Old Dec 13, 2014, 07:59 PM
MinneFlyer's Avatar
Joined Oct 2007
Takeoff and landing experience
I've been searching for that perfect airframe that will allow for realistic takeoff and landing experience. Ideally the plane would have a tricycle gear setup, pusher prop formation for clear fpv, and is stable at low airspeed. Here's the kicker, I'm looking for something small like 700mm wingspan or less. Anyone have a recommendation?
MinneFlyer is offline Find More Posts by MinneFlyer
Old Dec 14, 2014, 05:10 AM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Hobby King have the Skipper at 700mm. It can take off from its belly on grass or water. Or the mini skywalker is 840mm but you would need to add landing gear. But most of us use bigger planes to take the weight of landing gear.
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Dec 14, 2014, 02:41 PM
rcastab's Avatar
SF Bay Area, California, USA
Joined May 2001
I think with a 700mm wingspan, you would need a very light airframe, AUW of about 8-oz with FPV gear, and you'll need to fly indoors to get close to scale like flying via FPV. Very calm air is important for light weight airplane to have it fly true and stable.
Achieving scale like flying via FPV is easy with larger RC airplanes (More stable frames) but that would mean you'll need a larger flying field and longer landing and take-off runway, flying at higher velocities.
From my experience, I think a wingspan between 1.6 to 2.0 meter, AUW of about 34-oz, resulting in low wing loading (glider type) is a good compromise to be able to fly outdoors in a open field in calm air and experience scale like and slow flying characteristics via FPV.
Also, I think you'll need good landing gears that will absorb impact and help to keep your plane flying in the straight path during take-off and landing. I recommend using springs or something that will help cushion the rough ground.
A 3-axis stabilizer is also a must to help keep the plane balance while FPVing.
This type of FPV use has not caught on yet and I don't see a lot of options out there at the moment, so I made my own airframe to achieve the craving that I have to fly scale like or do what I call "Airport FPVing".
HD-Airport FPV scale take-off, flying, and landing-uncut (25 min 34 sec)
rcastab is offline Find More Posts by rcastab
Video Flight of vectored thrust delta with takeoff/landing on runway nuteman Foamies (Scratchbuilt) 2 Sep 12, 2014 08:16 AM
Discussion What is the minimum takeoff and landing distance for a Cessna 206? WDL244 General Aviation 4 Jun 05, 2014 04:45 PM
Discussion Takeoff and landing from a moving object Terry Rigden Multirotor Talk 3 Feb 10, 2014 12:26 PM
Discussion Hobbyking MX2 EPP 3D - Landing gear improvements for grass takeoff/landing RC Aerobat Electric Plane Talk 0 Aug 24, 2013 10:17 AM
