Old Aug 31, 2014, 05:18 PM
Joined Aug 2014
I have usb-rs232 full adapter (prolific pl2303hx chip + max213 level chip).
I think, if i connect my dht-u module directly to pl2303 chip (ttl levels) and load rs232 interface in pl2303 chip from 3.3v - i could reprogram my dht-u with it.
What do you think?
Also i want flash my D8R-II plus to D8R-XP 27ms firmware via this cable, but in original condition (tx and rx connect to max213 for serial rs232 levels on it).
DJ_URAN is offline Find More Posts by DJ_URAN
Old Aug 31, 2014, 05:56 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by jhsa View Post
Wasn't it the old V8R7 or whatever it was called that outputted PPM? Can't remember well as it was a while ago..
V8R7-SP.
http://www.frsky-rc.com/download/down.php?id=89
Daedalus66 is offline Find More Posts by Daedalus66
Old Sep 01, 2014, 12:52 AM
Romania, Dolj, Craiova
Joined Sep 2007
What do you think?
Should work this way
renatoa is online now Find More Posts by renatoa
Old Sep 01, 2014, 07:35 AM
Joined Aug 2014
Thank you! I will try it today and tell you result.
Other question:
Is it possible to know what firmware version is flashing in my D8R-II plus receiver?
Which version in stock new receivers is flashing?
My receiver binds to other TX frsky with no problem, so i think that firmware in my D8R-II plus is 1 version, cause other frsky TX have first gen firmware.
In manual says that firmwares of RX and TX MUST be same versions to make possible to bind RX to TX.
I will reflash my RX today but i want also to know what FW version now in it.
Old Sep 01, 2014, 08:42 AM
JLT_GTI's Avatar
Oviedo
Joined Jun 2010
Silly question.. could the D4R-II broadcast PPM? and if it does can it provide more than 4 channels throught the PPM or is limited to 4 same as the physical channels?
im going to build a multicopter with an AcroNaze32 board.. i have a D4R-II arround and tought about using it ..but maybe just 4 channels is too basic?
JLT_GTI is offline Find More Posts by JLT_GTI
Latest blog entry: CL-415 GuanLi
Old Sep 01, 2014, 09:00 AM
Germany, Berlin
Joined Jan 2012
Jumper ch 3+4 and you get PPM ch 1-8 on pins of ch1. BUT you should upgrade the firmware to the 27ms FW-version for safty reasons.
Greetings Marc
divemarc is online now Find More Posts by divemarc
Old Sep 01, 2014, 09:31 AM
JLT_GTI's Avatar
Oviedo
Joined Jun 2010
Greetings Marc
Thanks.. i found a video tutorial wich confirms 8 channel output.. still i probably would need 5 at most
FrSky D4R-II PPM setup for Naza Lite w/GPS, 9XR, DJT (4 min 55 sec)
Old Sep 01, 2014, 09:33 AM
Joined Sep 2007
For less than 7ch you are safe with 18ms frame, is an overbeaten dead horse...
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
