This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Mar 20, 2014, 04:58 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Just checked tracking and I should have Wicked motors restocked tomorrow :-) Finally!
The Don is online now Find More Posts by The Don
Old Mar 21, 2014, 11:43 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Just stopped home for lunch and two big boxes from my motor supplier are here. I will open them up and verify contents when I get back home from work this evening.
Don
Old Mar 21, 2014, 08:17 PM
T-CAT's Avatar
Joined Aug 2008
Excellent . Please let me know if you want me to order those two 6000kv motors from you (if they did come in when you verify) just by going through your website, or if you want to PayPal me an invoice. Hopefully you still remember my order .
T-CAT is offline Find More Posts by T-CAT
Old Mar 21, 2014, 09:55 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
OK lots of Wicked EDF motors back in stock, 4000,4800,5400,6000,4000+ and 4400+. Also I have the new 2700 KV Plus motors in for the CS 64mm fan , just have not listed that motor in the website yet.
I have posted photos of the new 2700 Plus and comparison to the current 2700 motor I have been selling. This motor should be great in a Jpower Rare Bear :-) plus it should work well in the CS 12 blade 64mm EDF fan unit.
Don
Old Mar 21, 2014, 09:56 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
You can order off the website, it would make keeping track easier for me, just note in the comment section.
Old Mar 21, 2014, 10:31 PM
T-CAT's Avatar
Joined Aug 2008
Done deal. I'll get on thaf ASAP. Thanks Don.
Old Mar 22, 2014, 12:41 AM
chuck
santa barbara, CA
Joined May 2009
don , whats the shaft size on the 2700 plus? and how much
thanks , chuck.
chas650r is online now Find More Posts by chas650r
Old Mar 26, 2014, 08:23 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is the new Wicked 2700 Plus motor and the new standoff adapter I designed for the Wicked motors. The new standoff is slightly smaller at the front compared to the old ones so now it fits into housings that only allow 20mm diameter motors to fit. The four mounting holes are still 3mm threads. The new standoff features a much larger 8mm OD bearing and can be fitted with either a 3mm ID bearing or 4mm ID bearing. The motor in the photo is setup for a 4mm shaft for the Change Sun 64mm 12 blade fan unit.
Old Mar 26, 2014, 11:27 PM
chuck
santa barbara, CA
Joined May 2009
very nice, glad to see the 4mm shaft , should be a winner.
chuck.
Old Mar 27, 2014, 01:51 PM
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Looking forward to hearing that in a video Don! Should sound great!
Alpha10 is online now Find More Posts by Alpha10
Old Mar 27, 2014, 05:56 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
CS64 12 blade 4mm adapters came today so now if you buy a CS 64 fan unit it will come with both 3.17 and 4mm adapters. Also I now have Wemotec microfan 3.17mm adapters so you can select 3mm or 3.17mm adapter size when ordering a Wemotec microfan unit.
Old Mar 27, 2014, 09:00 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Did a quick run up mounted to the Dr. Mad Thrust EDF test stand and with the inlet lip installed and no outlet tube I got 865 grams thrust at 675 watts and 44.7 amps, 15.1 volts under load. I will try and get a better reading as stuff was flying all over the place from the blast and I really need to video it to see the numbers better. The test stopped when a bullet connector on my test leads de-soldered itself so next test will be hooked up properly (I was anxious to try it out)
New Product New Products / Stock Arrivals / Product Updates thread Extreme_RC Extreme RC AUSTRALIA 6 Oct 05, 2011 01:53 AM
Discussion KP Website Update - KP10e and new Products harvey-boy Motorcycles 4 Jan 27, 2010 06:29 AM
Discussion New Website, New Products the_canuck Product Announcements 0 Mar 01, 2009 03:29 PM
Website Updated and New Products Soon mapmanufacturers Product Announcements 0 Aug 06, 2005 12:07 PM
iRate lipoly Inventory Updates frederm2002 Batteries and Chargers 11 Feb 19, 2004 12:28 PM
