Old Apr 14, 2014, 07:18 AM
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
Thanks guys...believe me I was a click away from ordering that glass cowl. What stopped me was the price of shipping to get it up here. Was just as much as the cowl itself, so had second thoughts.
tailskid2 - You must have had some cooling issues did you? Just wondering if you used an approximate 2-1 ratio of vent hole (exit air) size to intake air size openings? Even with that, some cowls just don't allow proper airflow for cooling.....so point taken and will consider!
rcwings is offline Find More Posts by rcwings
Old Apr 14, 2014, 11:45 AM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I blocked that exit and opened the bottom a bit and never had a problem with overheating.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: Is it possible to lose weight?
Old Apr 15, 2014, 04:52 AM
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Yes, 2 to 1 ratio, I opened the two front holes and made a big one in the bottom exit, never had a heat problem, even on idle.
pablojaime is offline Find More Posts by pablojaime
Old Apr 15, 2014, 09:50 AM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Engine choice?
I posted a blog on the 13th of this month, received 1009 views but no comments. I have since found this thread and hope to read through it in the next few days. Anyhow, the one question I have is, will an OS 91 Surpass fit under the cowl? I already have one and would like to use it in the RV-4. I also have an OS 48 four stroke that is currently being used in a Seniorita, but I would install it on the RV-4 if that is a better choice. Thank you in advance for your comments and I'm sure I will learn a lot as I thumb through the build log. P.S. I have not purchased the kit yet, but plan to very soon
rcflyinff is offline Find More Posts by rcflyinff
Old Apr 15, 2014, 10:17 AM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
Hello rcflyinff,
You will not be able to stuff that OS 91 FS into the RV-4 cowl. You will also be faced with trimming the cowl away for the muffler. Will not be a clean fit. It will also be too much power for that plane in my opinion! I have two of those engines, and would not recommend it for this bird. Will be overpowered and will add unwanted weight, as well as prop clearance may be an issue.
Can't really comment on the 48. It may be a better choice over the 91, but will likely fly more scale like. The 48 is on the low end of the power choice for the RV-4.
Hope that helps.
Old Apr 15, 2014, 12:50 PM
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Thank you rcwings. I figured that the 91 would be to big. I'd rather not go with the low end either. Guess I will have to do some bartering for a 60-70 range four stroke. I'd rather have more power than not enough. Are there any bad flying characteristics to this plane? How about flaps? Are they worth installing? This plane looks so nice and I can't wait to purchase and get started.
Old Apr 15, 2014, 01:32 PM
los36's Avatar
United States, TX, The Colony
Joined Nov 2012
You could try to find one of these ...
http://www.rcgroups.com/forums/showthread.php?t=1512743
I'm not sure about the GP RV-4, but it fits completely inside the H9 RV-8 cowl. Well, the needles stick out the top of the cowl.
los36 is online now Find More Posts by los36
Old Apr 15, 2014, 06:38 PM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
I believe that the discontinued H9 RV-8 is slightly larger. Very nice engine though!!!
Old Apr 15, 2014, 10:10 PM
los36's Avatar
Joined Nov 2012
Well, your model has a 5" longer wingspan. That doesn't mean that the cowl is larger, but it's probably similarly sized. Think of it as fitting two .50 four strokes in there. If one will fit, then the twin will fit.
2 servos in the tail should balance it right out.
Old Apr 15, 2014, 11:55 PM
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
I thought the little 60 Saito twin would be a sweet fit in the GP RV-4. Might be marginal for power though...and for the price, I was not willing to chance it.
Wanted Wanted:Great Planes RV-4 40 kit Warby Aircraft - Fuel - Airplanes (FS/W) 1 Nov 27, 2005 05:04 PM
FS- Great Planes RV-4 Ready to ... wolfast Aircraft - Fuel - Airplanes (FS/W) 2 May 01, 2004 05:56 PM
Ebay - Magnum XL-61 4-stroke and Great Planes RV-4 kit <24 hrs to go neilo Aircraft - Fuel - Airplanes (FS/W) 0 Feb 23, 2004 12:37 AM
Great Planes RV-4 kit pepflyer Electric Plane Talk 2 Jan 10, 2003 04:09 PM
Great Planes RV-4 conversion anyone? All__talk Sport Planes 7 Apr 01, 2002 02:53 PM
