Old Feb 22, 2014, 09:38 AM
Punch it, Chewie.
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
So...corny...must...AAAACHH!
x_x
RPM314 is offline Find More Posts by RPM314
Latest blog entry: "Falcon Mk. V"
Old Feb 22, 2014, 06:07 PM
Barry Leger's Avatar
Canada
Joined Nov 2004
Here's my scratch-built wing!
Link to the build and plans:
http://www.rcgroups.com/forums/showthread.php?t=564429
Barry Leger is online now Find More Posts by Barry Leger
Old Feb 22, 2014, 06:38 PM
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Originally Posted by speedactyl View Post
im impress with your muti-engine wings wonder if this is doable
8 Prop motors and 2 EDFs
I suppose it's possible. CG would be problematic.
KFC is offline Find More Posts by KFC
Old Feb 25, 2014, 12:50 AM
rodher12's Avatar
United States, CA, Calexico
Joined Sep 2011
Originally Posted by rodher12 View Post
I made my fpvTrond's fpv49 V3 flying wing.. due to have no depron near i used 12 pieces 20x30 dollar tree foam board, i just need to use three on each layer so it can reach measures.. flies very nice and stable.. thanks Trond and creators of kfm airfoil...
For measures you can go to fpvTrond's yt channel..
Here it is flying with mobius onboard...
fpv49 V3 and mobius test flight unedited (3 min 35 sec)
rodher12 is offline Find More Posts by rodher12
Old Feb 26, 2014, 05:27 PM
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Yup im fascinated on how the flight controller keeps multirotors nice and level. and want to know how it would behave on a finless flying wing using differential thrust and like you said Drag Rudders are a Drag.
BTW is esc braking require in multirotor style setup?
I had very good results flying finless wings with multiwii FC
few years ago FC were hard to get esp.w/ wing mode , back then gyro alone was useful too:
skyfun wing launch (3 min 3 sec)
fmkit is offline Find More Posts by fmkit
Old Feb 27, 2014, 10:13 PM
rodher12's Avatar
Joined Sep 2011
FPV49 Hard Crash!!
FPV49 V3 crash (LOS) (2 min 12 sec)
Old Mar 03, 2014, 09:39 PM
Flying Foamies
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
KFC : I finally went Finless on one of my wings. single motor too.
on first flight its difficult due to the uncontrolled Yaw,
2nd flight added Diffusers on the wing tips they substitute the function of the fins and it worked. only you have to be flying fast for it to work.
speedactyl is online now Find More Posts by speedactyl
Old Mar 03, 2014, 10:16 PM
Punch it, Chewie.
RPM314's Avatar
Joined Apr 2012
Well if you are not going Mach 2 with your hair on fire, then what is the point? Should be fine.
Old Mar 03, 2014, 11:17 PM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
Typo its Diffusers
Old Mar 06, 2014, 05:00 AM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Here is my 56" wing (roughly) First hot wired wing so it's a little rough but seems to glide super nice. Plan on flying it with a 4000mah 3s unsure on motor and esc probably something that with swing a 10" prop. Will hollow out center section and add winglets if this flies good it will be my new medium range plane. I plan on building another one with a thinner center section and hopefully it with be more efficient here are the pics enjoy
Description:
Description: MH-45 the rest of the rest of the airfoil will be formed by the elevon.
-Ben
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Latest blog entry: FPV49 V3 build log ( Kind of)
Old Mar 08, 2014, 05:02 PM
Joined Nov 2011
Wind Cutter
I have been flying this wing a lot because it cuts through the wind so well. The 9050 prop is supplying 30oz of thrust that really helps scoot down range into 15MPH steady winds. It seems to be windy all the time where I fly.
JerseyDevil is offline Find More Posts by JerseyDevil
Old Mar 09, 2014, 03:18 PM
Punch it, Chewie.
RPM314's Avatar
Joined Apr 2012
What airfoil does that use?
Old Mar 10, 2014, 11:45 AM
sygy's Avatar
Joined Dec 2011
Lancer
Here are some pics of my own flying wing design "Lancer". This is the end result of something I've wanted to do for a long time. It has a 59" wingspan, weighs just under 10 lbs, has retracts and an OS95AX engine. The wing design is very special for high maneuverability and low speed handling. See the design and build thread (with plans) here:
http://www.rcgroups.com/forums/showthread.php?t=1999514
sygy is offline Find More Posts by sygy
Old Mar 10, 2014, 10:08 PM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
why not....
1:5 aspect ratio still find it a bit fast and agile.
PICT0010 (3 min 51 sec)
PX31-A cam (3 min 47 sec)
Old Mar 11, 2014, 08:59 AM
Joined Nov 2013
FPV44 My First FPV Flight
Stacey coaxes me along as I experience my first FPV flight last year.
FPV44 v1 First FPV Flight (10 min 26 sec)
BeerNWingz is offline Find More Posts by BeerNWingz
Discussion Show your Slow Stick wings IamLegend Aerial Photography 33 Mar 22, 2008 04:09 PM
Show your support! (for soaring) hardlock Electric Sailplanes 1 Jan 07, 2002 11:25 PM
Having trouble launching your wings consistently? Admiral_Redman Foamies (Kits) 3 Dec 11, 2001 09:48 AM
Having trouble launching your wings consistently? Admiral_Redman Foamies (Kits) 0 Dec 10, 2001 08:20 PM
Lazy Bee: show your pics? Mike Wood Sport Planes 10 Oct 31, 2001 05:08 AM
