Old Feb 05, 2016, 03:33 PM
Liberty10 is offline
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
No, This is not an ATC issue. The 30 nm radius around that airport is to protect the Capital of the US from terrorists. (yeah I know, crazy right!) It was not meant to stop model aircraft from flying but it was very badly worded and well lawyers got involved and now we are waiting for a waiver to be issued. Rumor is that could happen any day.
Liberty10 is offline Find More Posts by Liberty10
Old Feb 05, 2016, 04:07 PM
sr175 is offline
Find More Posts by sr175
United States, CA, Manteca
Joined Mar 2013
Originally Posted by ckleanth View Post
Cf plate , ca, gorilla and wood glue... i tried everything.
I had the motor box kit but i didn't want to mess the plane up, now there's no strength in it, the area is wonky and it came to a point that the plane needed surgery.
This was before i rip everything out.
At some point if you have a motor box kit then it may be best to just replace that in its entirety. Generally take out the guts that the MB replaces and you just open the outer sides up put guts in and glue together. The outside of the plane they do not include so some fab required there. Over generalization I know. Just got done on the 74 and just doing the whole thing was much easier than messing with it. I know, there are many opinions on this but.... This plane is only $179 here in us so not sure how much over seas. Something to consider. Not that I would normally condone the whole buying new one every time but this is one of the cheaper airframes. Too much is done where many can be fixed with some time and thrown away.
sr175 is offline Find More Posts by sr175
Old Feb 05, 2016, 04:41 PM
ckleanth is online now
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
Yea but the issue is the two last struts/formers that I have asked for dimensions are not included in the MB kit. No way im throwing away a good airframe. My little extra is special..
ckleanth is online now Find More Posts by ckleanth
Old Feb 05, 2016, 09:07 PM
ckleanth's Avatar
Joined Mar 2011
Originally Posted by freddy_fo View Post
ckleanth, based on the drawing you have posted I get 44mm including the tab for the side dimension. Tab is 2mm.
I get approximately 96mm for the width of the bottom of the middle strut. My plane is together so I measured the bottom in front of the main gear and subtracted 4mm.
thanks.
thanks all. I now have everything I need
Old Feb 06, 2016, 09:39 AM
ckleanth's Avatar
Joined Mar 2011
By the way i copied the landing gear plate from the motor box kit and created a drawing as well as the two rear formers that are not included in the MB kit. Im hoping that the cnc laser cuter people can cut the G10 epoxy resin plate so next week i'm hoping that i will be making them (fingers crossed have them by friday).
Question is does anyone also want these to cut more? Will send them at whatever it cost me (don't think it will be more than 10 but i will confirm this) plus the postage..
PM / let me know if you want any.
Old Feb 06, 2016, 09:59 AM
ChinoDiablo is online now
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
Ck, consider using 1/4" ply like Eagle2Nitro did when he rebuilt his formers on his Edge
http://www.rcgroups.com/forums/showp...ostcount=11852
ChinoDiablo is online now Find More Posts by ChinoDiablo
Latest blog entry: Refining the Hanger
Old Feb 06, 2016, 10:15 AM
ckleanth's Avatar
Joined Mar 2011
Cheers. I copied the original pattern and that is 3mm ply, this needs to be this thick to fit in the battery tray otherwise stuff will need filing etc. I made the lightening holes smaller to give it a bit more strength and consider a few alternative options how the LG plate connects in the rear former (the original design uses 3 tabs that go into slots in the former.
The problem i want to minimise weight penalty and second if i make it ultra stiff any impact will transfer to the fuse and effectively generate more damage. Im happy if one gets it wrong to just change the LG plate and the formers; its realy easy to change them especially now that i can cut the formers and keep spares.
Old Feb 11, 2016, 01:28 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Placed an order today for the Extra and a few 5070's. I've never flown this one and I'm sure it's going to be a blast, just as the other 48's. This will also be the first 48 I'll have flown without a Motrofly and 14x7 up front. It will be interesting to see the difference between the two power systems.
jk6672 is online now Find More Posts by jk6672
Old Feb 11, 2016, 01:44 PM
sr175 is offline
Joined Mar 2013
Oh Yeh I hear you and i know that stuff is not included. Although this plane is half the size, but similar process, I just redid my 74 edge and I peeled the outside back, this stuff is not included in MB kit, replaced the guts with the MB kit and then put back together. No man i applaud you for doing that. It seems that everyone just throws away good planes that only need a number of hours of work and get new ones. Still learning the repair process stuff as I am not as fast and maybe not as good as you guys that have been doing it so I enjoy hearing how your doing it.
Old Feb 12, 2016, 05:24 PM
John
jk6672's Avatar
Joined Sep 2012
I was just looking at the manual, does the extra really come with EZ connectors, instead of double ball links, or is the manual just outdated?
Old Feb 12, 2016, 05:45 PM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
Mine came with ball links. A few bits of manual are out of date.
GoAround is offline Find More Posts by GoAround
Old Feb 12, 2016, 06:05 PM
Gregertman is online now
Find More Posts by Gregertman
United States, IL, Glenwood
Joined Nov 2013
Yep the manual is outdated. All the EF 48s come with ball links.
Gregertman is online now Find More Posts by Gregertman
Old Feb 13, 2016, 01:11 PM
ckleanth's Avatar
Joined Mar 2011
John, you will need a taller landing gear. I got a perfect match from the chinese website. I can
find the part number if you want.
Did you draw the ones from the edge? If you can draw the pieces assembed measure something substantial on the page (a line perhaps 150mm exactly) and send me a scan i can draw it up pretty acurate. Then cnc laser cut and presto you got spares
The attached formers and landing gear plate are not stock, they are slightly modified from stock.
I got someone to cut them for me (as well as my 74 3dhs edge wingtip design - remember that?)
Will get them next week and if everything fits i might offer it as a kit.
Old Feb 13, 2016, 01:32 PM
John
jk6672's Avatar
Joined Sep 2012
I'll be using the Torque and 12x6 on the Extra.
Old Feb 13, 2016, 01:36 PM
ckleanth's Avatar
Joined Mar 2011
Sorry read it the other way round.
Article Extreme Flight 48" Vanquish Review matchlessaero 3D Flying 71 Jan 03, 2016 08:39 PM
Discussion Extreme Flight RC Extra 300E sd2602 3D Flying 75 Jan 30, 2012 04:04 AM
For Sale Extreme Flight 50cc Extra 300 RTF Flyinrazrback Aircraft - Fuel - Airplanes (FS/W) 2 Jan 24, 2009 06:11 PM
