Old Mar 20, 2015, 05:09 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
On all jets This size or larger I run 2 1100 A123 batteries. You probably use less than 200mah per flight, so one would be fine, but I like redundancy.
Originally Posted by Rangerfan View Post
Receiver batt size? Looks like 11 analog servos with installation of the brakes. Anyone have a batt size suggestion?
Tumbler is offline Find More Posts by Tumbler
Old Mar 21, 2015, 09:39 PM
k-fly is offline
Find More Posts by k-fly
Universal City
Joined Jul 2010
What the best cell count for a non-pro XPS fan? 11s or 12s, c rate, and Ma? It's going into Y/A f-18 single
k-fly is offline Find More Posts by k-fly
Old Mar 21, 2015, 10:20 PM
Air-Jon is online now
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
XPS used to say that 11s is best, but they said 12s can be used if using batteries with a lower C rating like 25-35C. Don't use 40C or higher cells as the wattage jumps up too high. 5000 mAa should be enough.
Air-Jon is online now Find More Posts by Air-Jon
Old Mar 21, 2015, 11:26 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
This fan system lasted only 19 seconds at full throttle using a 65C 12S5000mAh. It runs all day on 11S. The wire used for the windings in the Hacker motor is a little small and can t handle the higher wattage.
JimDrew is online now Find More Posts by JimDrew
Old Mar 22, 2015, 05:22 PM
k-fly is offline
Universal City
Joined Jul 2010
Which one will work best and keep me safe from damage the motor?
Can I run 65c 11s5000mAh all day and get good flight time or running 40C 11s 5000mAh would be ok to run?
Old Mar 22, 2015, 05:26 PM
k-fly is offline
Universal City
Joined Jul 2010
Can I also used a cc 120HV or do I need to put in cc 160 HV?
Old Mar 22, 2015, 11:59 PM
Lake Havasu, AZ
Joined Jun 2005
You can use 65C 11S no problem. You can use the HV120, you will be pulling around 100A on 11S.
Old Mar 23, 2015, 01:17 PM
k-fly is offline
Universal City
Joined Jul 2010
Thanks jimDrew
1/10 scale f-18 jg1501 Electric Ducted Fan Jet Talk 2 Dec 06, 2009 10:20 AM
For Sale NewBright R/C International Outlaw CXT 1/10 scale lv2soar Cars - Trucks and Parts (FS/W) 0 Jan 08, 2009 02:23 AM
Discussion C-119 Retracts 1/10 scale 2M86 Scale Fuel Planes 1 Oct 01, 2008 04:52 PM
Help! 1/10 scale foam F-18 with Midifan question. X-spec Foamy EDFs 22 Feb 11, 2007 01:20 PM
Davie's 1/10 Scale C-17 Flew!! Hawker Electric Ducted Fan Jet Talk 16 Jun 19, 2004 04:41 PM
