Old Nov 03, 2015, 05:58 PM
anitelite is offline
Find More Posts by anitelite
Pearland, Texas
Joined Feb 2000
head design
Good afternoon
In the interest of simplicity, I bought a sheet of the thin reinforced fiberglass to make one of the head modifications I see being used on the Atom Special and similar aircraft. Based on the design in my Scout and others, the use of the fiberglass plate will eliminate the flapping hinge that I'm used to. If the hinge isn't needed, will the fiberglass still allow the blades to move up and down as needed? Should I be concerned about a blade strike on the fuselage?
Thanks!
anitelite is offline Find More Posts by anitelite
Old Nov 12, 2015, 05:08 PM
boberos is offline
Find More Posts by boberos
Ontario Canada
Joined Aug 2003
Yes & yes to both questions
boberos is offline Find More Posts by boberos
Old Nov 12, 2015, 06:30 PM
Graham L is offline
Find More Posts by Graham L
Joined Jul 2014
Hi Anitelite
The F/G plate (Around 0.8mm) will allow the right amount of movement for the blades to cone correctly. I would however make a larger plate than the Atom as the blades will have little room to fold back in the event of a tip over and will damage the roots. Something the size of a Whippitt plate will do well.
To avoid the blades going down too far and damaging the tail/fuselage in the event of a heavy landing , I make up a round plate to go underneath the main plate from the same 0.8mm f/g sheet and big enough just to go to the 3 edges of the top plate. This certainly stops strikes on 3 of my Gyros.
Hope this helps.
Graham
Graham L is offline Find More Posts by Graham L
Old Nov 13, 2015, 05:38 PM
Pearland, Texas
Joined Feb 2000
Thanks ! I'll give it a try and see.
Jim
FS: NIB YS 91 STR, Free Shipping Worldwide! (New Red Head, the latest design of YS91) Jason WAI Aircraft - Fuel - Helis (FS/W) 1 Dec 06, 2004 06:08 AM
Question Esky CP head design: Improvment? vpersiani Micro Helis 4 Nov 25, 2004 10:08 AM
anyone seen this? cp head design for LMH gmaster Electric Heli Talk 7 Feb 12, 2004 09:16 AM
New head design flies! BQuick Electric Heli Talk 12 Mar 23, 2003 08:55 PM
Differences in head designs RMihara Electric Heli Talk 10 Jan 11, 2002 01:18 AM
