Blackrat - homemade multiwii with a GY-86 10dof IMU and everything is going in the tube.
Old May 14, 2013, 08:29 AM
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
Nice. Is that schedule 20?
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old May 14, 2013, 10:06 AM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
2" built-in vacuum pipe and 3/4" potable water pipe. If either, both, or neither is schedule 20 I couldn't say.
Old May 14, 2013, 10:15 AM
Bosons not included
jackpm's Avatar
Joined Dec 2012
how did you "trim" the vacuum tube?
jackpm is offline Find More Posts by jackpm
Old May 14, 2013, 11:47 AM
United States, NV, Pahrump
Joined Feb 2013
Looks Good. I saw another person try PVC and the weight was just too much... what does this frame weight?
trickedout is offline Find More Posts by trickedout
Old May 14, 2013, 04:50 PM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
@jack - the actual tools were an xacto and dremel, the template I produced using this site: http://www.cycle-frames.com/bicycle-...e-Notcher.html
@trickedout - 310g so far.
Old May 14, 2013, 05:07 PM
Joined Mar 2011
310g. Not too bad, not great, but certainly not a heavy pig. That's why I asked about schedule 20. Plus the wall thickness of the main body looks like 20.
Old May 14, 2013, 05:22 PM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Well, according to a pipe chart the main body would be closest to 5s and the booms 10s.
Old May 14, 2013, 06:52 PM
Joined Feb 2013
Yea I guess I should read everything... haha!!
Old May 14, 2013, 11:10 PM
Joined Mar 2011
That was genius drilling an off center chord line for maximum surface for the glue.
Old May 15, 2013, 09:24 PM
Expat
Japan
Joined Apr 2010
How's the stiffness in the sun?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old May 15, 2013, 10:17 PM
Joined Mar 2011
It's white, so even direct sunlight in lower latitudes probably will not raise the surface temp, at most, more than 30F above ambient. However, if it was to be painted flat black, that would indeed get to a surface temp to soften.
Discussion my pvc quad bhcnomo Scratchbuilt Multirotors 29 Jul 31, 2012 01:16 PM
Discussion OPENPILOT PVC Quad chevota Multirotor Talk 22 Jan 23, 2012 01:53 PM
Build Log 5.00 Dollars FPV Quad (Waterproof, 700mm, 160g) tycoyoken Multirotor Talk 8 Oct 10, 2011 07:35 AM
Sold Traxxas stampede rtr waterproof with quad body hardly used! reptileman Cars - Trucks and Parts (FS/W) 5 Dec 30, 2009 01:50 PM
